Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-06-2009, 01:08 PM   #1
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
GpsLockout [ UPDATED 10/16/09 ]
RideRunner Extension Plugin for GpsLockout
General
This is a replacement for the old outdated MotionLock plugin by festy. If you used
the motionlock and changed the default settings then you'll need to transfer them
over to the GpsLockout.ini. There are no 'Mode' or 'DisableScreen' settings.
There are some additional notes for the settings at top of the ini file.
Labels
"GpsLockout_Engaged" - Shows 'Disabled'\'Enabled' depending on GPS speed is above/below
the 'stationary' imit
Indicators
"GpsLockout" - Indicates that the Plugin is Running
"GpsLockout_Engaged" - Indicates that video screens\cmds are locked out
Events
"GpsLockout_ONMotion" - is fired in place of the original issued command if already in motion(moving)
or if on a locked screen when starting to move, will close it then issue event
Included* in the Screens folder is an example screen that you can use. To use, just
copy the files from there into the skin folder that your using.
* screens are from festy's MotionLock plugin
I've added the screens from the carwings skin that were edited by pierrotm777 below.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-06-2009, 02:53 PM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Questions and Requests
Q1. Does this use the same screens and commands as festys.
Q2. Why did you stick this in the wrong forum?
R1. Can you (and I will ask this of other plugin authors) also release it in a non installer version.
Enforcer is offline   Reply With Quote
Old 10-06-2009, 04:17 PM   #3
The Curator
Blue ZX3's Avatar
All done via the ini file, just like festy's.
Er um..b/c it cant be posted in the released one, Duh I'm not a mod!
No, this is the way that PI's are supposed to be released in.
Now i'll answer your req with a req...
That NO plugin authors put make users go thru another forum just to DL it!
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-06-2009, 04:18 PM   #4
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
It was posted there, as it takes a mod to move a plugin to the released plugins section He PM'd me and asked me to move it to the released section.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 10-06-2009, 05:09 PM   #5
Confusion Master
Enforcer's Avatar
Yes, but what .skin files does it use?
Aren't you, I thought you were.
Yes and no.
If I want to be able to skin a plugin, but don't want to actually install it, I need it in a non-installer version.
Old 10-06-2009, 05:20 PM   #6
Super Moderator
JohnWPB's Avatar
It is a VERY simple installer, that just copies the files to [Your RR folder]\Plugins\GPS Lockout. The only skin needed is "gpslockout_denied.skin" or what ever you want to call it actually, as it's set in the ini file. So, yes, you can use the existing skin from Festy's plugin, and nothing is then needed to be skinned if you have that skin in place already.
The list of skins that are not aloud are set in the .ini file:
Quote:
# Settings Explained:
# Speed --------------- the max speed consider as 'stationary' - anything over that and access
# to the configured commands/skins is blocked
# cmds --------------- a list of commands to block while moving, space seperated
# skins --------------- a list of skins to block, space seperated again
# DisableScreen ------- the screen to call when above speed limit setting
# * To test, set speed to -1
[Settings]
Speed=3
cmds=dvd video
skins=external_DVD.skin video_player.skin windvd_player.skin
DisableScreen=gpslockout_denied.skin
Old 10-06-2009, 05:39 PM   #7
Confusion Master
Enforcer's Avatar
However the PC I'm on at the moment doesn't let me install anything. (New PC's at work and I don't have local admin rights. First time EVER )
Old 10-06-2009, 06:57 PM   #8
The Curator
Blue ZX3's Avatar
Probably b/c you SUPPOSED to be doing work, not playing!
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-06-2009, 07:03 PM   #9
Confusion Master
Enforcer's Avatar
And your point exactly?
Old 10-06-2009, 07:17 PM   #10
Raw Wave
mitchjs is on a distinguished road
enforcer, install it on another machine... then u can do what u need to do...
its also handy to have virtual machines
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 10-06-2009, 07:46 PM   #11
Confusion Master
Enforcer's Avatar
Well if I had a scrap machine set up I would, but I don't at the moment.
Besides afetr using Carputer1's skin installer which has caused all my lists to become Italicised I am wary of using installers now.
I prefer to know exactly what is being installed, where it's installed and what changes are being made. The I can make the choice on whether to install it or not.
As for virtual machines, tried that, find them too slow for what I want, need to set up a really big power rig, but never around to doing that.
Old 10-07-2009, 03:03 AM   #12
almera's Avatar
almera is on a distinguished road
You could use an unpacker like innounp, the Inno Setup Unpacker http://innounp.sourceforge.net/
Thanks for the plugin!
almera is offline   Reply With Quote
Old 10-10-2009, 05:22 AM   #13
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
i may be going OTT , as video while driving is mostly Illegal ,in most countrys,
i think either skinners should release this with thier skins default , or rr releases as default, and its down to the user to de-activate, at least the authors of skins or rr are covered. and done thier bit.
its not like its hard to de-activate is it now
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 10-10-2009, 06:21 AM   #14
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Miam Miam Miam
Exactely that i wanted .
Thanks Blue . You are the Best...
I have a motionlock,I have a motionlockIhave a motionlock
pierrotm777 is offline   Reply With Quote
Old 10-10-2009, 06:43 AM   #15
Yes it is very important . I agree also that .
I just tried it and it don't run for me in vista !!!!
Tags
disable screen, gps, motionlock
Skype Plugin released lambosprit RR Released Plugins 71 11-19-2009 01:46 PM
Ranger Released 30/08/09 carputer1 RR Released Skins 72 10-16-2009 05:51 PM
Teknik v2.0 - RELEASED Valheru RR Skins 0 12-04-2007 11:22 AM
New Lilliput drivers released! RS200Z LCD/Display 1 06-07-2006 10:57 PM
