Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 01-30-2008, 10:12 AM   #76
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Sorry, I don't have a clue. I don't have destinator, so I can't test.
The only thing I can think of is that the diaglog box for city searching isn't clicked or in focus when bringing up the OSK?
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is online now   Reply With Quote
Old 01-30-2008, 07:21 PM   #77
brandensin is an unknown quantity at this point
wow.. Great skin Sal.. Awsome job.. I know this isn't made for ig skin.. but would it be possible to add quick IG buttons for GPS skin? I am not a graphic artist by any means... I think this would mean a lot to those of us using IG for navigation.. Just buttons on both side... 3d, poi, zoom in/out, full, etc... If not, I understand. You already have put so much time and effort into this.. I'll try to add them, but god it's gonna look sucky... Can't image...
Thanks for ur great work!
brandensin is offline   Reply With Quote
Old 01-31-2008, 12:04 AM   #78
Sal R.'s Avatar
Not a problem. I'll post it up in a day or two.
Old 01-31-2008, 01:58 AM   #79
Quincy2003 is an unknown quantity at this point
I don't think that's the case, because Destinator takes only over the last letter I type.
Maybe you can take a look at it. You can download Destinator PN from www.woerners-online.de/destinator/desti.exe
Greets Quincy
Edit: Problem with the navigation solved. I have no idea how, but I showed my install to a co-worker today and out of the blue Destinator copies the entire text from the OSK.
Quincy2003 is offline   Reply With Quote
Old 02-02-2008, 12:52 AM   #80
Sal R.'s Avatar
See post #2 for files to patch an iG specific EXTERNAL_GPS.skin.
@Quincy
Glad to hear it worked out.
Old 02-02-2008, 04:07 AM   #81
U the man Sal... Most of the main buttons work. Looking good...
Thanks... ^^
Old 04-06-2008, 09:59 PM   #82
WassonA is an unknown quantity at this point
Im having trouble with the skin. Im using the most current version of RR and the most current version of the config program. Im getting what you described to be the gdi error and I manually registered it in windows but the problem still exists. Another thing that I noticed/couldnt find is you mentioned a Setup program? Is it still in this version as I know it has been updated a few times?
I will do a search and then edit this post if i find it.
WassonA is offline   Reply With Quote
Old 04-07-2008, 10:46 AM   #83
Sal R.'s Avatar
Does the problem persist when using another skin that uses transparency?
"Setup" is not a program. It's just the set of skin options under "Setup" (Upper Right Hand Button) so you can set your skin preferences.
Old 04-07-2008, 11:12 AM   #84
I couldnt tell you if the problem happens with a different skin, im not sure that the other skins that I use have transparency. I currently use iDrive and iDrive Night Red from Enforcer.
If there is a specific skin that i should try to see if the problem happens there, let me know.
Thanks on the setup information, I wouldnt have found it considering i cant get the skin to load yet.
Old 04-07-2008, 11:21 AM   #85
Sal R.'s Avatar
Try ShockV6.0.
It's a simple skin that uses transparency.
Old 04-07-2008, 11:28 AM   #86
Try ShockV6.0.
I just downloaded 6.1.1
Will do. I should be able to tell you if it worked this afternoon. If it doesnt, what would you recommend that I try?
Old 04-07-2008, 11:41 AM   #87
Sal R.'s Avatar
Well, if Shock doesn't work for you, then something else is wrong with your install and will not allow you to use RR Skins w/ transparencies.
Open rr.ini and check for fastmode=-1
From the sound of it, the GDI error is not specifically related to my skin. And if registering GDIPlusWrapper.dll didn't clear it up, gotta start listing out the specs of your OS.
Old 04-07-2008, 11:50 AM   #88
Yeah... I figured out what the problem was. I didnt notice this and you might not have either. I WAS editing the rr.ini file, but it never occured to me that the config program would overwrite the changes that I directly made to the file. I noticed that even though I had changed the fastmode, when I ran RR it would be changed back. Went into the config program and fastmode was disabled. Re-enabled fastmode, checked the ini, and everything came up. Im having issues with the font, but I havent done any changes to the config.
Thanks for all the help, you gave me ideas to check.
Old 04-08-2008, 10:50 AM   #89
Sal R.'s Avatar
Fonts are all standard windows fonts.
Arial Narrow
Arial
Webdings
Wingdings
Glad to hear you got it worked out.
Old 04-28-2008, 05:31 PM   #90
BartDP is an unknown quantity at this point
MMI and Mappoint : again ...
Hello Sal,
I had the bad luck I needed completly to reinstall my carpc (yes, broken harddisk. Need to buy a SSD)
Now, I can't find why it keeps me showing the wrong screen when selecting Navigation.
Where the mappoint card is expected, I receive this :
Any idee what this can be ?
Thanks.
BartDP is offline   Reply With Quote
