Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 09-22-2009, 05:51 PM   #46
lambosprit's Avatar
lambosprit is on a distinguished road
call duration is tested and will be in next release.
Video currently working for both send and receive BUT cannot get the video window embeded in rr so cant see received video. Can see sent though
lambosprit is offline   Reply With Quote
Old 09-27-2009, 06:31 PM   #47
lambosprit's Avatar
New release version 1.5. Videocalls working. You can now send and receive video. When receivevideo set , and a call is made or recieved then RRSkype_video.skin is opened and video displayed. DO NOT set auto full screen for video in skype as it stops the window capture for embedding.
Get it in first post
Old 09-28-2009, 01:25 PM   #48
Dartman_71 is an unknown quantity at this point
Is there button command which enable/disable video or is't allways on if you choose to use video?
Dartman_71 is offline   Reply With Quote
Old 09-28-2009, 06:20 PM   #49
lambosprit's Avatar
its always on if you select it.
Old 09-29-2009, 02:33 PM   #50
Lambo, I just notice you fix those two things what I asking, thank's very much
Are you planning to make enable/disable send video command? Toggle button would be best.
Old 09-30-2009, 09:29 AM   #51
lambosprit's Avatar
Your never happy you! I worry that with things like this you end up with so many buttons that you can't fit them all on the screen. I suppose it could be put on the rrskypecall.skin. I'll have a look.
Old 09-30-2009, 11:10 AM   #52
but there is allways something which makes this plugin even better. Don't worry there is allways enough space to fit few buttons. By the way rrskypecall skin doesn't open when you make a call, otherwise good idea
Old 09-30-2009, 01:19 PM   #53
I just made quick test with video and it's not work if you have SkypeCall=on (rrskypecall.skin), it doesn't load rrskype_video.skin.
So there's no option to embed just video screen? Embeding whole Skype video window doesn't look so nice.
Old 09-30-2009, 06:20 PM   #54
lambosprit's Avatar
does your rrskypecall.skin close when you answer the call? The plugin tries to open the video skin using menu again (but only when in a call not when ringing) so I guess you can't open two menus at the same time.
As for embeding just the video screen I couldn't find a way. Skype only shows the video in its own screen so thats what I embeded. If you click on it though it goes full screen.
Old 10-01-2009, 01:25 AM   #55
rrskypecall.skin doesn't close when I answer but that is good because I have to end call as well, so if I wanna close it I just use mobilephone_pickup||exit that should work, right?
Old 10-01-2009, 09:58 AM   #56
lambosprit's Avatar
that's how I do it in the flash skins then you can modify the video skin to include a finish call button
Old 10-23-2009, 08:57 AM   #57
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Smile
Hi lambosprit,
I have found a little error in your readme.txt file :
Code:
Carwings: Goto line 77 of the Exectlb.ini file in the carwings folder. Choose one of the empty MyAppXX to use (usually MyApp22 is free) and change it to "MyAppxx","LOAD:RRSKYPE.skin" (usually MyApp22 is free so it would be "MyApp22","LOAD:RRSKYPE.skin"). Now look at line 75 and change the details to give a name to your chosen MyApp (RRSkype would be good). Now open carwings and pick a button to use. Keep it clicked down until the app chooser skin is shown. Then find the app name you used earlier i.e. RRSkype and select.
I think that LOAD:RRSKYPE.skin must to be replaced by LOAD;RRSKYPE.skin
I have make a Skype skin for the Carwings_Dynamic_lite skin .
It is not perfect , surely . If somebody want to test it and give me feed back ?
pierrotm777 is offline   Reply With Quote
Old 10-23-2009, 06:13 PM   #58
lambosprit's Avatar
Quote: Originally Posted by pierrotm777 View Post
Hi lambosprit,
Code:
thanks I'll make that correction and if you dont mind I'll add your skin to the installer.
Old 10-24-2009, 05:10 AM   #59
No problem , but i am not certain that my screen is full or finished .
I think that is it possible to replace the red/green indicator(circle yellow) by the skype indicator on the top (circle red) .
The remainder , in the blue square can to be under the skype logo ?
Do you have tested this screen ? It run well ?
Old 10-24-2009, 06:44 PM   #60
lambosprit's Avatar
That would look good
They are from the mobilephone.net screen and no function in RRSkype so you could delete them.
I haven't as I have mine setup for freedom ultimate. I'm sure others will comment.
Have you had any success with the video calls? It looks really cool in the car
Error: The requested action with this object has failed. EricE RR Skins 13 05-28-2009 04:18 PM
Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you) mitchjs Road Runner 63 03-10-2009 08:49 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 09:26 PM
