Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 11-07-2006, 05:03 AM   #31
307SW_NLD's Avatar
307SW_NLD is on a distinguished road
You can use my example skin the get the readings for each button press when you connected the steering wheel control to analogin2.
If you have the following setting in the RRK8055.ini the label for analogin2 will read a value between 0 (is 0 volts) and 255 (is 5 volts)
[AnalogOut2]
LowValue=0
HighValue=255
Decimals=0
Units=
Write down the values you see for each button you press and populate the value in the RRK8055.ini. See example below.
Because of interference and loss due to connections and wires. The button press will not allways give the same reading. This problem is solved by using AnalogButtonVariance. A AnalogButtonVariance of 5 with AnalogButton1 really means that the plugin will detect any reading between 5 and 15 as a buttonpress for AnalogButton1. In the example below this will send an volume up command to Road Runner
[MENU]
Mask=31
Type=Analog
Menu1=DEFAULT
AnalogButton1=10
AnalogButton2=50
AnalogButton4=100
AnalogButton8=150
AnalogButton16=200
AnalogButtonVariance=5
[DEFAULT]
Button1=VOL+
Button2=VOL-
Button3=MUTE
Button4=PLAY
Button8=NEXT
Button16=PREV
My car: 2003 KIA Sorento 2.5 CRDI AUT
Hardware: EPIA SP13000, 60Gb 2.5"HDD, M1-ATX, Lilliput 7", RADIO SiLABS, K8055 BOARD
Software: Road Runner, FreeDrive, PowerDVD, WinXP SP1
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 50 % DONE
307SW_NLD is offline   Reply With Quote
Old 11-07-2006, 08:21 AM   #32
p1cass0 is on a distinguished road
Is it possible to sense the handbrake state using one of the digital inputs and this plugin to set a ' brake_on/off' flag in RR. Then maybe this flag could be monitored by the MotionLock plugin to disable 'in motion' functions.
p1cass0 is offline   Reply With Quote
Old 11-07-2006, 09:12 AM   #33
307SW_NLD's Avatar
Why not execute a command (is there a new command implemented in the motionlock plugin? If not, this can be easily added to the plugin) that stops the DVD playback. This can be done based on the state of one of the digital inputs. Will have to make changes to my plugin aswell since it only executes a command on a change from off to on. Should also be able to execute a command when input goes from on to off.
Old 11-07-2006, 01:10 PM   #34
Tissy's Avatar
Tissy is on a distinguished road
The demo which came on the CD works fine, but the plug-in still doesn't.
There seems to be a problem with the registration of the K8055D.dll as if i try and register it i get these errors. One is by using a 'right-click' DLL register in the context menu, the other is in a DOS prompt.
However the RRK8055.dll registered fine. Can someone post their K8055D.dll incase mine is corrupt.
Any other ideas?
Steve
System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
Tissy is offline   Reply With Quote
Old 11-07-2006, 05:27 PM   #35
307SW_NLD's Avatar
If the demo work fine the k8055d.dll is registered correctly. The demo is also using the dll. Did you change the lowercase x in the relay.skin?
Old 11-07-2006, 06:23 PM   #36
Tissy's Avatar
OK, figured it out. On my installation CD there is a sub-directory entitled 'DLL Ver2.0 with examples' this is the DLL i was using. Having taken the DLL which was in the installed demo directory and placed this in the RR directory, all now works.
Velleman have obvioulsy released an upgraded DLL which is not capatible with this plug-in.
307SW_NLD - Are you aware of this and is it worth me sending you the DLL and the accompanying PDF document. Also it may be worth placing the correct DLL in your ZIP file to save any future problems ?
Cheers for your help, i can start to use it now !!
Steve
Old 11-08-2006, 04:43 AM   #37
Tissy's Avatar
Do you currently have commands for the following:
  • All Outputs ON
  • All Outputs OFF
  • Toggle ALL Outputs
  • Test Mode (sequentially turn on then off all outputs)
If not would you consider implementing these commands as they may be useful.
Many thanks
Old 11-08-2006, 08:00 AM   #38
307SW_NLD's Avatar
  • All Outputs ON
  • All Outputs OFF
Many thanks
No, none of them are yet implemented. I'll consider it. Have to make some major changes the the way menus work first.
Old 11-08-2006, 10:26 PM   #39
proph's Avatar
proph is on a distinguished road
those that use this piece... how are you using the digital 13 digital lines?
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
proph is offline   Reply With Quote
Old 11-09-2006, 07:21 AM   #40
307SW_NLD's Avatar
You mean the 8 digital outputs and 5 digital inputs (8+5 = 13)?
You want to know how?
Using the plugin you can use the digital inputs as indicators in RR of you can use them as inputs to execute RR commands.
The digital outputs are controled using RR buttons or using a clickable RR indicator.
Or do you want to know what we have connected to them?
Steering wheel controls, Buttons, Door open detection, etc.
Old 11-11-2006, 06:38 PM   #41
307SW_NLD's Avatar
Quote: Originally Posted by Jarrod View Post
Sorry for being such an electronics n00b, but can you please help me figure out what voltage I can use for the analog input going by the attached schematic for my steering wheel controls?
Thanks,
For the ones going to use the analogin for steering wheel controls or are creating your own keypad, here is a sample schematic that can be used to connect the steering wheel controls to the analog in.
Is also created an excelnsheet that can be used to calculate the different resistor values and output values. You can use the outputvalues in the RRK8055.ini to configure the analog menu.
Old 11-15-2006, 08:43 PM   #42
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
wow, this is really cool... great work with this, I gotta get me one of those boards
turbocad6 is offline   Reply With Quote
Old 11-16-2006, 11:23 AM   #43
nugomes is on a distinguished road
hi is it possivel to control my cpu cooler ?
I mean read temperatur and if temperature is higher than 40°c then turn cpu cooler one and then when temperatur goes under 40°c wait some time and then turn cpu cooler off
on europe this board is avaiable on
www.conrad.de
www.conrad.ch
nugomes is offline   Reply With Quote
Old 11-16-2006, 01:45 PM   #44
307SW_NLD's Avatar
www.conrad.de
www.conrad.ch
You can use the analog input to read the temperature and you can use one of the digital outputs to swtich on/off your CPU cooler. You can also use the analog out/PWM pulses to control the speed of your CPU cooler. Maybe with some smart skinning you can automate this. But in my opinion it would be cheaper to get yourself a temp. controlled CPU cooler which will run independantly from RR. On the other hand, paid just 45 euro for the board in the Netherlands (www.conrad.nl) and opens a world of possibilities.
Old 11-16-2006, 03:16 PM   #45
hy tanks for the answer
well I tink my problem will be the "smart skinning"
I hope some one kan help I would like to use this boar to detect the rear gear and then turn on my rear camera.
I thik I m going to by the board and see what I can do.
thanks
Lilliput button board (IR sensor extension)...did I fry it? Quack LCD/Display 10 08-22-2008 06:36 PM
i think i burn my USB controller board susuking LCD/Display 0 01-26-2006 12:55 PM
USB Control Board component burned carfreak01 LCD/Display 4 08-24-2005 03:43 PM
Lilliput USB Circuit Board... gleinz LCD/Display 1 01-18-2005 05:09 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
