Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 02-01-2008, 06:56 AM   #376
Darkman613 is an unknown quantity at this point
Quote: Originally Posted by jonessc View Post
does ge support voicr navigation as well?
Just start iGuidance, enter a destination, and then switch to GE... you will get the GE display and hear the IGuidance voice in the background!
Darkman613 is offline   Reply With Quote
Old 02-01-2008, 07:16 AM   #377
BTW, Is there a way to start GE in silent mode without the irritating splash screen and other message windows?
Old 02-02-2008, 10:59 PM   #378
slvrsol's Avatar
slvrsol is an unknown quantity at this point
Quote: Originally Posted by hari-bhari View Post
sorry to bump my own post, but no help here?? i know i had it working before. where does it get the comport info from? im just trying to figure out what could cause the kml to be empty.
If it is empty, maybe you should download the file again.
slvrsol is offline   Reply With Quote
Old 02-03-2008, 06:27 PM   #379
hari-bhari can only hope to improve
i finally found the download link in post 350 of this file and replaced the net.kml.ini and that seemed to do the trick. EUREKA!
hari-bhari is offline   Reply With Quote
Old 02-04-2008, 11:05 AM   #380
for those of you looking to cache, here is a duplicate of my post from the lsx thread that may be of help:
google 'ge cacher', i think that's what i used. it has parameters for upper left corner, then the width and the length of the total area you want to cache. also has a parameter for altitude so you can see how high up you want to get, and the width and length of each box u make. you'll have to play with the parameters a bit before you get the altitude to match each step's box size, but you can watch it as it goes along to verify.
a few pieces of advice:
-make sure ur cache level is set to 2000mb in GE which is the max if u want the map as much as you want.
-MAKE SURE that when you copy it over to the carputer you have it set to 2000mb as well, otherwise when you copy the cache file over itll basically wipe out part of the file and the index and ull have to do it over
-copy over your ge cache AND the index file, the cache file is useless without its index and ull have to start over if u lose it.
-if you have multiple areas you would like to cache, do it in one run of GE (you can still use the cacher multiple times, but leave GE open) and monitor your cache file to ensure its not exceeding 2000mb or you will wipe out your initial cached area. i found that if you exit in between sometimes, the areas u had before disappear from the index file even though the cache file size still shows as the same. you may also want to just backup the cache and the index file incrementally on the way to be safe in case it gets messed up along the way.
-make sure in your carpc you have run GE at least once with internet access before you load in your cache file or it wont work.
hope all this helps
Old 02-05-2008, 11:38 PM   #381
slvrsol's Avatar
does anyone have problems with the gps or ruler screen popping up when executing commands on other screens?
Old 02-08-2008, 08:17 AM   #382
brandensin is an unknown quantity at this point
Guino, you are the PIMP of all.. This is a great toy...
brandensin is offline   Reply With Quote
Old 02-19-2008, 06:42 AM   #383
RRearth Crashes on Close
For some reasons, the my RoadRunner/DigitalFX crashes when I close the RREarth window... any idea?
Here is my close command in the RREARTH.skin:
B,680,0,61,51,"EXIT||GE_CLOSE",
This is with a fresh install...
Thanks!
Old 02-23-2008, 10:11 PM   #384
Opr_7G is an unknown quantity at this point
Looks like I just missed the boat... kompassist.co.uk is apparently down for an indefinite amount of time. Doing a DNS lookup on the domain returns:
Registration status:
Renewal required.
*** This registration has been SUSPENDED. ***
Does anyone know when/if it will be back, or if there is an alternate source for this plugin? It's the only file for which I could not find a mirror...
________________________________
3 GHz P4 1GB RAM; Mini-ITX
250 GB HDD
Holux GPS; iGuidance 3.0
Turtle Beach AA Roadie USB (5.1 config)
Lilliput 629GL-70NP 7" Display
Opr_7G is offline   Reply With Quote
Old 02-24-2008, 05:45 PM   #385
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
This is the latest I have...
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 03-13-2008, 01:24 PM   #386
morris_the_cat's Avatar
morris_the_cat is an unknown quantity at this point
Is anyone else having issues with running this in the DXF3.0 skin. It doesn't embed properly & doesn't turn on GPS tracking. It works fine with the test skin though in DXF2.0.. ??
2001 PT Cuiser
VoomPC with 1.5Ghz C7
M2 power supply
in dash slim tray dvd drive
DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
See my install here
morris_the_cat is offline   Reply With Quote
Old 03-19-2008, 04:45 AM   #387
Does anyone know how to launch the RREarth plug-in with DFX3.0?
Old 03-19-2008, 10:16 AM   #388
kirk78h's Avatar
kirk78h is an unknown quantity at this point
Thanks!
I'm having the same issue with DigitalFX 2.5
kirk78h is offline   Reply With Quote
Old 03-24-2008, 08:40 AM   #389
Anyone?
Old 03-24-2008, 12:42 PM   #390
take out that exit... It seems like ge_close already have an exit command embeded in...
I looked at the debug file, and it's executing exit call twice which leds rr to shutdown..
so, "exit||ge_close" ====> "ge_close" that should do it...
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
slide show plugin for winamp 3 needed babas151 Software & Software Development 0 02-01-2003 12:24 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
winamp audio CD plugin needed babas151 Software & Software Development 4 05-14-2002 04:47 PM
Blackwind's keypad plugin v2.0 beta released Blackwind Software & Software Development 14 02-11-2001 04:54 AM
