Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 08-22-2008, 11:38 AM   #106
maarten74 is an unknown quantity at this point
Thanks for the reply MGD.
I tried typing in the line AVSTRANPARENT=TRUE (as you showed) and avstransparent=true, but it still did not work. In rrconfig on page 2 of music I have it set to Avs window and the "transparent" box is checked. Then when I go to my rr.ini file there is a line "visuname=!Winamp Gen!AVS". Is that correct? It is also set to AVS in winamp.
Also, in regards to Iguidance where to put the line: Bxxxx,"SETTOPMOST;RR;true||GPS".
Thanks.
maarten74 is offline   Reply With Quote
Old 08-22-2008, 11:48 AM   #107
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Try unzipping the attached file and place the contents in the RR folder.
Thanks.
Open Exectbl.ini in the MMIv2 folder and edit this entry from this:
"MMIEXTERNAL","GPS||SHOWGPSEXTLABELS||NAVBTNPI C"
to this:
"MMIEXTERNAL","SETTOPMOST;RR;TRUE||GPS||SHOWGPSEXT LABELS||NAVBTNPIC"
File Type: rar screensaver.rar (183 Bytes, 21 views)
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 10-16-2008, 07:17 AM   #108
pault_barrett's Avatar
pault_barrett is an unknown quantity at this point
Hey Guys, I was hoping you could help with a problem that is occuring.
When im in the audio player and I change the media source from say My Music to Removable disk or anything else, i can choose My Music again but the file listing doesnt change, it stays on Removable disk. So i can cycle through all the media ( removable disk, my music, cd rom) and nothing changes, i need to restart RR but the problem occurs again if i change the media source
pault_barrett is offline   Reply With Quote
Old 10-16-2008, 10:24 AM   #109
Sal R.'s Avatar
Make sure all your directory paths you are referencing has at least one file in it (i.e. a text file).
Old 10-16-2008, 10:40 AM   #110
Ok Cool,
First i wanna say that this is an awsome skin and a appreticate you sharing it to the community considering all the time and effort that went into it. It looks great in my A3
With the library thing, give it a go and advise you of the results.
I was also wondering how to get around the problem where when the PC is rebooted and i come back to RR, i goto radio, the correct station is hear but it shows 87.50
Also is it possible to make the Library for the audio player like the queue where i can swipe my finger over it to scroll down or up instead of trying to touch the scroll bar
And lastly how i get all the utilities back with the cool icons.
Old 10-16-2008, 11:13 AM   #111
Sal R.'s Avatar
What radio hardware are you using?
Go to "Setup" > "Skin" > "Enable iList" = TRUE
Press & Hold on an open slot and it'll open up the Available Utilities Menu for you to choose which apps you want shortcuts to. The option to add your own custom app is all also in that menu.
Old 10-16-2008, 11:15 AM   #112
[QUOTE=Sal R.;1261380]What radio hardware are you using?
Im using a Silabs module with the updated dll for better RDS but it has always done this, even with the included RR dll
Old 10-16-2008, 11:18 AM   #113
Sal R.'s Avatar
[QUOTE=pault_barrett;1261381]
I figured as much. It's a known bug, and I don't know if it has ever been resolved.
What version of RR are you using?
Old 10-16-2008, 11:21 AM   #114
RR is the latest version, only just updated 2-3 days ago. So i guess im stuck.
Oh well, ill work on it and post any progress.
Thanks for your help.
Old 10-17-2008, 09:42 PM   #115
I tried what you suggested and it did not help, do you have any other ideas's
Old 10-17-2008, 10:35 PM   #116
Sal R.'s Avatar
Sorry, I can't duplicate the problem you're having. The only way I can get the audio browser to behave the way you described is if your Music Path only has folders in it.
You must have at least one file in your music path root directory and it must not be hidden.
Old 10-18-2008, 01:49 AM   #117
Ok, ill try a reinstall then, hopefully that will help.
Do you have any info on how to get IGO to mute winamp or the radio when a direction is said.
Old 10-18-2008, 03:15 AM   #118
Sal R.'s Avatar
Nope. Nothing like that done yet for RR as far as I know...
Old 04-05-2009, 08:21 PM   #119
E92er is an unknown quantity at this point
I love this skin! Only need the Gas & Weather added and i'd never need another!
E92er is offline   Reply With Quote
Old 04-10-2009, 01:29 PM   #120
Sal R.'s Avatar
gas & weather are included, but has not been updated to the new standards...at least gas.
