Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-11-2009, 02:30 PM   #121
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
Quote: Originally Posted by Sonicxtacy02 View Post
There's no more key lag john.
I think hes pointing a finger at you lol...
also sonics i see a error in the font color in the txt box
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 08-11-2009, 04:11 PM   #122
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
yea i'm not sure whats goin on there i simply copied the carwings osk.skin into your skin then added the label and enter button.
The fuel data entry is now just 2 steps . Dont ask me why the old version had me requesting the odometer reading when i already have the total distance label
the last thing i need to do is figure out the total cost average calculation error john mentioned. that might take some time tho cause i suck at math!
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 08-11-2009, 09:15 PM   #123
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Sounds good... If I may make a suggestion though... hahahah!
I would leave the odometer entry in there, and propagate it from the value in the plugin so it shows when the OSK is loaded for entry. If it is correct, just press enter to accept it. More than likely it is going to be off just a bit from GPS skipping out, not starting soon as you start to drive ect. This way the Odometer would be updated and calibrated at each fill up. Which basically does the proverbial killing two birds with one stone thing
I am not sure why actually you are using a separate keyboard, as I use the OSKTOVAR command to get information using the standard RR OSK.
Here is an example from my YouTube skin, that uses the OSK to get the path where you want the video saved, then saves it to the skin.ini and changes the variable in memory:
PHP Code:
"YT_SETPATH"," ||OSKTOCMD;YTPATH;YT_SAVETOSKIN"
"YT_SAVETOSKIN"
,"SAVETOSKIN;ytsavein;$YTPATH$||SETVAR;ytsavein;$YTPATH$"
You can not concat the command with the ||, thus the 2nd line is needed to actually run all the commands
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 08-11-2009, 09:31 PM   #124
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
John seems to like to
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 08-12-2009, 01:49 AM   #125
THE EXPERIMENTER
carputer1's Avatar
mmmmm strange open the osk skin file up and change these 2 lines it will change the font to yellow like the rest of the skin
T01,15,109,771,40,255,255,0,40,0,0,22,"Arial Narrow","Country"
L,17,86,750,22,255,255,0,18,"Arial","RRVM_OSKTITLE ","LEFT"
Links
Old 08-12-2009, 09:34 AM   #126
Terminal flasher
lol john your KILLING me here. You wanted the fuel entry as streamlined as possible but you want me to add back an entry that was redundant lol. If you really wanted to add a check before fuel entry you could set a var when RRVM_EDITTOTALDISTANCE is launched then check that var when adding fuel... Then just run a byvar either instructing someone to update the odometer or continue to add fuel.
Now the osk thing comes back to the point that i'm using the data as soon as its entered.. and it doesnt make sense to have my plugin wait for the data to be sent through RR queue before i have access to it. If the data entered is in an invalid format my plugin clears the text area and makes the OSKTITLE label blink to indicate the value must be entered again. Its only going to slow the process down if the data ONLY the plugin uses has to wait for RR to feed the plugin the data. C'mon man you have a million .skin files in that masterpiece of yours whats one more osk gonna hurt
03 Acura RSX Coupe
Old 08-12-2009, 09:40 AM   #127
Terminal flasher
got it.. thanks
03 Acura RSX Coupe
Old 08-12-2009, 04:37 PM   #128
Terminal flasher
woo hoo figured out the total cost per mile bug. I wasn't resetting the holding variable so the calculation was basically doubling every time it was made. I've also given some thought to what john mentioned about adding back odometer to the fuel data entry... it does make sense in the long run. If nothing else comes up before tomorrow we just might have ourselves a beta release
03 Acura RSX Coupe
Old 08-13-2009, 01:18 PM   #129
Terminal flasher
Check post 1
03 Acura RSX Coupe
Old 08-13-2009, 01:27 PM   #130
barnyard is an unknown quantity at this point
It may be me, but the link isn't working. I end up with a 38k .rar file, that won't open. I'm using Avast antivirus, so i tried disabling that, but it still does the same thing.
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is offline   Reply With Quote
Old 08-13-2009, 01:29 PM   #131
Terminal flasher
hmm just tried to download it and it worked for me. Should be a 2.6mb .rar file. Maybe your connection dropped during the download.
03 Acura RSX Coupe
Old 08-13-2009, 01:46 PM   #132
THE EXPERIMENTER
carputer1's Avatar
at last a offical release .lol... no problems with the link 6 sec's to download.
Links
Old 08-13-2009, 01:56 PM   #133
I've tried it several times with Firefox & IE. I'll try again when I get back from my interview.
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
Old 08-13-2009, 02:03 PM   #134
THE EXPERIMENTER
carputer1's Avatar
1st problem sonics , started fresh un-reg dll deleted file and skin , replaced with what was in download, got the dialog popup up hit next error , asks for numosk.skin
Links
Old 08-13-2009, 02:10 PM   #135
Terminal flasher
andddddd just that fast i remembered something i forgot to add... RRVM_DISMISS! It will dismiss the indicator and on_checkmaintenance event until rr is restarted/resumed. Anyone downloading before 2:09ET needs to redownload!
03 Acura RSX Coupe
Error: The requested action with this object has failed. EricE RR Skins 13 05-28-2009 04:18 PM
Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you) mitchjs Road Runner 63 03-10-2009 08:49 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 09:26 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
