Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 01-18-2007, 09:51 AM   #136
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
ok i've posted yet another version. I took out the way rr was writing to the playlist files and used the tried and true autoit method. Download the new version and overwrite your existing ratings.exe. Also there was an error in the exectbl "ONSONGSTART" entry. please lookat add to exectbl.ini for this.
I REALLY appreciate u guys sticking in and working the bugs out here. If this version gives you errors please list the following:
1. RR version
2. RR, music, and playlist install paths
3. Are .m3u's being created?
4. Are the songs being written to the correct m3u?
5. Any other issues
Doing it this way will reduce any confusion. Thanks
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Sonicxtacy02 is online now   Reply With Quote
Old 01-18-2007, 11:12 AM   #137
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
cool, ill give it a spin.
also note, i havnt had any of the issues others were having, all the updates worked fine for me.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 01-18-2007, 01:18 PM   #138
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Then you're not really trying hard enough.
Enforcer is offline   Reply With Quote
Old 01-18-2007, 05:41 PM   #139
Ruffy's Avatar
Ruffy is an unknown quantity at this point
updated everything, put the exectbl.ini stuff in both my main rr folder and my skins folder
still doesnt work. m3u files are still empty after rating.
Question
should the button that invokes the rating be
"MENU;ratings.skin||RunQW;C:\Program Files\Road Runner\Ratings\ratecheck.exe"
or
"MENU;ratings.skin||RunQW;C:\Program Files\Road Runner\Ratings\ratecheck.exe|$curtrack$"
I got the second method from LSX skin
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 01-18-2007, 06:13 PM   #140
Ruffy's Avatar
found something slightly interesting
the m3u files are NOT empty. Well they are in the sense that the proper data isnt being stored. Instead blank lines are being appended to each file
So if I rate 10 songs with a 4 star rating i get 10 blank lines in the m3u file
if you open up the file in a hex editor you can see this
0D 0A 0D 0A 0D 0A 0D 0A 0D 0A 0D 0A 0D 0A 0D 0A
One pair for each line. So it is attempting to write the data. but the plugin itself isnt pulling the song info from roadrunner like said above. Com issue? Would be nice if the plugin could interface with winamp directly for all the info it needed. Course if it could do that then it would be nicer if it used winamps built in rating support.
Oh wells. Best of luck.
Old 01-18-2007, 06:35 PM   #141
tundra2000's Avatar
tundra2000 is on a distinguished road
1) the latest version (11/12/2006)
2)RR: C:\program files\road runner\
music: C:\Documents and Settings\Owner\Desktop\My Media\MP3s\Music\
playlists: C:\program files\road runner\playlists
--all default
3) yes
4) yes
5) my issue is that when i rate a song, the indicator stars light up, then turn off immediately in my audio_player.skin. everything else is working fine for me tho. i am following all the directions
tundra2000 is offline   Reply With Quote
Old 01-18-2007, 06:36 PM   #142
Terminal flasher
Question
or
first method is correct. $curtrack worked with old versions of the plugin
i'm starting to wonder if it has something to do with having autoit and autoit beta installed. i did a quick test on a system that didnt have the beta installed and it didnt work. that would also explain why LS has it working (he uses autoit as much as i do). try updating both autoit and autoit beta.
03 Acura RSX Coupe
Old 01-18-2007, 06:42 PM   #143
Ruffy's Avatar
why do we even need autoit again? i thought when you compiled them to a .exe they were self contained.
I'll try the beta. dling it right now
Old 01-18-2007, 06:46 PM   #144
Ruffy's Avatar
beta installed
Still blank m3u's
Old 01-18-2007, 06:57 PM   #145
tundra2000's Avatar
update: ok i accidently clicked on ratecheck.exe, and what do u know, RR loads and my current song is rated correctly. so, in conclusion, every time i reload ratecheck.exe, it does what the name of the app is (it checks to see if the current song is rated, and then does sets the indicators appropriately). so ta da, that works. however, if i rate a song 5 stars or whatever, then go to a new song (which has not been rated), it keeps the old rating up (from the 5 star song) for all the songs that i play until it finds a song that i have rated differently.
basically, ive got it working except whenever i dont have a song rated, it just keeps the rating from the previous song up (even if i run ratecheck after a song change).
so maybe you could create a 0 star.m3u, and have it turn off all the indicators. then i would put all my music into the zero star playlist, and whenever i rate a song differently, it would delete it from the zero star playlist and write it into one of the other 5 playlists. just an idea
by the way, im running autoit normal (not the beta version).
Old 01-18-2007, 07:02 PM   #146
Terminal flasher
check ur MAIN exectbl.ini for "ONSONGSTART". Do you have that command there? if so delete it. then make sure your skin exectbl.ini has
"ONSONGSTART","RUNQ;$RRPATH$Ratings\ratecheck. exe"
03 Acura RSX Coupe
Old 01-18-2007, 07:08 PM   #147
Terminal flasher
u shouldnt need it but at this point i'm guessing what the problem is. There's nothing wrong with the script. It works on my computers, my friends computers, and LS confirmed it works on his. The question now is whats the difference between all these rr installs and the ones that arent working. If you're run the debugger version i posted yesterday and it showed you the track playing there is absolutely NOTHING that should stop execution... cause after that its just a matter of writing a line to a txt file. ive tried multiple ways of doing this... and all of them worked for the pcs mentioned earlier. I gotta find out why it doesnt work for the others
03 Acura RSX Coupe
Old 01-18-2007, 07:09 PM   #148
Ruffy's Avatar
is there supposed to be a space between ratecheck. and exe?
Old 01-18-2007, 07:13 PM   #149
Terminal flasher
no sorry that was a typo
03 Acura RSX Coupe
Old 01-18-2007, 07:15 PM   #150
Ruffy's Avatar
well my main execbtl is empty
my skins execbtl has the line. tried with both a space between ratecheck. and exe, and without just as ratecheck.exe
doesnt work.
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
Hello World plugin paulpv CF Plugins 5 06-08-2006 11:07 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 06:10 PM
