Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 01-15-2009, 01:27 PM   #46
Startingline13 can only hope to improve
The North American Version of Vista 32. That's why I can't understand why it is coming up with Chinese symbols.
Startingline13 is offline   Reply With Quote
Old 01-15-2009, 03:12 PM   #47
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Ah! vista, you need to be running in XP compatability mode I believe as Vista doesn't like some VB6 runtimes. (at least I think that is it)
Enforcer is offline   Reply With Quote
Old 01-15-2009, 03:40 PM   #48
Ahhh, have to love Microsoft
Ok I'll try that out when I get home a bit later.
Old 01-15-2009, 11:05 PM   #49
I've been searching for ways to run this in compatibility mode but have come up with nothing. It seems you can only run specific programs in compatibility mode, and not something such as a .dll
Old 01-21-2009, 12:00 AM   #50
docbreezy's Avatar
docbreezy is an unknown quantity at this point
Nice lil plugin. I actually got it to work first time with no hitch. Now i can see whats happening in the trunk from up front. So now i woul like to explore a bit further
1. would it be possible (from rr) to monitor the power source, whether battery or external and then execute a command (Lets say, hibernate) when source changes from external to battery.
2 what would that command look like? (Maybe using that BYVAR command??)
NEVER BLEND IN!!!
docbreezy is offline   Reply With Quote
Old 01-21-2009, 12:05 AM   #51
Confusion Master
Enforcer's Avatar
Have a look at bluezx3's plugins, he has one which will monitor label values and then react to certain user defined values.
Old 01-21-2009, 05:54 PM   #52
docbreezy's Avatar
Thanks for the reply, i used the RRWarningWatcher and i actually got it to work. Im exctatic. There is only one sticking point though. I am using the battery level label which does a few things i specify and then hibernates when battery drops below 90% which happens when external power is dropped and battery starts discharging . Works like a charm.
Problem is, since the battery wont be charging while in hibernation, upon resume, battery level will still be below the 90%.
I would rather use the powersource label but its given in text rather than numeric. so i cant/dont know how to use the '<' or '>' criteria.
NEVER BLEND IN!!!
Old 01-21-2009, 06:10 PM   #53
Confusion Master
Enforcer's Avatar
can you not test it equal to charging or not charging
Old 01-21-2009, 09:43 PM   #54
docbreezy's Avatar
I tried, with no luck. dont think the syntax allows "=", it seems to only respond when more or less than the set criteria which seem to need some numerical value.
NEVER BLEND IN!!!
Old 01-22-2009, 11:39 AM   #55
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Kinda round about, but you could set up a global timer event to evaluate the power source label and set a value based on the string.
Code:
SETVARBYCODE;pstate;powermon_powersrc||EVAL;pstate;strcomp("$pstate$";"Battery")||BYVAR;pstate;SETLABEL;CUSTOMpwrsrc;1<<SETLABEL;CUSTOMpwrsrc;3" .
Then set RRWW to monitor "CUSTOMpwrsrc"
I think you can also use the BYSTR command to do the same thing, but I don't know if it can read labels directly. I know it can eval variables with string properties, tho.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 01-22-2009, 09:18 PM   #56
docbreezy's Avatar
Well that didnt work out. It did work somewhat, but the RRWW Alarm event kept firing no matter how i cofigured it. However i did, find a winning combination from that code.
Code:
"TIMER","SETVARBYCODE;pstate;powermon_powersrc||EVAL;pstate;strcomp("$pstate$";"Battery")||BYVAR;pstate;DONOTHING<<CUSTHib" "CUSTHib","DIGITALOUT11TOGGLE||wAIT;1||FBDISCONNECT||wAIT;1||HIBERNATE"
Works like a gem and now i have no need for those external hibernation apps and i didn't even have to utilize RRWW.
NEVER BLEND IN!!!
Old 05-01-2009, 12:04 PM   #57
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
Hey Sal, I just posted some code in the RREXTENDED Thread about triggering an RRCode command when powermon_powersrc label changes. Can this plugin be setup to do it for me, i.e., through a settings.ini or a switch. My method works, but it requires a RRCode timer fired every 15 seconds. And I'd like to get away from additional plugins and timers.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 05-01-2009, 12:39 PM   #58
Sal R.'s Avatar
I can probably add an indicator if the power source was a battery or external and you can then use the RRE's IndPoller.
I've never had much luck executing commands from a label change.
Looking at the code your provided in the RRE thread, it looks like it might work...
Old 05-01-2009, 07:53 PM   #59
GizmoQ's Avatar
Nah, my label change checker does work! Right now its the only thing using RRE. Was looking to reduce # of plugins.
Old 11-03-2009, 11:22 PM   #60
mcmasterp is an unknown quantity at this point
I am sorry, I read this thread but I dont think I am up to heavy coding.
I am using the digitalFX 4.o skin.
I tried using the examples people gave but with my 1024x600 res it is all screwed up placement wise. I would really like it small somewhere in the corner possibly next to the cpu%.
any ideas?
mcmasterp is offline   Reply With Quote
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
XMLTraffic Plugin 307SW_NLD RR Plugins 20 09-14-2006 06:20 PM
Hello World plugin paulpv CF Plugins 5 06-08-2006 11:07 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
