Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 08-03-2007, 05:43 PM   #1
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
MMIv2
DOWNLOAD: MMIv2 Updated 1/13/08
Please go thru the SETUP menu to select your preferences for the skin.
Original Graphics Work by btbe
Designed to work with:
RR v11-4-2007 <- Minimum required!
Winamp 5.13 or version capable of using DJik's
JTFE plugin
Tested to work with:
Silabs USB Radio
HD Radio
iGuidance 3.0
Plugins:
JTFE - DJik
NewHits - Sonicxtacy02
Specturm Analyzer - liquid_smoke
System Manager - quickmic
MP3 Tag Editor - EL CAMINO
Task Manager - EL CAMINO
Updates over beta:
General
- Added specialized VOL+/VOL- to ATT speed volume control that adjusts the max volume using VOL+/VOL- from any screen while att speed is active. Will revert back to orignial functionality when att speed is disabled.
- Incorporated iLists in all Directory and Playlists
Navigation
- Cleaned up track info label placement and are more dependant on Radio/Audio.
Source Menu
- SAVE/RECALL master volume presets when moving thru different media. <-Used to keep the volume from blowing up your eardrums when att speed is disabled.
- Added an image uploader script.
- Added a copy playlist to removeable media script defined in skin.ini
- Added a copy track to removeable media script defined in skin.ini
- Removed JohnWPB's iG script call out for general external GPS applications.
- Audio
- - Audio Browser
- - - Modified user drive selection to cylce through connected media using upper L & R buttons instead of using icons for a cleaner look. Media is checked for readiness using the "drivecheck.exe" script.
- - Audio Queue
- - - Removed ID3 Playlist format option from "Setup" and moved functionality into the Audio Queue list.
- - - - Using the L/R arrows will cycle through different pre-formatted PL formats on-the-fly, including the user default setting in rr.ini.
- - - - Holding down either L/R arrows will turn on/off feature that allows MMIv2 to remember the last displayed PL format. NOTE: This feature also uses the $titlesafter$ variable defined in RR.ini to separate ID3 tag data.
- - Audio Playlist
- - - Option to add current queue list to an existing playlist.
- - - Confirmation window to overwrite an existing playlist under the "Save Playlist" menu.
- - - Added playlist browsing functions to see playlist contents in the "Add to" & "Load" playlist menus.
- Video
- - Video Browser
- Radio
- - Cleaned up the Radio functionality
- Added TV
Setup
- Skin-based, trimmed down, RR & Skin Config and moved RRConfig.exe into the Available Utilities Menu.
- Option to use radio art.
- Removed Close Winamp Option from Setup menu.
- Changed static CD drive shortcut into a dynamic configurable drive. All drive shortcuts are now customizeable.
- Added selectable media menu to choose which media is accessible.
- - i.e. If you don't have Sat Radio, you don't have to have it display in the Source Media Menu.
- Restructured the Media Config, Logo, & Att speed config menus for consistency.
- Restructured theme menu to use preview images.
- Removed Master volume preset from iG auto switch
- Added a Plug-In Loader menu
Utilities Menu
- Restructured "Utilities" menu to be fully user defined. Add only the tools or apps that you want.
- RR Picviewer
- - - Holding down either upper L & R buttons will restore default utilities settings.
- Added a Mileage Log skin.
- Added a Maintainence Log skin.
- Added a Delete USB tool - Will clear your MP3s from your removeable media
- TMS
- My Computer - Browse your computer drives & directories. Current capabilites include copy, move, and delete folder/files.
Layout:
Main Menu
- Media Source Menu
- - Audio
- - - Library
- - - Playlist Manager
- - - Queue List
- - Video
- - - Library
- - MPC DVD
- - WinDVD
- - PowerDVD
- - Radio
- - - Function
- - - Presets
- X XM Sat Radio
- X Sirius Sat Radio
- - TV
- Setup Menu
- - General Settings
- - Skin Settings
- - Music Settings
- - Radio Settings
- - Video Settings
- - GPS Settings
- - Phoco Settings
- - Media Settings
- - Source Settings
- - Logo Settings
- - Themes
- - iGuidance Settings
- - Radio Art
- - MP3 Art
- - Attenuated Speed Settings
- - About MMIv2.0
- Navigation
- - iGuidance V3.0
- - Mappoint
- Utilities Menu
- - 14 User-Defined Utility Slots
- - - Available Utilities Menu
- - - - RR Picture Viewer
- - - - Gas Price Finder
- - - - Weather
- - - X Phoco
- - - - CDRip
- - - - Calculator
- - - - System Manager
- - - - Rainlendar
- - - - TS Scribble Pad
- - - - Windows Explorer
- - - - VAG-COM
- - - - MP3 Tag Editor
- - - - Skin Browser
- - - - Web Browser
- - - - File Manager
- - - - Launch
- - - - Notepad
- - - - RRConfig.exe
- - - - Mileage Log
- - - - Maintainence Log
- - - - Gamma
- - - - Clear USB Tool
- - - - TMS
- - - - My Computer
- - - - Task Manager
Application Specific Skins Included:
VAG-COM v3.11-N
MP3 Tag Editor
Souce Media Features:
Audio
- Audio Player
- - Relies on DJik's JTFE plugin to search through the current playlist. Must have a compatible winamp version. I'm using v5.13 and included in the skin are all the files needed to install the plugin. See above for link and more details.
