Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 05-15-2009, 11:27 PM   #1
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Arrow Foobar2000 Player Plugin
Foobar2000 Player for Ride Runner
Foobar player plugin is part of the offical Ride Runner Installer
Description:
This is a player plugin for Ride Runner which uses Foobar2000 as the audio engine.
Purpose:
This plugin provides the choice to use Foobar2000 with Ride Runner instead of winamp/wmp/fmod.
Requirements:
-Foobar2000 9.6.5 or newer (Tested with 9.6.5 Stable, 9.6.6 Beta, 0.9.6.7, 0.9.6.8 and 0.9.6.9)
Available at: http://www.foobar2000.org/?page=Download
-Foobar COM Server 2-0.7 or newer (Tested with 2-0.7 only)
Available at: http://foosion.foobar2000.org/0.9/
-Ride Runner 5-1-2009 (Untested with previous versions)
Available at: www.nisuautomotive.com
Installation:
-Copy FoobarRR.DLL to the desired location of install and use regsvr32 to register it.
For instance: regsvr32 FoobarRR.DLL (from a command prompt)
-In RR.INI set (make sure there's no winamppath= or hidewinamp= settings):
player=FoobarRR
playerpath=c:\program files\foobar2000\ (location where foobar is installed)
hideplayer=true
visuname=FoobarVis
-Open foobar2000 by itself (while RR is NOT running), and:
-BE SURE that the spectrum is visible ON THE TOOLBAR (Default) -- or visualization will not work in RR.
-Be sure that the equalizer is installed (Default) or it will not work in RR.
-Choose the colors you want for the spectrum (it will display like that in RR).
-You can use any visual/screen layout you want, it will not matter to RR.
-Open the PREFERENCES of Foobar, click on the COM Automation Server (1 on picture below), verify that the status is "Running" for the "Server" (2) and "Helper" (3) -- if you don't see the COM Automation Server option OR the status is not "Running" for the Server AND Helper, then your installation is not right and RR will NOT work. In this case I suggest you uninstall Foobar2000 AND the COM server, then re-install them fresh.
-Still under preferences, click on the Advanced section and change the full file buffering option as shown in the second picture -- if you don't do this, Foobar will LOCK the files it plays and RR may be unable to display ID3 info from the song you're playing.
Considerations:
-This is a beta version, please submit bugs/suggestions.
-This has only been tested on "portable installation" mode, but should work with standard instalation as well.
-Foobar2000 has 18 equalizer bands, RR supports only 10. This means that when controlling the EQ in RR, the mid-level bands will move in "pairs" in foobar2000 to mimic the equivalency of 10 bands from RR. 18band support will be available with the next RR release.
NOTE: If you want to use all 18 bands from Foobar, you can set them up in Foobar2000 and they will stay the same as long as you don't change them inside RR. Otherwise RR will set them as it can.
-If you turn the Equalizer OFF, the band levels will be reset to mid-level when re-starting foobar2000. This happens if you run foobar2000 by itself of from within RR -- it's a foobar2000 characteristic.
-There's no "PRE-AMP" support in the Foobar2000 player -- this function is not available in foobar2000.
Thank you for your support,
Guino.
UPDATED ON 5/20/2009:
-Hideplayer setting implemented.
UPDATED ON 5/26/2009:
-Fixed issue with resizing the Foobar200 equalizer window.
UPDATED ON 10/5/2009:
-Instructions on checking the COM server status.
UPDATED ON 10/6/2009:
-Instructions on file buffering added.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Advertisement Sponsored links
Old 05-16-2009, 01:52 AM   #2
mezz64's Avatar
mezz64 is on a distinguished road
Woohoo! Thank you Guino!
I can't wait to give this a try, RR now has the capability to provide the best SQ of any frontend available.
98' Honda CR-V
http://www.superbluecrv.com
*OBDMPG, the RR OBD Plugin*
mezz64 is offline   Reply With Quote
Old 05-17-2009, 01:11 AM   #3
sxtnitehawk is an unknown quantity at this point
i'll look into this when RR can support the full 18band EQ of foobar.....until then i see no reason to change.
Planning: [|||||||||-] 90%
Purchased: [||||||||--] 80%
Installation: [----------] 0% (awaiting arrival of parts)
sxtnitehawk is offline   Reply With Quote
Old 05-17-2009, 11:51 AM   #4
guino's Avatar
There will be 18band equalizer support for Foobar2000 on the next release of RR, but it will require a skin with a 18 band mixer to work.
Old 05-17-2009, 11:53 AM   #5
OK THEN!
so I'll make a Foobar version of my skin...
Old 05-18-2009, 09:15 AM   #6
qpwoeiruty999 is an unknown quantity at this point
That's really amazing! Looking forward to trying it!
qpwoeiruty999 is offline   Reply With Quote
Old 05-18-2009, 09:44 AM   #7
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
do these new plugins support commands like LOAD, LOADLIST and the like. PLAYPOS sliders and such work? I'm anxious to use foobar in the car but only if its RRMedia friendly
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 05-18-2009, 09:47 AM   #8
guino's Avatar
They are all built around the same player plugin interface used by winamp, so they should have all the same basic features winamp provides in RR, unless of course there's a bug/issue (which we could likely fix).
Old 05-18-2009, 12:11 PM   #9
Larry49 is an unknown quantity at this point
Hi everybody, this is my first message. I have this error with Foobar and RideRunner
How can I fix it???
tks
Larry49 is offline   Reply With Quote
Old 05-18-2009, 01:05 PM   #10
pierrotm777's Avatar
pierrotm777 will become famous soon enough
error
Don't run for me .
I have an error when i run riderunner
pierrotm777 is offline   Reply With Quote
Old 05-18-2009, 03:53 PM   #11
guino's Avatar
Did you guys install the Foobar COM Server (the bold line in the first post) ?
Old 05-18-2009, 04:31 PM   #12
I registered FoobarRR.dll and made all you said before but nothing to do....
When I open RRconfig and save it the RR.ini file return in the original state, all mods are out....
Old 05-18-2009, 07:02 PM   #13
guino's Avatar
your playerpath= setting is missing the "2000" from the path... and your visuname= is wrong as well.. please fix those and let me know if it still gives you issues.
EDIT: I just put the wrong path in here and got the same error -- I'll be adding a prevention for next release (but I can't do much about a wrong path setting).
Old 05-19-2009, 04:13 AM   #14
Works here
It works for me, at least in its basic form. Performance is yet inferior to winamp as it seems slow. Haven't checked CPU usage thoroughly, but if i remember correctly, CPU usage gets high when switching songs. Talking about foobar process, not the comserver or what is called.
Old 05-19-2009, 04:28 AM   #15
Yes , I had installed the COM Server .
This is my rr.ini:
Code:
[Player Setup] player=FoobarRR playerpath=c:\program files\foobar2000\ visuname=FoobarVis hidewinamp=true exitmute=true
.net Bluetooth Mobilephone Plugin lambosprit RR Released Plugins 614 11-19-2009 05:34 PM
RR 04-01-09 ... Never to late.. (GET HOT FIX) Blue ZX3 Road Runner 69 05-08-2009 09:39 AM
Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you) mitchjs Road Runner 63 03-10-2009 08:49 PM
Custom Indicator Bug JohnWPB RR Bug Tracker 4 03-27-2008 06:10 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
