Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 05-17-2009, 07:35 PM   #1
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Arrow FMOD Player Plugin
FMOD Player for Ride Runner
Description:
This is a player plugin for Ride Runner which uses the FMOD library as the audio engine.
This is a slightly updated version of the old FMOD player plugin (no extra features, just internal improvements to allow support for newer OS versions).
Purpose:
This plugin provides the choice to use FMOD with Ride Runner instead of winamp/wmp/foobar2000/iTunes.
Requirements:
-FMOD.DLL (included with package)
-Ride Runner 5-1-2009 (Untested with previous versions)
Available at: www.nisuautomotive.com
Installation:
-Copy FMODRR.DLL to the desired location of install and use regsvr32 to register it.
For instance: regsvr32 FMODRR.DLL (from a command prompt)
-Copy FMOD.DLL to the same location of FMODRR.DLL
-In RR.INI set (make sure there's no winamppath= setting):
player=FMODRR
visuname=FMODVis
Extras:
-You can customize the Visualization of FMOD using the commands:
"player;backcolor;Red;Green;Blue" - Set the red/green/blue colors for the back of the visualization.
"player;barcolor;Red;Green;Blue" - Set the red/green/blue colors for the bars of the visualization.
"player;showpeak;true" - Sets if the visualization should have peaks (true) or not (false)
"player;peakcolor;Red;Green;Blue" - Set the red/green/blue colors for the peaks of the visualization.
* The range of each red/green/blue color is between 0 and 255.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Advertisement Sponsored links
.net Bluetooth Mobilephone Plugin lambosprit RR Released Plugins 614 11-19-2009 05:34 PM
Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you) mitchjs Road Runner 63 03-10-2009 08:49 PM
Custom Indicator Bug JohnWPB RR Bug Tracker 4 03-27-2008 06:10 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 09:26 PM