- - Holding down the attenuated speed control button will take you to a config menu to change att speed related options on-the-fly.
- - To access VISU, hold down the mixer button.
- Audio Library
- Audio Queue - Song queue list
- - Subcommands description as follows (L to R): JTFE Search, "SETNEXT" command, MP3 Copy Plugin, Minus 1, Mixer.
- - Add to Playlist - Add current song playing to current playlist to another playlist of your choice.
- - - Left Arrow/Right Arrow to browse playlist contents
- - - Subcommands description as follows (L to R): Add 1 to New Playlist, Add 1 to Existing Playlist, Add Current Playlist to Existing Playlist, Delete Playlist
- - Load Playlist - Load an existing playlist
- - Save Playlist - Save current song queue list to a new or existing playlist
- - - Subcommands description as follows (L to R): Save to New Playlist, Save Over Existing Playlist, Delete Current Selected Playlist
- - New Hits Playlist - Generate a "New Hits" playlist via plugin. Please see above links for more details.
- - Copy Playlist - Copies the contents of the current playlist to a removeable media defined w/in the skin.
Video
- Video Browser
Radio - Works w/ the Silabs and HD Radio Tuner
- Radio Player
- - Three different modes of tuning frequencies using "<<" and ">>". Pressing the "Preset"
button will cycle the modes from Presets > Frequency Tune > Seek. There is an additional "Tune" to bring up OSK to choose a specific radio frequency.
- - "Scan" is a preset scan mode.
- - Does not use an RR standard radio "playlist."
- - Clicking the frequency will add/modify the frequencies "RADIONAME"
- Radio Presets
- - 14FM and 14AM presets
- - Pressing and holding a preset button will save the currect frequency to that preset
Setup MMI Features:
- General - General RR.ini settings
- Skin - Skin related RR.ini and skin.ini settings
- - "BROWSE BY THUMBNAIL" Enable thumbnail view in the Audio Browser & Video Browser skins. A skin setting.
- - "ENABLE iLIST" Turns On/Off iLists (For slower machines, like mine)
- Music - Music related skin & RR.ini settings
- Radio - Radio related skin & RR.ini settings
- Video - Video related RR.ini settings
- GPS - General GPS related RR.ini settings
- Phoco - Phoco related RR.ini settings
- Weather - Weather related rr.ini settings
- Attenuated Speed - Attspeed related RR.ini settings
- Media - Customize all media shortcuts (drive, path, name)
- - When defining drive paths, clicking on the tool/title bar will allow for more options on drive choices (D:\, E:\, etc.)
- Source - Turn on/off source media that you want displayed. (i.e. If you don't have Sat Radio, you don't have to have it display in the Source Media Menu.)
- Logo - Set main menu logo preferences. Useable formats: Flash or Image. Files MUST be located in the skin folder.
- Theme - Select from 6 provided color themes.
- iGuidance - Set RR native IGv3.0 options.
- Plug-ins Menu - Select which plugins you want to enable/disable
- About - Current RR version and notes about current version of MMIv2
Utilities Features
- 14 Open/customizeable slots for external applications or user-defined skins.
- - Currently has 21 readily available user-selectable tools for use. For more details, please see "Available Utilities Menu".
- - - Holding down any slot of the utilities menu will open the list of available utilies for use.
- - Additional Option for user-defined application and associated skin for embedding external programs. No more hand editing a .skin file or ExecTBL.ini. Can be done w/in the skin.
- - Holding down either tool bar L & R buttons will restore default utilities settings.
- RR Picviewer
- VAG-COM - Audi/VW OBD II Scantool
- - Default measuring blocks are provided. These values are entered into VAG-COM using the SENDKEY command.
- - Holding down the numbered "Blocks" will open the NUMOSK to prompt the user for a specific measuring block. After entering a value, the said button will retain those properties until RR is restarted where it will default back to the original value. To change the default value, open skin.ini and edit "Block1-7" w/ the appropriate value.
- - "LOG" button - Also included is the option to open a user defined text file on the local or an external drive.
- - - Holding down the "LOG" button will open a directory browser to allow you to point to a specific TEXT file that will be opened using the notepad editor. In addition, once the file is defined, a TEXT file indicator will notify you if the file exists. Clicking the toolbar will bring additional drive choices (D:\, E:\, etc.).
- - - This feature is most often used to quickly paste fault log data from VAG-COM to the specified text file (located on a removeable media, i.e. thumbdrive) for diagnosis.
- Mileage Log
- - Skin based mileage tracker. Data are saved/recalled from skin.ini with option to save data to fuellog.csv in the root RR folder.
