Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 09-27-2006, 03:54 PM   #46
Chuck's Avatar
Chuck is on a distinguished road
I guess it’s almost time for me to upgrade
-It is NOT recommend to run this on machines with less than 512Mb of RAM - 256Mb
-It is NOT recommend to run this on machines with less 1.2Ghz - 1.3Ghz
-It is NOT recommend to run this on machines with less 32Mb of Video - 16Mb
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 09-27-2006, 05:21 PM   #47
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Ok, posted another update (same link). This one has tilt control support and autozoom support (I did NOT update the skin yet -- check skin commands.txt and rrearth.ini for details). Let me know how this works.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 09-27-2006, 05:28 PM   #48
guino's Avatar
I just did an upgrade on my CarPC (one of my home machines had the MB shot so I got some spare parts). I first ran it with 8Mb of video and 256Mb RAM and it had less detail (maps) and was pretty sluggish.. then I added another 256Mb and changed in the BIOS the shared memory for video to 32Mb.. now it has better map detail and runs pretty nice too.. My work laptop (where I develop), is a 1.2Ghz with 512Mb Ram and it works pretty decent too.. this one has a nice 128Mb video card though.. with less then 32Mb video you can only display high detail maps of 256x256 (center area of the screen) and the rest gets blurred out.. with 32Mb you can display 512x512 .. At some other level you can get it to display the full maps at high quality (don't know exactly what number that is).. those are settings in GE you can set (it enables/disables it according to the video memory available).
Old 09-27-2006, 05:44 PM   #49
wfs1's Avatar
wfs1 is on a distinguished road
quino,
I have tried to find the reason for this not to resize or embed into the RRearth screens. Is there something in RR config or maybe window that I am overlooking??
If I don't clip then then this will happen, the google earth is behind the rrearth screens. If I open task manager and task from RR to GE then back again it will try to resize there but as soon as I touch any part of the GE program it goes fullscreen and covers the RRearth skin. Also when I go to RRearth2 skin goggle goes fullscreen and if I toggle using taskmanager it will try to resize but none of the commands/buttons work.
I'm running this on a 2.4 P4 with 1-gig memory but my video is only 16 meg and I can't change or share it in the bios. I setup GE to use directx as they recommended..
Lost again..
wfs1 is offline   Reply With Quote
Old 09-27-2006, 05:49 PM   #50
guino's Avatar
Are you using GE version 4 ?
Old 09-27-2006, 05:49 PM   #51
guino's Avatar
Also, if anybody downloaded the auto-zoom/tilt version, please re-download as I forgot to update the EXE in the zip.. the right EXE is up now.
Old 09-27-2006, 06:00 PM   #52
wfs1's Avatar
Yes version 4 beta the latest from there site.
Old 09-27-2006, 08:03 PM   #53
guino's Avatar
check your pm.
Old 09-27-2006, 11:20 PM   #54
kolemieux is on a distinguished road
Guino - had work travel today wish I had seen this sooner spent 5 hours round trip over to Indy with a rock solid RR trip ;-)
Just grabbing this now and will report in --- I tested the early goops stuff but was messy - this looks pretty interesting especially with the cache features in Earth...
Thanks for this!
kolemieux is offline   Reply With Quote
Old 09-28-2006, 12:09 AM   #55
Guino --
I stepped thru all 4 pages of the thread, to the tee. I get the skin to load, no embedding occurs but I see that googleearth is loaded as a process with task manager.
1 - Copied beta RoadRunner.exe to my RR path
2 - Using BMV fresh skin - added new skin files and assigned a button
3 - Unzip'd files to RR path and ran the .exe there as you indicated
4 - Installed GE 4 made sure no links as you mentioned.
5 - Added the x, ... to the menu skin file.
Double checked this all quite a bit but sure I could have missed something?
Anything else I may be missing.... I am going to try another clean build. Looks fantastic - would love to see it.
Quote: Originally Posted by guino View Post
@wfs1: I don't think you have it setup propperly:
1-You should not see any menu bars
2-You should not need to clip any areas of the skin
3-You should not use the LOAD command to start/show the maps, you should use "GE_START" only.
4-Double check you've deleted RR.EXE and you're running RoadRunner.exe (with that FILENAME) -- the one posted on the BETA site.
Old 09-28-2006, 12:18 AM   #56
Guino - update...
Correct me if I am wrong, and don't think this should be the case. But if I run GE 4 before RR, it appears to embed properly and is showing and operating within the skin. I don't think this is the desired approach here but just an update on that.....
Old 09-28-2006, 12:51 AM   #57
Ok - ditto on speed comments below and well warned Guino, but I did get it working in a clean RR build - so it loads and all is well. I am using local and simply need to see if it would be usable in my cars - and also the features a bit more. Not sure exactly that I know enough about how I would go about using it but the directions piece I would like to figure out.
Thanks again for the work. There is no doubt this it tied in beautiful - very embedded from my view - fantastic job. I just need to understand the app and how to better use it (or how you would other than wow which is kewl by the way), how to cache better (is tool only option), and how the GE directions piece works.
I will mess with all of this and sure folks will chime in.
Thanks!!!
Quote: Originally Posted by Sonicxtacy02 View Post
its working on my home system quite well. I cant use it in the car yet though cause i dont wanna give up the latest phoco beta .exe . The system i'm on now is a 1ghz with a gig of ram and yea.. not even CLOSE to usable lol.
Autozoom based on speed i'd consider a must. Tilt control as a present would be a pretty nice little feature. As for goops... dunno a thing about it
Old 09-28-2006, 04:46 AM   #58
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
Guys... I thought Googles app worked around Direct X ? If thats so is there any accellaction features you can use there ?
Terran
ccsnet is offline   Reply With Quote
Old 09-28-2006, 06:24 AM   #59
guino's Avatar
it can use DX or OpenGL.. both use hardware accel, but it's still pretty intense it seems..
Old 09-28-2006, 09:23 AM   #60
gabepage is on a distinguished road
Great work guino!!!
Thanks!!!
gabepage is offline   Reply With Quote
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
slide show plugin for winamp 3 needed babas151 Software & Software Development 0 02-01-2003 12:24 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
winamp audio CD plugin needed babas151 Software & Software Development 4 05-14-2002 04:47 PM
Blackwind's keypad plugin v2.0 beta released Blackwind Software & Software Development 14 02-11-2001 04:54 AM
