04-28-2008, 05:53 PM
#91
There seems to be a problem loading the MAPPOINT_GPS.skin.
What is the value of gpsmode in your rr.ini?
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
06-10-2008, 04:08 PM
#92
Hello Sal,
A bit late, but here my settings
[GPS]
gpsmode=1
mapmonkeypath=Klik hier om path in te stellen
gpspath=
gpsname=
overspeed=55
gpsport=5
mappointmap=2
mapcountry=
mapcity=
mapautozoom=false
isunits=false
usegpsserv=false
gasfinderautorefresh=false
06-10-2008, 11:41 PM
#93
Quote: Originally Posted by BartDP
Hello Sal,
[GPS]
gpsmode=1
gpspath=
gpsname=
overspeed=55
gpsport=5
mappointmap=2
mapcountry=
mapcity=
mapautozoom=false
isunits=false
usegpsserv=false
Looks okay.
Can you please verify that the MAPPOINT_GPS.skin is in the skin folder?
06-24-2008, 05:10 PM
#94
Looks okay.
Yes, a whole series of MAPPOINT_xxx.skin (7) in the C:\Program Files\RoadRunner\skins\Mmiv2 folder
I made a clean install, roadrunner and MMIv2, on an other PC and I have the same problem.
Something wrong with my MMIv2 install file ? (Downloaded it from the first page)
Do I need to install other skin (supporting mappoint) first ?
Thanks.
07-07-2008, 11:24 AM
#95
Thanks.
I've been pouring over this and I can't see why it's not loading mappoint_gps.skin. I've downloaded the hosted file and did a fresh install of RR on my dev pc and it worked fine even w/o MAPPOINT installed on my pc.
Can you post a debug file so I can see what RR is doing when trying to load Mappoint?
07-07-2008, 05:41 PM
#96
Thanks for replying Sal.
Is there somewhere writen how to create a debug file ?
I don't know how to do.
rgds
07-07-2008, 05:45 PM
#97
In rr.ini:
"debugmode=TRUE"
Save and Close.
Start RR and then select "Navigation."
Close RR.
Go to the RR directory and you should see "debug.txt" in the directory.
Open it, copy & paste the contents and post it so I can take a look at what's happeneing when hitting the gps button.
07-07-2008, 06:06 PM
#98
debug file
07-07-2008, 06:25 PM
#99
debug file
That is wierd. It's executing the the GPS command, but not loading mappoint_gps.skin. It is loading all commands after "GPS" in the MENU.skin, not MAPPOINT_GPS.skin as intended.
Okay.
This is gonna get hairy.
I need you open the menu.skin file in notepad and change this line:
Code:
B10,0,82,87,206,"MMIGPS||MPOPTION1",
to
Code:
B10,0,82,87,206,"GPS",
Save and start RR.
This is a check to see if RR's "GPS" command is working. It should load MAPPOINT_GPS.skin w/o any of the buttons working with some labels missing.
I don't know if you've done this yet, but have you tried opening the mappoint_* .skin files in notepad to see if they are not corrupt in any way?
Truly puzzling...
07-07-2008, 06:46 PM
#100
I did so but whitout result.
When pushing left uper "navigation" butom, nothing happens.
Have verified mappoint_* .skin, all ok and readable
08-18-2008, 05:25 PM
#101
Can you use later versions of Iguidance such as V2009? If not, where can you buy/download v3.0?
Also, how do you disable album art (assuming it is the box next to the text when music is playing)? Thanks
08-21-2008, 10:47 PM
#102
When I switch to the navigation or search screens the text font at the top of the screen (displays music info) is very large; is there an easy way to decrease the size?
Also, i noticed in Sal's pictures that when a song is playing there is a transparent spectrum analyzer visualization. How do you do that?
08-21-2008, 11:03 PM
#103
Yeah. Open FONTSYTLEDEFINITIONS.txt and edit the following lines to your liking:
/,Generic Window App Fonts
/DEFINE DIGISIZE01 14
/DEFINE DIGIFONT01 "Digital Readout ExpUpright"
The file listed above is the master font definitions for the entire skin. You can make changes here and it will be a global change.
For transparent vis, open rr.ini and search for this line
AvsTransparent=True
and make sure it equals "true"
08-21-2008, 11:44 PM
#104
Thank you for the reply Sal.
The font is fixed, but when I went into the rr.ini file i didn't find that specific line. I added the line avstranspartent=true and i'm pretty sure everything is set correctly in winamp and rrconfig. Any suggestions?
Also, I forgot to ask is there a way to eliminate iguidance "popping out" into the desktop when you first press Navigation.
Thanks in advance.
08-22-2008, 10:15 AM
#105
If you miss spelled the line the same way you did here then it will not work.
Check and make sure it is
AVSTRANPARENT=TRUE
For iG you can set RR on top, like this
Bxxxx,"SETTOPMOST;RR;true||GPS"
| Thread Tools |
| Display Modes |
Linear Mode