- Maintainence Log
- - Skin based maintainence log. Data are saved/recalled from skin.ini with option to save data to maintlog.csv in the root RR folder.
- - Delete USB Tool - Deletes all mp3's located in any of your specified removeable media.
- - Robby's TMS plugin
- - - Just replace the "tms_1EMPTY.png" & "tms_1ON.png" w/ your appropriate image if youwant to use a custom image for the TMS skin.
- - My Computer
- - - Browse your computers available drives & directories w/ simple functions included: Copy,Cut, Paste, & Delete files/folders. Skin based & uses mycomputer.exe w/ appropriate commands to perform simple tasks.
Included Applications w/ the skin:
- Moffsoft Free Calculator - Has ticker tape feature
- Filemanager
- Touch Screen Scribble Pad
- Skin copy of Notepad
Included Plugins w/ the skin:
- NewHits Generator
- JTFE
I hope I caught everything, but please post if you have issues.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 08-03-2007, 05:44 PM   #2
Sal R.'s Avatar
Patches
Other Files:
Rainlendar MMIv2 Skin
PSDs
iG GPS Skin Patch
Colors currently available:
Audio Player
Theme Menu
Notepad Editor
My Computer
Logo Browser
More screen caps can be found in my photos.
Old 08-03-2007, 06:54 PM   #3
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
Very nice work. Excellent job
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 08-03-2007, 09:15 PM   #4
Sal R.'s Avatar
Thanks!
Old 08-03-2007, 09:42 PM   #5
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
about time, i was waiting to see your skin, looks very nice, nice job man.
EL CAMINO is offline   Reply With Quote
Old 08-04-2007, 04:04 PM   #6
Sal R.'s Avatar
LOL! Thanks. Yeah, I've been running in my car and testing functionality for the past few months. Wanted to make sure all was neatly organized and easy to navigate.
Let's face it, everyone in here knows that you should not be using your carPC while driving, but I'm sure not everyone follows that rule.
So I kept re-working the skin til it was easy to navigate.
I must have re-coded the skin well over a dozen times, I think, just to get it to this point.
Old 08-04-2007, 07:32 PM   #7
redls1bird's Avatar
redls1bird is on a distinguished road
This is a great looking mmi skin! One request though. can you set it up so that you could choose your own logo for the background? Some skins have this option, and I must admit i dont know how to do it without that option.
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
redls1bird is offline   Reply With Quote
Old 08-05-2007, 01:19 PM   #8
Sal R.'s Avatar
Yeah, there is an option for it.
Go to -> Setup -> Next -> Logo Format
You have the option to use any image file or flash file and can define the size of your logo.
Old 08-06-2007, 10:07 PM   #9
redls1bird's Avatar
Thats great. Thanks for the help Sal. Im about to go give this a shot now.
My worklog
Old 08-29-2007, 12:48 AM   #10
EL CAMINO's Avatar
dont let this skin behind.. come on people, is time to test more great skins out there, like this one, excelent work sal.
Old 08-29-2007, 11:17 AM   #11
Sal R.'s Avatar
Thanks for bump. Back in the swing of things and trying to finish up some skins that are not included so far.
Some updates:
- I've restructured the Utilities menu to remove the "Standard" features and made all the slots user defined. (i.e. If you don't need a web browser, you don't have to have a button for it)
- Modified the select drive menus to include indicators if the drive exists.
- Added new option to add current playlist to an existing playlist in the Audio Playlist Menu.
- New Rainlender skin for a more integrated look.
I'm sure there've been other stuff. That's all I can think at the top of my head atm.
Old 08-31-2007, 09:48 PM   #12
65coupei6 is on a distinguished road
Great skin! Keep it going. Are going to release the PSD's for people who don't like to leave things alone
65coupei6 is offline   Reply With Quote
Old 09-01-2007, 05:57 PM   #13
Sal R.'s Avatar
Sure..why not? I'll post it up next time I put up an update.
The skin image files are flexible enough for those who want to mess around and can't wait. They are all blank template images that is used and re-used in different skin files. The look and functionality are augmented using the IMG commands.
I used nothing but label codes and patched in .pngs to keep the footprint small.
Old 09-04-2007, 04:14 PM   #14
BartDP is an unknown quantity at this point
Audi skin
Hello Sal,
Love this skin.
I'm looking for a skin that best fits the look of my brand new Audi A4 (with the color dig. display between the meters (you know : set 1, set 2, menu) , in place of the red version)
This is the first one who fit : think I will use the white interface, as there is a lot of white also used in this small display
Keep on the good work !!
BartDP is offline   Reply With Quote
Old 09-06-2007, 10:49 AM   #15
Sal R.'s Avatar
Thanks for the kind comment. I'll be updating and working on this skin as often as I can to keep up w/ updates, plugins, and new features.
So, I've updated to RRv9-2-2007 on my test machines, and there was a bug using the LOADIMG command. As a result, if you've updated to the latest RR version, you'll find some icons not loading, as well as, the utilities icon selector skin not working properly. Guino is aware and will have a fix for the next release.
