Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-13-2009, 03:36 PM   #151
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
yup... i see the issue i messed up the array count. Hold off on downloading peeps
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 08-13-2009, 03:50 PM   #152
Terminal flasher
fixed the time issue.. i'm moving onto the mileage calculation
03 Acura RSX Coupe
Old 08-13-2009, 03:59 PM   #153
Terminal flasher
I'm trying to research this problem and i'm a little confused.. your current TOTALDISTANCE label is 62500...but the history item says 65500 ? RRVM_HISTORYMILEAGE is supposed to say at what mileage the selected history item was completed... so if you reset a maintenance item at 62500 that number is written to history.csv. 65500 would make no sense
Quote: Originally Posted by JohnWPB View Post
Here is my MaintenanceTracker.ini:
[Main]
TotalDistance=62500
LastDate=8/13/2009
WaypointMiles=
FirstRun=1
[MileageInterval]
1LastDoneMiles=65000
2LastDoneMiles=62500
[TimeInterval]
1TimeCount=4
2TimeCount=0
[MaintenanceItems]
Maintenance1=Oil Change;3000;90;24.95;Use WD 30
Maintenance2=Air Filter;12000;365;24.95;Use KDE-2145 Filter
When I go into history, and select the air filter it is showing the 65500. It seems to be pulling the total distance for the value when an item is reset.
Just to make sure I don't have the label in the wrong place I am using "RRVM_HISTORYMILEAGE"
03 Acura RSX Coupe
Old 08-13-2009, 04:46 PM   #154
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Yea it was 62500, sorry. I thought that label was to show how many miles left. I have gotten confused with the 3 different screens, and what labels are for what. My bad.
I am on Yahoo as usual, if ya wanna chat when you get home. JohnWPBFL
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 08-13-2009, 04:51 PM   #155
Terminal flasher
i've got the latest fix with the days remaining label fixed and uploaded.
I'll shoot you a message from yahoo tonight to see if anything else is hanging. I'll have to remember what my yahoo id is though lol
03 Acura RSX Coupe
Old 08-14-2009, 03:38 AM   #156
Super Moderator
JohnWPB's Avatar
Its the addy you use for HM
Sorry, I was out most of the evening after all, just was checking the forums b4 hitting the sack.
Old 08-14-2009, 04:08 PM   #157
barnyard is an unknown quantity at this point
Man, this would be great if I could use it! I hacked into my Onstar GPS, and this has worked great for getting from point A to point B for 3 or 4 years now. The problem is, from time to time it'll throw out some bogus information. On the gauges screen in DFX I've noticed from time to time the location it says is hundreds of miles from where I actually am. At the same time, the speed readout pegs @ around 5500 MPH. It's apparently doing it more often than I originally thought.
This is my Maintenance Tracker.ini:
Code:
[Main] TotalDistance=1020039.35091913 LastDate=8/14/2009 WaypointMiles= FirstRun=1 [MileageInterval] 1LastDoneMiles=117597 2LastDoneMiles=117597 3LastDoneMiles=117597 4LastDoneMiles=100649 5LastDoneMiles=100649 6LastDoneMiles=53410 [TimeInterval] 1TimeCount=80 2TimeCount=80 3TimeCount=391 4TimeCount=889 5TimeCount=889 6TimeCount=1945 [MaintenanceItems] Maintenance1=Oil Change;15000;365;45; Maintenance2=Tires Rotated;7500;60;0; Maintenance3=Fuel filter changed;15000;365;20; Maintenance4=Radiator Flush & Fill;75000;365;70; Maintenance5=Rear Differential Service;7500;365;20; Maintenance6=Transmission service;50000;600;60;
I had 138765 miles when I started this morning, now I'm over a million!
I don't guess there's any way for the plugin to ignore anything that is obviously impossible distances? If is not easy to fix, don't worry about it. I guess I can get another GPS receiver down the road.
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is online now   Reply With Quote
Old 08-14-2009, 04:17 PM   #158
Terminal flasher
lol did your GPS throw you off the planet or something? I guess if you had a bad connection and the gps returned a bad set of coordinates this could happen. Never thought of it honestly. It would be easy to add a kickout that would calculate the difference in coordinates and throw out impossible numbers. Say... any distance that would indicate than your travelled speed being more than 160mph
03 Acura RSX Coupe
Old 08-14-2009, 04:25 PM   #159
That's kinda what I was thinking.... the truck has a 100MPH speed limiter anyway! If it's not to hard to do I'd appreciate it!
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
Old 08-14-2009, 07:21 PM   #160
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
In a nutshell.... the same feature as the old milage plugin had if the calc'd distance is > than setting specified for the plug in it doesn't add that to the total acc milage.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 08-14-2009, 10:11 PM   #161
Super Moderator
JohnWPB's Avatar
I am not sure, but if this could be added into RR, I think THIS would work for you.
Old 08-15-2009, 03:31 AM   #162
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
looks like i'm dead in the water with this plugin now.
got put into profile mode last night, and now this plugin won't work, i can't even regiester it. ran the install.bat a few times and rrdebug says its not reg'ed and getting skipped on load,
any ideas guys i need to finish skinning it lol...
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 08-15-2009, 06:15 AM   #163
Terminal flasher
and profile mode is what again?
03 Acura RSX Coupe
Old 08-15-2009, 06:25 AM   #164
THE EXPERIMENTER
carputer1's Avatar
if i'm right about this ,its when rr ini's and plugin temp files are saved to my documents , not program files, but the plugins folder is still in program files, but i don't think thats the issue , for some reason the plugin is no longer reg'ed and i can't reg it again, maybe when you release the next update it may work again, i think the new plugin code rulles state about useing my documents for temp files not sure , blue ,Guino, or mitch would be able to explain better
Links
Old 08-15-2009, 06:48 AM   #165
Terminal flasher
oh... that lol. I guess i'm just a rebel here.. or dont feel like working on something thats pointless in my mind... but unless i'm absolutely bored out of my mind i'm not gonna take the time to worry about profile mode .
the plugin will register just fine it just crashes if it doesnt detect the required files before creating the COM object. Thats why RR tells you its most likely not registered
03 Acura RSX Coupe
Error: The requested action with this object has failed. EricE RR Skins 13 05-28-2009 04:18 PM
Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you) mitchjs Road Runner 63 03-10-2009 08:49 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 09:26 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
