Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-30-2009, 11:10 AM   #346
barnyard is an unknown quantity at this point
That is beyond cool! I just set up the new version (on my desktop using a backup of my logs) A few minutes later, I get an email with the report! Great work Sonic!!!!
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is offline   Reply With Quote
Old 10-30-2009, 05:19 PM   #347
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
I am getting inconsistant reports for some reason....
The first time I ran it, it showed the maintenance items and repairs, and the fuel log showed nothing. (I had 3 fuel up's in the tracker).
I added another fuel, sent the report, and all that was in the report was just the fuel table, and nothing else.
I added another repair, and got the report, but this time as attachments..
I copied the empty logs from the .rar over my logs to start from scratch. I entered a maintenance item, a repair, and a fuel up and this time it came through as all this time as attachments to download from Gmail.
I sent the log again, and this time came through with the top section and the maintenance section, no repairs or fuel.....
I can't seem to find a pattern as of yet, but will keep playing and see if I can come up with something.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 10-30-2009, 05:47 PM   #348
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
beats me... i'm only programatically sending the email one way... doesnt make sense that the email would be sent different ways each time its sent. If the files are open and not available to RRVM it could cause a problem i spose. The only attachment i'm sending programatically is the vehicle.jpg. For fuel and repair log if they have any spaces or linefeeds i could see that throwing everything outta wack too.... but the maintenance tracker should be sent everytime all the time because i'm not reading a file, i'm using the data i've already got.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 11-01-2009, 03:18 PM   #349
boelle is an unknown quantity at this point
dont know if this one has been asked and answered before... but the "ding" sound created by RRVM.. is that solved? i still get it but has not updated to this new release, but since my carpc is going to have permanent internet it makes sense to have a reminder at home in the mail
boelle is offline   Reply With Quote
Old 11-01-2009, 03:20 PM   #350
Terminal flasher
is what solved? The ding is still there... tho you should never hear it unless you have maintenance that needs to be done. The new release dings and sends email if you have internet. If you wish not to hear the ding replace rrvm.wav with a silent .wav file
03 Acura RSX Coupe
Old 11-01-2009, 03:23 PM   #351
i get it at almost the same interval.. as soon i reg the dll i get it... if an item is due should there be a pop up? i dont get one
Old 11-01-2009, 03:30 PM   #352
Terminal flasher
i still dont know what you're talking about. The ding should only occur if you have maintenance items in the alert phase. It should only happen ONCE daily.. very soon after rr has been started. There is no pop up when maintenance is due.. there is:
-the audible DING
-the email is sent
-ONCHECKMAINTENANCE event is done... you can use this even in exectbl.ini to create a popup or do whatever you want inside of RR when the maintenance item is deteceted as due
03 Acura RSX Coupe
Old 11-01-2009, 03:38 PM   #353
i just get a ding every few minutes... and together with carputer i tracked it to coming from RRVM
and i tried to unreg RRVM and the ding stopped... but i will try to replace the soundfile with another to make an extra check
Old 11-01-2009, 03:41 PM   #354
did an search for rrvm.wav on the entire drive (only have one) no rrvm.wav anywhere
Old 11-01-2009, 04:30 PM   #355
Super Moderator
JohnWPB's Avatar
Its gonna be very hard to find actually... as the sound is like a cheapie digital watch, and its usually hard to tell where the sound is coming from
Old 11-01-2009, 04:33 PM   #356
Terminal flasher
ok.. number 1.. use the LATEST version... i cant troubleshoot if you're using something old. Secondly, you're not telling me if you actually have a maintenance item due. If you dont, there's nothing programatically that can make the .wav file play. If you DO have a maintenance item due... do the maintenance, and reset the maintenance item.
maybe RRVM.wav isnt the filename.. but there is a .wav file.. somewhere in the sample skin folder that you can replace. you could probably delete it but i dont remember for sure if i'm doing a file check.
03 Acura RSX Coupe
Old 11-01-2009, 05:25 PM   #357
will check out first thing in the morning and report back....
Old 11-01-2009, 06:06 PM   #358
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
I too can say that the reminder sound(rrvm.wav) plays ~once every 2mins! Until I just got my oil changed and reset the that item, I heard it/put up with listening to it to/from work...
It clearly does NOT just play once per day....FYI
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 11-01-2009, 06:12 PM   #359
Terminal flasher
I stand corrected.. the ding will occur on the specified timer interval until RRVM_DISMISS is run. Consequently, you can put "RRVM_ONCHECKMAINTENANCE","RRVM_DISMISS" in exectbl.ini and this will stop the ding after 1 go round.
03 Acura RSX Coupe
Old 11-18-2009, 10:26 PM   #360
Hey Sonic,
I haven't been able to send a report in quite some time. I've tried it on 3 different computers, and 3 separate internet connections. I get the attached popup when the report tries to send. Could we possibly set it up with our own SMTP information to fix the problem?
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
Error: The requested action with this object has failed. EricE RR Skins 13 05-28-2009 04:18 PM
Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you) mitchjs Road Runner 63 03-10-2009 08:49 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 09:26 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
