Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-25-2009, 04:59 AM   #61
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Quote: Originally Posted by lambosprit View Post
That would look good
They are from the mobilephone.net screen and no function in RRSkype so you could delete them.
I haven't as I have mine setup for freedom ultimate. I'm sure others will comment.
Have you had any success with the video calls? It looks really cool in the car
Ok , I do that and give you me files for to integrated in your setup .
Are you on xp or vista,because GoogleTraffic has an embedded problem in xp , not on vista
pierrotm777 is offline   Reply With Quote
Old 10-26-2009, 09:36 AM   #62
I don't know why , but RRSkype don't run in my pc .
I have just installed skype and registered the plugin , but nothing ...
Carwins_Dynamic_lite RRSkype screen:
Please test again this screen and add to your setup .
Old 10-26-2009, 01:01 PM   #63
lambosprit's Avatar
lambosprit is on a distinguished road
Has carwings lite got the plugin manager? If so check its showing correctly there.
If it is look in the log file to see if the problems obvious. Remember you have to set the debug level to 5 to get all the output.
It is most unlikely to be your skin. More probably the plugin didn't register properly or you haven't setup your skype correctly.
lambosprit is offline   Reply With Quote
Old 10-26-2009, 01:07 PM   #64
In skype , i have just create a login and a password .
For the plugin , I have just used the setup .
In the plugin manager , i see well rrskype .
Old 10-26-2009, 01:10 PM   #65
lambosprit's Avatar
and the log file?
Old 11-14-2009, 04:05 PM   #66
RipplingHurst's Avatar
RipplingHurst will become famous soon enough
I've set debut=5, but where is the debug file saved?
I'm using carwings skin, windows7, latest skype (4.1.0.179), I'm online. I've used the following commands:
regsvr32 skype4com.dll
cd c:\windows\Microsoft.NET\Framework\v2.0.50727
Regasm "C:\Program Files\RideRunner\Plugins\RRSkype\RRSkype.dll" /tlb:RRSkype.tlb /codebase
Everything was registered okay. But my contact list is not populated, my username does not appear on the main screen, etc.
Worklog - 07 Infiniti Fx35 Carputer
Worklog – 06 Infiniti M35 Carputer (sold!)
RipplingHurst is offline   Reply With Quote
Old 11-14-2009, 04:20 PM   #67
Of course I've found it. It contains this:
11/14/2009 13:13:51:Info : Starting RRSkype version: 1.5.3557.39421
11/14/2009 13:13:51:Info : Debug level set to 5
11/14/2009 13:13:51:Info : Auto answer set to 10
11/14/2009 13:13:51:Info : Receive video: False
11/14/2009 13:13:51:Info : Send video: False
11/14/2009 13:13:51ebug : Client running: True
11/14/2009 13:13:51ebug : New Skype connection status: conOnline
11/14/2009 13:13:51ebug : Friend Echo / Sound Test Service loaded
11/14/2009 13:13:51ebug : Friend xxxxxxxx loaded
11/14/2009 13:13:51ebug : Loaded 2 friends into array
But I cannot select friend xxx to call. All I see is this (first pic).
Then, after clicking PC, MEM and Last, I see this. (BTW, what PC, MEM and SIM mean?) the following lines are added to the debug and I see the 2nd screen:
11/14/2009 13:21:45ebug : Active chats array loaded
11/14/2009 13:21:49ebug : Missed calls array loaded 0 calls
Old 11-16-2009, 11:29 AM   #68
lambosprit's Avatar
Looks like you're using pierre's skin for carwings_dynamic. I haven't tested this my self but it looks from the first pic that you're not actually connected. The second pic shows you are connected and that the friend echo/sound has been selected.
The PC/MEM and SIM refer to the mobilephone skin that this skin is based on. They should be changed to contacts, missed_calls , chats and sms_list.
Let me have a look at this skin and get back to you
edit. Had a look at the skin. You need to click on the button marked PC. It loads your contacts. you should then see all your contacts in the list box.
check the first of the dots at the top of the screen (under the skype logo) is green. That tells you that rrskype is loaded correctly.
the second dot tells you if your skype user is on line. It should be green.
the third dot should show a skype status symbol. When you select a contact it should change to show the users status.
I've changed Pierre's skin file so it should show the correct text now for each of the buttons. note though that some buttons dont do anything and have no text now.
edit : edited skin file now attached
Old 11-16-2009, 01:42 PM   #69
Oh, thanks. So I always have to click PC? Okay. The modded skin file is on Pierre's thread or on your first post here? I'll look for it, thanks!
Edit: I couldn't find it. In both places, same file, from 11/5/2009?
Old 11-18-2009, 10:09 AM   #70
lambosprit's Avatar
sorry about that. Forgot I can't upload straight skin files. I've added it to the previuos post
Old 11-19-2009, 12:48 PM   #71
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
Hi lamb , i have just started to add this to Ranger , and testing as i do , now i have someone with skype to test with lol...
so far i have a few request and problems , if you be so kind.
1= my timezone label seems not to be working correct , if i use echo 123 its -24, when i'm talking to another contact , it says 2.
2= the auto messege you have running , its a real pain, i understand why , like you i'm in the UK , so i do understand , but can we come up with a ini setting to switch off, or may be more to your liking , use GPS signal , like Blues GPSlockout PI, your plugin see's that gps is running shuts the function off, when car is not moving switches the function on.
3= can i have a ind for in-call please as well as the label you already have.
4= an ini option to start skype app on rr start or not , as you will be aware here the dongles are step graded to what you pay monthly , i'm on limted time at the moment and having skype start every time i start RR will eat my credit away, also a button to start skype app , after RR has started.
thankyou thats it for now ..
ENJOY
Edit : forgot , for some reason the cl list is only showing the top contact from skype's contact box , any ideas.
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 11-19-2009, 01:46 PM   #72
I have updated your skin in the Add Ons thread !
Error: The requested action with this object has failed. EricE RR Skins 13 05-28-2009 04:18 PM
Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you) mitchjs Road Runner 63 03-10-2009 08:49 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 09:26 PM
