Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 01-12-2007, 02:18 AM   #106
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
Quote: Originally Posted by Ruffy View Post
this is what i'd prefer
I am gonna begin writing a tag editor plugin for RR (because there is always this one tag that I mess up and I always wished there was a way to change it within RR) and I will see if I can integrate the ratings part of the tag. I'll give Sonic the info so he can integrate it with his plugin.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 01-12-2007, 08:41 AM   #107
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
if you write a tag editor it'd be easy for me to adjust my plugin to make use of it... but can rr read the tag information and load songs according to the rating inside the tag is the question.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 01-12-2007, 01:54 PM   #108
I see dead kittens
Quattro's Avatar
Good question, that is something we have to ask guino
Installed
Old 01-15-2007, 02:47 PM   #109
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
ADDTOFILE command in Road Runner
Any luck sonix? One thing that MAY save you a little bit oof coding, is RR now has the ability internally to append a line to a file.
ADDTOFILE;$PLAYLISTPATH$5Star.M3U;=$CURRENTTRACK$"
You would still have to look and see if the song is in that list already, but it would make adding a line to a playlist very easy, instead of having to read the file in, add the line, and then save the file back out again.
I am anxious to get this working in my skin, as it is a fantastic plugin! I have it all skinned and ready to go, just waiting on the bug fixes ect.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 01-15-2007, 03:44 PM   #110
Terminal flasher
I've been working with enforcer on some fixes. He donated some of his time and code and i'll have the results of that out tomorrow hopefully.
03 Acura RSX Coupe
Old 01-15-2007, 04:08 PM   #111
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Still trying to track down that other little bug as well.
Enforcer is online now   Reply With Quote
Old 01-16-2007, 01:22 PM   #112
Terminal flasher
ok friends another version released. There are MANY changes that should make for a faster more streamlined (and easier to setup) experience. Please DELETE the previous ratings folder and any changes made to exectbl.ini. U will also have to copy the new .skin files over ur existing ones. Check post 1 for more details and by all means any bugs please report them.
03 Acura RSX Coupe
Old 01-16-2007, 02:02 PM   #113
raphizzz's Avatar
raphizzz is on a distinguished road
Thanks, it's working just fine now!!
Edit: i just noticed that the path of the song in the .m3u is wrong
it writes D: D:\MP3\... where it should be D:\MP3\...
raphizzz is offline   Reply With Quote
Old 01-16-2007, 07:18 PM   #114
tundra2000's Avatar
tundra2000 is on a distinguished road
im pretty sure that i followed all the directions. the buttons are all working / writing to the playlists correctly. very good progress. its very close (at least for me). the only problem i am having is that my indicators wont stay on. they turn on rightwhen i rate a song, but then turn off immediately. any suggestions?
tundra2000 is offline   Reply With Quote
Old 01-16-2007, 07:21 PM   #115
Confusion Master
Enforcer's Avatar
Actually it's doing that in all playlists, otherwise it seems to be working for me now.
What I would like to see though is:
When rating a previously rated song it puts it's old rating up before you re-rate it.
Old 01-16-2007, 09:53 PM   #116
Terminal flasher
There's something odd in RR that makes some labels show the drive letter and some dont. Easy fix though that will be done first thing tomorrow
are you mousing over your indicators? Unfortunately thats the way rr turns them off. Only way around this is to create a flash skin (which i have around here somewhere if you want it)
drive letter issue will be fixed tomorrow. And what you requested should happen if a song is rated. Thats the sole purpose of ratecheck.exe. Thats one thing i forgot to test today but i will tomorrow.
03 Acura RSX Coupe
Old 01-16-2007, 10:11 PM   #117
Confusion Master
Enforcer's Avatar
Funny, I don't have this issue
The indicators for the previously rated song are lit when the pop up comes, then disappear, but the current songs rating does not appear.
Old 01-16-2007, 11:21 PM   #118
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
So sonic, how did you like working with the RR COM interface? Make things a little easier?
It might be about time I give this thing another go, now thats its a more mature plugin...
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 01-17-2007, 08:46 AM   #119
Terminal flasher
the inferface rocks . And i had no idea it was as easy as it is. Definitely saves time and resources. Sadly i have put your getpaths() function to rest.
03 Acura RSX Coupe
Old 01-17-2007, 12:04 PM   #120
Terminal flasher
new version released. Check post 1
03 Acura RSX Coupe
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
Hello World plugin paulpv CF Plugins 5 06-08-2006 11:07 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 06:10 PM
