Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-10-2009, 06:37 PM   #16
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Looks like I'll have to pull out my Vista VM then and take a look....
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-10-2009, 11:22 PM   #17
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by carputer1 View Post
i think either skinners should release this with their skins default , or rr releases as default, and its down to the user to de-activate, at least the authors of skins or rr are covered. and done their bit.
its not like its hard to de-activate is it now
This is EXACTLY what I have done with the DFX skins in the past. I enable it by default, it is up to the user to deactivate it. I personally want to think that I had nothing whatsoever to do if someone was watching video in the car and got either a ticket, or God forbid, into an accident.
And on top of that, in this day and age, I do not want to be open for a lawsuit.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 10-11-2009, 09:14 AM   #18
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Not run for me
Hi Blue,
I try gpslockout in xp (tried also in vista) who don't run .
The .ini file must to be on rr path like motionlock or in gpslockout folder ?
It is well loaded but when i use my video_player . I see my video .
i upload my debug file .
thanks
pierrotm777 is offline   Reply With Quote
Old 10-11-2009, 10:41 AM   #19
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Post your GpsLockout.ini file as well.
Enforcer is online now   Reply With Quote
Old 10-11-2009, 10:48 AM   #20
Code:
############################################################################################### # # Settings Explained: # # Speed --------------- the max speed consider as 'stationary' - anything over that and access # to the configured commands/skins is blocked # cmds --------------- a list of commands to block while moving, space seperated # skins --------------- a list of skins to block, space seperated again # DisableScreen ------- the screen to call when above speed limit setting # # * To test, set speed to -1 # ################################################################################################ [Settings] Speed=3 cmds=dvd video skins=external_DVD.skin video_player.skin windvd_player.skin DisableScreen=gpslockout_denied.skin
Old 10-11-2009, 11:01 AM   #21
Confusion Master
Enforcer's Avatar
1. have you tried setting the speed to -1 to test, as the instructions say? If not try that.
2. have you set RR's GPSport up to receive NMEA data from your GPS Mouse? If not, then try that.
Old 10-11-2009, 11:23 AM   #22
1 . Yes i have tried -1 and have the same issu.
2 . My gps is not a gps mouse but gpsgate with virtual com port
Old 10-11-2009, 12:44 PM   #23
Confusion Master
Enforcer's Avatar
If it's not working with -1 then there is definitely an issue with the plugin or where the settings file is.
Old 10-12-2009, 12:32 AM   #24
Super Moderator
JohnWPB's Avatar
It must be something internal to the plugin. It is not something as to where the settings file is located, as that is exactly what the installer is for. To ensure that files are put where they are supposed to be, and registered if necessary. This takes all guesswork out of where files are placed and if they are registered correctly, thus narrowing down the debugging process. This alleviates all the initial posts in a thread like: "Did you put the file in xx directory?", "Did you register the file?", "Register, how do I do that" and so forth....
Old 10-12-2009, 07:30 AM   #25
Confusion Master
Enforcer's Avatar
I was trying to avoid saying it was definitely the plugin at fault
Maybe it's an issue with commas and fullstops and decimal points again.
Old 10-12-2009, 08:01 AM   #26
The Curator
Blue ZX3's Avatar
Comma=NO
fullstops=?
decimal=I dont believe so
I will make a special debuging dll latter tonight and PM pierrotm777 bout the details
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-12-2009, 01:15 PM   #27
Quote: Originally Posted by Blue ZX3 View Post
Comma=NO
fullstops=?
Thanks Blue .
Old 10-15-2009, 01:45 PM   #28
The Curator
Blue ZX3's Avatar
Have found two issues, after pierrotm777 gets done testing the next updated dll and all is good, I will update the installer..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-16-2009, 02:36 PM   #29
The last dll given by Blue for test is GENIAL!!! .
Old 10-16-2009, 08:42 PM   #30
The Curator
Blue ZX3's Avatar
I have updated the installer with the newest dll build, I did find two errors.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Tags
disable screen, gps, motionlock
Skype Plugin released lambosprit RR Released Plugins 71 11-19-2009 01:46 PM
Ranger Released 30/08/09 carputer1 RR Released Skins 72 10-16-2009 05:51 PM
Teknik v2.0 - RELEASED Valheru RR Skins 0 12-04-2007 11:22 AM
New Lilliput drivers released! RS200Z LCD/Display 1 06-07-2006 10:57 PM
