08-13-2009, 02:13 PM
#136
Terminal flasher
Quote: Originally Posted by carputer1
1st problem sonics , started fresh un-reg dll deleted file and skin , replaced with what was in download, got the dialog popup up hit next error , asks for numosk.skin
so your skin doesnt have a numosk.skin? thats just for the timer data entry.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
08-13-2009, 02:15 PM
#137
THE EXPERIMENTER
and i'll put my hands up here to , in test skin copy your backgroundpath= from your skin.ini of a working skin and add it to the RRVM test skin ,skin.ini
sorry guys oooop's
08-13-2009, 02:20 PM
#138
Terminal flasher
Doh! i forgot your skin is MY skin lol.. i'll add the numosk from carwings
03 Acura RSX Coupe
08-13-2009, 02:22 PM
#139
Super Moderator
Quote: Originally Posted by Sonicxtacy02
lol john your KILLING me here  . You wanted the fuel entry as streamlined as possible but you want me to add back an entry that was redundant lol.
Streamlining is one thing, but removing something was not what I meant
I think updating the Odo at fill up's is a great way to make sure that the plugin is as accurate as possible with fuel mileage ect. Entering in fuel, and not having a correct odo reading is gonna throw things way off fast.
Maybe in the future you can have an option to get the mileage from the OBDMPG plugin. This would keep your odo accurate with the car. Not that it would help me, my current Fiero Project would be no good, as it doesn't have ODBII!
08-13-2009, 02:24 PM
#140
Terminal flasher
yea you're right.. i took your advice and thats in there
03 Acura RSX Coupe
08-13-2009, 02:26 PM
#141
THE EXPERIMENTER
while your at sonics ,open the test skin's skin.ini add this
backgroundpath=
and drop a background image in the skin file and add the name of the image to the path
08-13-2009, 02:30 PM
#142
Terminal flasher
tried that.. didnt change the background though.
Code:
03 Acura RSX Coupe
08-13-2009, 02:32 PM
#143
THE EXPERIMENTER
works here , it should work thats how rr carwings dose it it looks for image if none then black
08-13-2009, 02:37 PM
#144
Terminal flasher
its probably a me only problem considering i've had other problems with backgrounds in the past.. but look
regardless the link has been updated with your request
03 Acura RSX Coupe
08-13-2009, 02:47 PM
#145
Super Moderator
I just installed the new version, and no longer see cost per mile go up when I click in the Maintenance button
Now.... your probably not gonna like me... sorry.
But.... can there be at least an option to use the NumOSK for the fuel data entry? I would try to work around it, but your fuel entry button is a command that internally opens the NumOsk. If you can give me any internal commands that I can use for a work around that would even be great!
The numbers are much larger, and it is much easier to enter the numbers fast with the NumOSK -vs- the full OSK.
I already spent a couple hours building a new OSK, that is now no longer needed. I also created a new NumOSK with a nice large label area at the top for the instructions, I am hoping to be able to use it
Also, on the fuel screen in the original BMV2 skin that is used to clear the fuel data. It is doing nothing that I can tell.
08-13-2009, 02:53 PM
#146
Terminal flasher
do you care if its RRVM_numosk.skin? Basically the same thing as RRVM_OSK.skin is now.. an exact copy of numosk with the OSKTITLE label and RRVM_ENTER. If you dont care i can add a check for the rrvm_numosk.skin for fuel entry if its detected.
the clear button does nothing at this time... in the event i add it later its already in the demo skin.
03 Acura RSX Coupe
08-13-2009, 02:57 PM
#147
Super Moderator
Thats fine, as you mentioned one more skin in this beast is not going to hurt anything
Ok, couple things I noticed....
I added a recurring repair for an air filter. I told it 365 days, and 12 months. After completing it, it said I had 361 days remaining. Not that 4 days is a big deal, just something was not adding up somewhere.
I then highlighted the air filter, and reset it, got the confirm to reset and did. Now it says it has been 61,200 miles since I replaced it
08-13-2009, 03:18 PM
#148
Terminal flasher
num_osk request is added
here's my code for that the time remaining label
Code:
Case "rrvm_timeremaining"
ReturnLabel = Math.Round(MaintenanceArrayCheck(ItemSelected, 2) - TimeCounter(ItemSelected), 0, MidpointRounding.AwayFromZero)
MaintenanceArrayCheck(ItemSelected,2) is your time interval as read from maintenance tracker.ini
TimeCounter(ItemSelected) is #TimeCount from maintenance tracker.ini
Let me see those your maintenance tracker if you dont mind.. maybe the numbers got recorded funny or something.
I'll solve the mileage thing after we fix this
03 Acura RSX Coupe
08-13-2009, 03:25 PM
#149
Terminal flasher
doh i see a problem with that calculation.. but i'm not sure its gonna solve your issue. stay tuned!
03 Acura RSX Coupe
08-13-2009, 03:29 PM
#150
Super Moderator
Here is my MaintenanceTracker.ini:
[Main]
TotalDistance=62500
LastDate=8/13/2009
WaypointMiles=
FirstRun=1
[MileageInterval]
1LastDoneMiles=65000
2LastDoneMiles=62500
[TimeInterval]
1TimeCount=4
2TimeCount=0
[MaintenanceItems]
Maintenance1=Oil Change;3000;90;24.95;Use WD 30
Maintenance2=Air Filter;12000;365;24.95;Use KDE-2145 Filter
When I go into history, and select the air filter it is showing the 65500. It seems to be pulling the total distance for the value when an item is reset.
Just to make sure I don't have the label in the wrong place I am using "RRVM_HISTORYMILEAGE"
| Thread Tools |
| Display Modes |
Linear Mode
