Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 01-31-2007, 10:35 AM   #151
307SW_NLD's Avatar
307SW_NLD is on a distinguished road
Quote: Originally Posted by mugurg View Post
I have registered the new DLL , and tried with both my skin files and the one attached. I can't get it to work at all. Using back my previous DLL/INI files everything works perfect. Where should i see the new indicator to click on it? the one "invisible" named k8055_menu is doing nothing when i am pressing it. What i am doing wrong?
Sorry to hear this. I checked this on a fresh machine without installing the K8055 software. Only placed k8055d.dll, rrk8055.dll and the rrk8055.ini in the road runner directory. Starting with an older version of my rrk8055d.dll it worked after registring the rrk8055.dll. Replace the dll with the new version and it did not work!! Did and regsvr32 rrk8055.dll /U and a regsvr32 rrk8055.dll and it worked. Please could you try the same thing. Please redownload the latest version as I have my K8055d.dll included in there.
My car: 2003 KIA Sorento 2.5 CRDI AUT
Hardware: EPIA SP13000, 60Gb 2.5"HDD, M1-ATX, Lilliput 7", RADIO SiLABS, K8055 BOARD
Software: Road Runner, FreeDrive, PowerDVD, WinXP SP1
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 50 % DONE
307SW_NLD is offline   Reply With Quote
Old 01-31-2007, 10:39 AM   #152
mugurg is an unknown quantity at this point
Will do now.
Later edit: downloaded the last version.
Unregistered the DLL first then placed the files in the RR folder and registered the files you sent. Got the confirmation of unregistering and registering as succeded...
Nothing.. the board displays 0 (zero) on the indicators and that is all.
RE-done all steps again. Still nothing...using also your SKIN file not mine.
BTW, of course the board works perfect with its own software...and with the previous DLL version.
My second Subaru skin
Full screenshots second skin
My car photos
CarPC Progress
■■■■■■■ - 75%
mugurg is offline   Reply With Quote
Old 02-02-2007, 09:44 AM   #153
307SW_NLD's Avatar
Will do now.
Could you please try this one? If took out a few changes that might have caused problems in your case. Need to now what language version of windows you are using and how you date/time format looks like.
Old 02-02-2007, 09:47 AM   #154
hi
Win XP Pro, SP2
Time/date: Friday, February 02, 2007
My car photos
CarPC Progress
■■■■■■■ - 75%
Old 02-05-2007, 06:10 PM   #155
lambosprit's Avatar
lambosprit is on a distinguished road
hi 307
tried the new dll but its still not working for me. I tried to unregister my previous version of k8055d.dll and I get a "K8055d.dll was loaded, but the dllunregisterserver entry point was not found. File cannot be unregistered" message. Got something similar when I tried to register it afterwards.
My own app still works fine and controls the board no problem. Any ideas?
thanks
lambosprit is offline   Reply With Quote
Old 02-05-2007, 06:26 PM   #156
307SW_NLD's Avatar
Quote: Originally Posted by lambosprit View Post
hi 307
thanks
You can't register the k8055d.dll. You'll have to register the rrk8055.dll. Please have the k8055d.dll in the same dir as the rrk8055.dll (c:\Program Files\Road Runner)
Old 02-06-2007, 06:47 PM   #157
lambosprit's Avatar
ok. I've run out of things to check now. Just cant seem to get it to work. I have the rrk8055 dll registered and the k8055 dll in my rr directory. I've added the indicator to my skin but nothing appears. Using the test program supplied with the board everything works.
Thanks for your help but I'm lost now
Old 02-07-2007, 05:16 AM   #158
307SW_NLD's Avatar
Sorry to hear this. I don't know what is going on here. I'm building some debug code in my plugin to see if it's even called. If it's not called I can understand it has problems. If it's being called I will write some messages in a debug file what the results are of the initialization of the board. Can you in the mean time send me your debug.txt from the roadrunner directory. (please delete the current and restart road runner and open your screen with the k8055 controls.) If debuging is not on you can enable it in the RRconfig utility.
Old 02-07-2007, 04:24 PM   #159
lambosprit's Avatar
Thanks for putting in the time to help its greatly appreciated because I really want this to work. If I can test the new debug messages for you I will. Heres my debug. I can see an sdk message calling the dll but nothing else
Old 02-08-2007, 04:27 AM   #160
307SW_NLD's Avatar
The RRSCREEN call you saw in the debug.txt means that RR has successfully loaded rrk8055.dll. So it has problems initializing the board itself. Will see what I can do with debug messages.
Old 02-09-2007, 01:35 PM   #161
307SW_NLD's Avatar
OK,
For the people having troubles to get the plugin to work please use the attached dll. This dll will create a k8055debug.txt with some debug info. Please let me know the results.
Old 02-09-2007, 05:47 PM   #162
lambosprit's Avatar
here's my debug log. Hope it helps. Just in case I de-registered and re-registered the dll. Had trouble finding the k8055debug file. It was in the road runner gamma folder for some reason
Old 02-10-2007, 12:53 PM   #163
307SW_NLD's Avatar
This is indeed strange. I'm writing the debug file in the same location as I'm expecting the rrk8055.ini. Can you copy the k8055d.dll and the rrk8055.dll and the rrk8055.ini to this directory and try again?
Old 02-11-2007, 11:50 AM   #164
dan__wright's Avatar
dan__wright is on a distinguished road
thanks for this brilliant plugin, only problem i have it it is that i have to load the relays skin before it will work, i have moved the X,RRK8055 from the relay skin to the menu skin but i still have to load the relays skin before it will work.
Any ideas?
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
dan__wright is offline   Reply With Quote
Old 02-11-2007, 02:04 PM   #165
lambosprit's Avatar
Hurray. Success. If I put the files in my gamma folder everything works perfectly. Now why does it look in the gamma folder. I have checked my rr config and all seems ok. I haven't actually set the ini file path on rr config, could this be it?
Lilliput button board (IR sensor extension)...did I fry it? Quack LCD/Display 10 08-22-2008 06:36 PM
i think i burn my USB controller board susuking LCD/Display 0 01-26-2006 12:55 PM
USB Control Board component burned carfreak01 LCD/Display 4 08-24-2005 03:43 PM
Lilliput USB Circuit Board... gleinz LCD/Display 1 01-18-2005 05:09 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
