Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 01-08-2007, 10:31 AM   #76
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Quote: Originally Posted by raphizzz View Post
i'm having the exact same problem when using "ratings" altrough i use the lsxvoid 2.0 skin.
thats something that was fixed bakc in october. make sure ur using today's version and today's skins. Also make sure ur launch button is as it reads in the read me.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 01-08-2007, 04:28 PM   #77
raphizzz's Avatar
raphizzz is on a distinguished road
thanks, i updated the skins files with the archive i found in post#1.
the launch button is already set in lsxvoid2.0.
my playlist folder is D:\MP3\Playlists
now i if rate a song 3 stars, there's a "TEST" popup with the number 3, i press OK, and then i only get D: in "2 satrs.m3u"
raphizzz is offline   Reply With Quote
Old 01-08-2007, 04:47 PM   #78
Terminal flasher
thats odd.. you shouldnt be getting test lines as thast just debug code thats commented out.. gonna have to try somethin else i guess. Please make sure ur skin and launch code match the NEW stuff in the readme and i'll try to make other adjustments.
03 Acura RSX Coupe
Old 01-08-2007, 04:55 PM   #79
Terminal flasher
ugh i've gotta debug message to and i dont know why.. i'm pulling the release til i find out. stay tuned
03 Acura RSX Coupe
Old 01-08-2007, 05:24 PM   #80
tundra2000's Avatar
tundra2000 is on a distinguished road
*anxiously awaits re-upload...*
tundra2000 is offline   Reply With Quote
Old 01-08-2007, 05:25 PM   #81
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Ifeel your pain sonix! I had something similar with the installer for my skin. I would fix something post it, and it would break something else, pull it, re-fix it and something else was broke... The poor souls using the skin have been totally understanding. I am sure that people using this plugin also understand the strangeness of coding something, and working out the kinks.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 01-09-2007, 08:56 AM   #82
Terminal flasher
Ok posted ANOTHER fix and tested it for about 5 hours between last night and this morning. Everything is working as it should for me.
03 Acura RSX Coupe
Old 01-09-2007, 04:55 PM   #83
tundra2000's Avatar
um, i actually cannot get my ratings to work at all now after this update. i followed all the instructions! i thought i did at least. basically now when i click on my rate button, i rate the song, click apply, then a couple stars flash and then they all go away. am i missing something? my ratings dont work at all now tho.
i dont mean to complain at all, i just wanna get this working because its a plugin i think that could be potentially really useful once its fully functional. id be happy to test other versions if u need it.
another question, with this plugin, when i load RR, will it load all my ratings say if im playing songs in an on-the-fly playlist or if its a differnt playlist altogehter? that would be reallly really nice. thanks for all the work -i appreciate everything and i know what a pain this can be sometimes.
Old 01-09-2007, 07:05 PM   #84
Terminal flasher
i tested this on 4 pcs with different skins. Please give me details on your setup. Is your rr in the default install path? are you using the NEW button commands and skins in the new version? etc etc etc. The way it works is RR sends the currently playing track to rr and with that the plugin checks each of the "star" playlists for that song. If its detected the stars will light up letting you know. If not detected no stars will show. So it doesnt matter what playlist its in, if its playing in rr, u can rate it. I plan on adding the ability to rate an album as soon as these new kinks are ironed out.
03 Acura RSX Coupe
Old 01-09-2007, 08:14 PM   #85
tundra2000's Avatar
yea i have RR installed in the normal directory, and i followed the instructions exactly (new skins, new button, etc.). ill keep trying. im sure its something i have screwed up. i am running the old LSX void skin. i realy dont get why its doing this so i guess ill just have to mess around with it to get it to work. im sure it really does work and the way you have the plugin working is great. thanks for evverything.
Old 01-09-2007, 09:54 PM   #86
tundra2000's Avatar
ok well after messing around with it, i still havent solved it lol. i have winamp 5.31 -that might be a problem, but i doubt it. anyway, after saving a playlist straight out of winamp (not RR) as the 5 stars.m3u playlist, i played some of the songs in that play list and the ratings were not detected. in order for this plugin to do what you say it does, im assuming there has to be some 'exe' running in the background that checks the current song if it is on one of the 1-5 star playlists. i dont have any programs runnign while winamp is running. is something sposed to be? also, when i rate the song, what i think happens is it saves the song in the playlist, but immediately deletes it. not sure why. sorry if im babbling taking up space, but i think im gonna keep doin it until i get it right. again, im not blaming any of this on you or the plugin.
EDIT: when i open up my 4 stars.m3u (or whatever rating playlist) in notepad, the only thing in there is: C:
that help diagnosing this at all?
-this kinda looks like raphizzz's problem a couple posts up.
Old 01-09-2007, 11:48 PM   #87
Super Moderator
JohnWPB's Avatar
The version I just downloaded and tried does not seem to be working for me either. If I rate a song 1 Star, the 1star.mp3 file is empty, and nothing has been written to it.
It was working the other day with a version you had posted, aside from erasing the playlists when re-rating a song.
Old 01-10-2007, 09:53 AM   #88
Terminal flasher
Hey john, are you using the commands in the lsx void skin too? i THINK i found the problem. Ratings went thru changes and LS never sent me an update for that particular skin. Try this, add this to your MAIN exectbl.ini where it says ONSONGSTART.
"ONSONGSTART","SETVARBYCODE;curtrack;trackpath "
if you look at the freedom skin code thats included in "OK" button. Its missing from the LSX code. The lsx code was also missing the parameter for ratings.exe. copy this new skin to your skin folder. You guys give that a try and lemme know how it goes.
File Type: rar ratings.rar (542 Bytes, 46 views)
03 Acura RSX Coupe
Old 01-10-2007, 02:30 PM   #89
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Ok
Strange happenings. (probably caused by the same problems I had with the traffice one, but hey)
First off my RR is installed on my E: drive and my music somewhere on the M: drive
If I run with this, the plugin immediately hangs with no access via mouse or keyboard to RR and ratingscheck.exe is running at near 100%. I f I close this down then I get access back to rest of plugin.
I have tried changing the path for rr.ini in the ini file but it makes no difference (have tried just rrpath, rrpath\ and rrpath\rr.in where rrpath equals the full path to rr).
I then created a Road Runner folder on my c: drive and put rr.ini in there, now it doesn't hang, but I get no m3u files.
I then created a ratings folder on c: and now I get m3u files, but they are not in the folder specified in the ini, they are just in the root of M: and all they contain is 'M:' no name of files.
Am using the latest version in the first post.
*edit, added the extra curtrack to the OK button, now it does save a filename in the m3U file. However the other issues still exist.
Enforcer is offline   Reply With Quote
Old 01-10-2007, 02:43 PM   #90
Super Moderator
JohnWPB's Avatar
U will try this and let you know. As for the skin, no I am using the one that you packaged with the plugin.
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
Hello World plugin paulpv CF Plugins 5 06-08-2006 11:07 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 06:10 PM
