Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 01-05-2007, 07:55 PM   #121
Tissy's Avatar
Tissy is on a distinguished road
Here you go mate, let us know if it works OK.
http://www.wrx-carpc.co.uk/downloads/K8055D.zip
Steve
System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
Tissy is offline   Reply With Quote
Old 01-06-2007, 06:06 AM   #122
dan__wright's Avatar
dan__wright is on a distinguished road
thanks, put it in the rr dir andx tried to register it but it said it wasnt a valid dll or ocx, is there a oxc to go with it? or it is corrupt.
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
dan__wright is offline   Reply With Quote
Old 01-06-2007, 06:41 AM   #123
307SW_NLD's Avatar
307SW_NLD is on a distinguished road
You dont need to register the DLL because the functions are called directly from the RRK8055.DLL. Just need to be able to find the DLL in the search path. So placing it in the RR directory of windows\system32 should do.
My car: 2003 KIA Sorento 2.5 CRDI AUT
Hardware: EPIA SP13000, 60Gb 2.5"HDD, M1-ATX, Lilliput 7", RADIO SiLABS, K8055 BOARD
Software: Road Runner, FreeDrive, PowerDVD, WinXP SP1
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 50 % DONE
307SW_NLD is offline   Reply With Quote
Old 01-06-2007, 07:03 AM   #124
OK, ive copied the new one to the system32 dir but its still not working, could you post your k8055d as im not sure the one that tissy posted unzipped ok.
Type-R Mini
Old 01-06-2007, 07:28 AM   #125
mugurg is an unknown quantity at this point
dll
here is the one i have in my RR folder and the one in Veleman demo folder . hope that it helps...
My second Subaru skin
Full screenshots second skin
My car photos
CarPC Progress
■■■■■■■ - 75%
mugurg is offline   Reply With Quote
Old 01-06-2007, 10:18 AM   #126
that worked, thanks a lot
Type-R Mini
Old 01-06-2007, 11:17 AM   #127
Now i feel better. Thanks to 307SW_NLD not to me...
My car photos
CarPC Progress
■■■■■■■ - 75%
Old 01-06-2007, 12:39 PM   #128
think the anlog inputs on my board are shot if i connect one or two to the analog ground nothing changes, ive set it the pot on 1 to 3.5 volts and it doesnt change.
it is just me being dumb or does it sound like my board has had it? it was a b grade on maplins so may have just found out why, although they never said it was faulty on the site, presumed it was just a return.
Type-R Mini
Old 01-06-2007, 01:53 PM   #129
307SW_NLD's Avatar
The potmeter only works if you install jumper SK2 and SK3. This will let you regulate the analog in 1 & 2 between 0 and 5 volts
Connecting A1 and/or A2 to analog groud should give a zero reading.
NEVER supply more the 5 volts to the analog in
Old 01-06-2007, 02:00 PM   #130
yeah i have the sk2 & 3 jumpers in place and set it so it reads at 3.5V, then connect 1 to ground, should that not read 5V? the reading doesn't change, stays at 3.5V, tried it with 2 as well and its the same.
haven't tried it with an external input so will try removing the jumper and use a battery
Type-R Mini
Old 01-06-2007, 03:22 PM   #131
307SW_NLD's Avatar
No, when both jumpers are set you can change the readout between 0 and 5 volts using the potmeter. If the jumpers are removed it will measure the voltage between analog in (1 or 2) and analog ground. So the jumpers are just there to test the analog in without supplying voltage to the analog inputs
Old 01-06-2007, 05:18 PM   #132
Oh OK so even with the jumpers on and pot set so its showing 3.5, when i connect 1 to ground it wont change.
also, what is 'clamp' for on the outputs?
Thanks for all your help
Type-R Mini
Old 01-06-2007, 08:58 PM   #133
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Anyone using this board with standby, and if so, are there any resume probs?
Kinda got me thinking about getting one of these, but I only use standby/resume, not hib...
Thanks for any info!
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 01-07-2007, 11:55 AM   #134
ok is this possible, ive got illumination hooked into analog 5, at the moment ive got it on press that it changes gama, the problem is that it doesnt trigger gamma again when you turn the lights off, ive tried it with long and switch, what should i have it on so that it triggers the event when it goes live and when it goes dead?
going a bit further, is it possible to set gamma to dark when live and bright when dead, instead of toggling in case its already dimmed and then i put the lights on it would go bright.
Type-R Mini
Old 01-07-2007, 12:22 PM   #135
ok i was being dumb, i set the wrong one to switch, set 5 as switch and it works ok, is it possible to say switchon=NIGHTGAMMA and switchoff=DAYGAMMA (the day and night gamma are RR existing commands)
realy should of read the documentation lol got it working now, the problem is it will only work in the realys skin,not the menu, the DEAFULT & menu.skin section both have the same content and i havent changed anything else other than making Analog 5 a switch, any ideas?
Edit: Now working fine, i had the 2.1.0.0 dll, downloaded the 2.1.0.3 and registered it, works great thanks for such a great plugin.
Type-R Mini
Lilliput button board (IR sensor extension)...did I fry it? Quack LCD/Display 10 08-22-2008 06:36 PM
i think i burn my USB controller board susuking LCD/Display 0 01-26-2006 12:55 PM
USB Control Board component burned carfreak01 LCD/Display 4 08-24-2005 03:43 PM
Lilliput USB Circuit Board... gleinz LCD/Display 1 01-18-2005 05:09 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
