Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 07-08-2009, 10:26 AM   #61
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Quote: Originally Posted by spamminator View Post
Hmmm....can we ever specify the date on maintenance items? Like, can I enter in that I got an oil change 2 months ago at 110000 miles, or is it just going to take the current date and mileage whenever I add anything new? Can we at least add items manually to the .ini file and have them show up at the right dates/mileage?
nope.. cant specify thru RR the date for anything. There's just no clean way to handle it now. You can enter the data into the .ini and the new .csv manually however and that should work.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 07-08-2009, 10:33 AM   #62
spamminator is an unknown quantity at this point
I think it should be possible if you just specify a format for the date when you enter it: MM/DD/YYYY or whatever. I know that a large part of the world uses DD/MM/YYYY, so whichever one you pick. If the user doesn't conform then it's their own fault. Ideally I'd like to be able to enter in the name of the maintenance item, the date it was done, and the mileage it was done at for each new item, and then have the plugin do all the math.
spamminator is offline   Reply With Quote
Old 07-08-2009, 10:37 AM   #63
Terminal flasher
never said it wasnt possible.. its just a pain in the butt. that would require no less than 3 numosk's along with 3 popup screens telling you what each numosk is for. That puts the number of steps to add a maintenance item at 12. Is it really work THAT many screens to change the date when it would take half the screens to add the information on or around the date the maintenance item needs to be added? I'll have to post a video to show what i mean.
03 Acura RSX Coupe
Old 07-08-2009, 10:50 AM   #64
I'm saying just use 1 screen and maybe a custom numOSK that has a "/" key. Then the 1 pop-up say: Enter the date in MM/DD/YYYY format, and it's up to the user to enter it correctly.
Old 07-08-2009, 12:34 PM   #65
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
what about useing RRext cmds like textboxtovar, i use this to enter times ,lon/lat,daylight save all from 1 popup,saves aload of NUMOSK being used all us skinners have to do is make sure the relevant keys are on the said popup,,, or if your worried about the amount of skins just give us the ini save , and we can use what ever cmd we need weather its from rrext or rr its self to complete the task.
carputer1 is online now   Reply With Quote
Old 07-08-2009, 01:30 PM   #66
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Calling sonic... I do still have that idea that i mentioned a few posts ago, that might also be a nice addition, and will probably in the end add it to RRExtended...
Its a "DateOSK" function and is pretty slick I think, its only one additional skin file and you can enter all date info w/o ever leaving the screen...
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 07-08-2009, 02:31 PM   #67
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
It's a shame there isn't a Calendar plugin that could pull up , well a calender, and you just click on the day and will then take that as a date input.
Enforcer is offline   Reply With Quote
Old 07-08-2009, 02:33 PM   #68
THE EXPERIMENTER
carputer1's Avatar
is that a hint at Blue there lol...
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
Old 07-08-2009, 02:47 PM   #69
Terminal flasher
that would work just great! Nice clean way to do it
that was the way i initially tested it.. and it worked well.. just didnt make sense to make my plugin depend on RRSched and since blue's busy with nearly everything else there wasnt a need for me to bug him about it
03 Acura RSX Coupe
Old 07-08-2009, 03:01 PM   #70
Confusion Master
Enforcer's Avatar
Would I do such a thing?
Old 07-09-2009, 06:15 PM   #71
The Curator
Blue ZX3's Avatar
Now that sonic has both seen my DateOSK and code to handle anything else in the same manner....good things can only come from this...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 07-09-2009, 07:13 PM   #72
Terminal flasher
Yes.. thank to blue you will now be able to set your date if you have RRExtended loaded. If not, it will automatically default to "today". There will also be HALF the pop ups thanks to a portion of the code he shared with me.
I really needa start payin you man
03 Acura RSX Coupe
Old 07-21-2009, 04:20 PM   #73
Are we close to a beta release?
Old 08-03-2009, 06:23 PM   #74
boelle is an unknown quantity at this point
yeah.... me want this too
boelle is offline   Reply With Quote
Old 08-04-2009, 10:45 AM   #75
Terminal flasher
Plugin is certainly not dead i just got caught up in programming for my blackberry. I've found some bugs in RRVM over the last week or so that should be easy to fix... then i've got to start the "history" skins and commands because right now i have NONE of that done. Should i release a beta before going there or wait til after?
03 Acura RSX Coupe
Error: The requested action with this object has failed. EricE RR Skins 13 05-28-2009 04:18 PM
Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you) mitchjs Road Runner 63 03-10-2009 08:49 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 09:26 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
