Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-26-2009, 09:15 PM   #1
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
Thumbs up [Final Release Candidate] Overlay Menu - Dragable, Moveable, Flyable, Commandable
Thanks El Camino
First, credit goes to El Camino for creating a fine plugin with enormous capabilities.
This plugin was originally created by El Camino and with his permission I have been able to make some feature additions along with a few other tweaks.
With out further A Do... I bring you...
FLY TO MENU
(Not all features previewed but all do work well)
If you got a better name let me know
Preview is featuring my new skin, New Age - Slider
You tube preview
[Features]
-Drag the menu around with your mouse or touch screen
-Master Volume Wiper (Similar to CF3 song scrubber or a slider)
Can be a horizontal or vertical wiper. Depends on the dimensions when created. A horizontal rectangle creates a horizontal wiper, a vertical rectangle creates a vertical wiper.
-Jump buttons to make the menu jump up, down, left or right to a specific position
-Labels from RR
-RR Button commands sent to RR
-Fly the menu from one position to another (Can fly across the screen and land at a specified position)
-Drage Limits - Set position limitations for top, bottom left and right most positions you want the screen to be moved to. Default is with in the dimensions of the currently displayed RR skin.
-Autopopup - Menu can be moved to a position when commanded then returns to it's origin when a definable timer expires. This feature is good for warnings and menus you want to retract automatically.
-AutoPopUp feature compatible with SpeedZone - Special Feature Un-Released Version as of 10-29-2009
-Multiple Overlay screens at one time. Not sure on how many you can use, but there is no limitation on instances as long as each instance is using a different skin with unique filename.
Feature Requests and Comments are welcome in this thread
RELEASED
-Speed Zone compatibility will require that you use the speedlimit.exe downloadable below.
-Read the FlyToMenu-Commands.TXT for instruction
This is pretty stable I just want some other opinions before I drop a release
ThunderStick is offline   Reply With Quote
Advertisement Sponsored links
Old 10-26-2009, 09:16 PM   #2
One Sharp Cheddar
[Release Notes]
10-29-2009 - First Release,Read FlyToMenu-Commands.TXT for instructions
10-31-2009 - Bug fix - Autopopup not returning to positiion after timer times out,Speed Zone not interfacing correctly
10-31-2009 - PM bug fix - Speed Zone Update label change for alerts
SHOW YOUR STUFF
If using this overlay plugin. Post a screen shot, youtube video or vimeo video to show what you were able to use this for.
Old 10-27-2009, 12:48 AM   #3
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Wow, that is looking killer! Great work on the additions to ElCamino's plugin!
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 10-27-2009, 02:34 AM   #4
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
this is a great addition Thunder , my only concern is CPU , as this plugin origanally did have some CPU issue in some cases ,
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is online now   Reply With Quote
Old 10-27-2009, 03:31 AM   #5
pierrotm777's Avatar
pierrotm777 will become famous soon enough
It is a great idea, this menu stay the screen free and bigger.
Just one word , WONDERFULL
pierrotm777 is offline   Reply With Quote
Old 10-27-2009, 05:00 AM   #6
One Sharp Cheddar
CPU usage is pretty high when moving the menu around, but I have this working in my car now and it works pretty well.
I have a pentium 1.5ghz with 512mb ram in the car so shouldnt be too bad for most. I probably wouldn't recommend less than 1.5ghz and 512mb ram since it is a processor hog when moving the menu around. Using the jump buttons doesnt seem to use nearly as much though.
Old 10-27-2009, 09:16 PM   #7
bandung_steve is an unknown quantity at this point
Nice Video and looking GOOD
bandung_steve is offline   Reply With Quote
Old 10-28-2009, 01:41 AM   #8
for the name:
Overlay Slide Menus ?
Old 10-29-2009, 03:16 AM   #9
If you want i can to be a beta tester
Old 10-29-2009, 01:32 PM   #10
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
Nice Very Nice, good job!!
EL CAMINO is offline   Reply With Quote
Old 10-29-2009, 10:33 PM   #11
One Sharp Cheddar
1st release
Let me know what you think?...
Old 10-31-2009, 05:16 AM   #12
THE EXPERIMENTER
carputer1's Avatar
well i have dl'ed and played , very nice work thunder , i know what i'm going to use it for , will let you know if i come across anything ,
CPU here for me is not a problem useing your script , yes it dose increase when dragging but not hit higher than 40% so far , with rr running and garmin, and music playing.
Links
Old 10-31-2009, 11:39 AM   #13
One Sharp Cheddar
Thanks,
I did find a bug last night. When using the autopopup feature it doesnt return after the timer times out. Problem solved.
I also found problems with Speed Zone interfacing correctly. I fixed this as well and also added a label to speedzone so that it would update and display the correct information needed.
Old 10-31-2009, 11:48 AM   #14
Quote: Originally Posted by ThunderStick View Post
Thanks,
The first post is updated or whe must to wait a little bit ?
Old 10-31-2009, 12:32 PM   #15
One Sharp Cheddar
Patience is virtue..
It is ready in the first post.
Holux GPS Trouble mangus580 StreetDeck 34 11-26-2007 09:56 PM
