Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 12-22-2006, 06:23 PM   #106
307SW_NLD's Avatar
307SW_NLD is on a distinguished road
Quote: Originally Posted by distler View Post
Does this plugin support the "The number of inputs/outputs can be further expanded by connecting more (up to a maximum of four) cards to the PC's USB connectors." part listed by velleman?
I'm thinking of having atleast two of these cards in use for all the functions i need... well mostly the relays that i'm short on.
It does not at the moment. You can use one card at one of the four available addresses. I might implement a card address destination switch command that you can execute before the actually sending output to the desired card.
My car: 2003 KIA Sorento 2.5 CRDI AUT
Hardware: EPIA SP13000, 60Gb 2.5"HDD, M1-ATX, Lilliput 7", RADIO SiLABS, K8055 BOARD
Software: Road Runner, FreeDrive, PowerDVD, WinXP SP1
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 50 % DONE
307SW_NLD is offline   Reply With Quote
Old 12-29-2006, 09:43 AM   #107
307SW_NLD's Avatar
Plugin updated. See post #1
Old 12-29-2006, 09:50 AM   #108
mugurg is an unknown quantity at this point
WOW!!! many thanks for hidden screens!
My second Subaru skin
Full screenshots second skin
My car photos
CarPC Progress
■■■■■■■ - 75%
mugurg is offline   Reply With Quote
Old 01-04-2007, 06:18 PM   #109
dan__wright's Avatar
dan__wright is on a distinguished road
please help, im using latest version of rr and also using the latest version of the plugin (also tested the beta). i have added the relays.skin and other files for it into my skin, added the dll & ini to the rr folder and registed the DLL, i have added the command "LOAD;relays.skin", into my menu skin.
when i click the button i see the screen but no values in anything and it doesnt read / controll the board but i get no errors, any ideas?
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
dan__wright is offline   Reply With Quote
Old 01-04-2007, 06:28 PM   #110
307SW_NLD's Avatar
Does the relays.skin have a X,RRK8055 entry?
Does the demo program of the K8055 board work.
Where is the K8055d.dll located. Try moving it to the windows\system32 directory or the road runnner directory
Old 01-04-2007, 06:31 PM   #111
Hi, yeah the skin has the entry and it has the capital X.
the demo program works fine and the files are in the RR directory.
the strange thing is i just unregistered the dll and renamed it and launched the skin, nothing, its almost as if its not trying to load the DLL.
Type-R Mini
Old 01-04-2007, 07:28 PM   #112
Are you sure Dan you've registered the DLL corectly? i am asking this because before registering i have had to go to the correct path and then to register. I used TotalComander for this. but it should work from promter too... Before i did that, my result was identical with yours...
My car photos
CarPC Progress
■■■■■■■ - 75%
Old 01-05-2007, 03:57 AM   #113
yeah im sure, ive also tried unregistering it and registering it from that dir.
the strange thing is if i add X,RRK8055 to the menu.skin when i load the relays .skin the counters and two inputs to the right at the bottom show 0, if i dont have that there they are blank.
Type-R Mini
Old 01-05-2007, 12:52 PM   #114
307SW_NLD's Avatar
Copy the k8055d.dll to your rr directory
Old 01-05-2007, 02:27 PM   #115
i copied the k8055d.dll from the demo app but it made no difference, i tried to register it and got this error
Type-R Mini
Old 01-05-2007, 02:46 PM   #116
Dan you have to copy the DLL from this thread, not the original DLL file that you have with your demo...
Have you tried with this one?
My car photos
CarPC Progress
■■■■■■■ - 75%
Old 01-05-2007, 03:14 PM   #117
yeah ive had the rrk8055.dll there and registered the whole time but 307sw's last post was about k8055d.dll which is what the demos use
Type-R Mini
Old 01-05-2007, 03:33 PM   #118
Then it's out of my knowlegde. My board works perfect in RR...
My car photos
CarPC Progress
■■■■■■■ - 75%
Old 01-05-2007, 04:50 PM   #119
Tissy's Avatar
Tissy is on a distinguished road
dan__wright - Have a look at post #34 and #36 mate, i had the same problem. So reading this may help you out also.
Steve
System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
Tissy is offline   Reply With Quote
Old 01-05-2007, 06:09 PM   #120
i think thats the problem, i downloaded the demo app from the velleman site as i cant find the cd, its probably the updated dll, could someone zip the working version of the k8055d.dll and post it on here please?
Type-R Mini
Lilliput button board (IR sensor extension)...did I fry it? Quack LCD/Display 10 08-22-2008 06:36 PM
i think i burn my USB controller board susuking LCD/Display 0 01-26-2006 12:55 PM
USB Control Board component burned carfreak01 LCD/Display 4 08-24-2005 03:43 PM
Lilliput USB Circuit Board... gleinz LCD/Display 1 01-18-2005 05:09 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
