Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
16:9 (15:9) at 800 x 480 37 35.24%
4:3 at 800 x 600 50 47.62%
16:9 HIGHER THEN 800 x 480 10 9.52%
4:3 HIGHER THEN 800 x 600 8 7.62%
Voters: 105. You may not vote on this poll
Old 11-01-2009, 02:25 PM   #706
Davefocus's Avatar
Davefocus is on a distinguished road
Quote: Originally Posted by Enforcer View Post
Why would you want Gas?
I don't, I want RRPetrol skins in Elite lite theme but I was thinking of the majority forum base and talking the language that would get more response. RRGas and RRPetrol must be virtually identical as far as skins go, surely...
I'm really liking the Elite lite skin theme and have got new mobo etc. which I'm hoping to get all the features I've been thinking of adding but too lazy to do thus far. I need to revisit the icons again to get this sorted once and for all! (or as sorted as it can be.........)
Vauxhall Astra SXi Car PC installed.
Centre console screen fabrication in progress.
Davefocus is offline   Reply With Quote
Old 11-01-2009, 04:57 PM   #707
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Sort of.
Depends on whether the RRGas screen is done with the new RRGas in mind or the old Gaspricefinder in mind.
Enforcer is offline   Reply With Quote
Old 11-02-2009, 03:30 PM   #708
Davefocus's Avatar
Help required please with my Dashcommand obd.skin to get Dashcommand to embed just as Sygic embeds.
I've effectively copied the elite>gps folder and renamed it to obd, keeping other and other-1. I also copied the eternal_gps.skin and renamed to obd.skin and changed the skin line to INC,elite/gps/$gpsmode$$viewmode$.elite to INC,elite/obd/$gpsmode$$viewmode$.elite
Lastly I've added LOAD;obd.skin||RUN;c:\Program Files\Dashcommand\Dashcommand.exe;Dashcommand to my run command in apps.txt
Obviously this doesn't work but can anyone advise me where I've gone wrong. I've messed around so much with it I've lost focus on what I'm trying to do with it....
Many, many thanks.
Old 11-02-2009, 04:05 PM   #709
Confusion Master
Enforcer's Avatar
Many, many thanks.
try
LOAD;obd.skin;OBD;c:\Program Files\Dashcommand\Dashcommand.exe;Dashcommand
Old 11-02-2009, 04:22 PM   #710
Davefocus's Avatar
try
Thanks E. Spot on.
Next stage to is to refresh myself with RRPetrol and RRUpd8 and develop some Elite Lite Themed skins
Old 11-02-2009, 05:10 PM   #711
Davefocus's Avatar
One other thing...I still get no music info in title bar until I select 'Music' when I would expect to have the last track displayed. Any pointers?
Thanks again
Old 11-02-2009, 10:29 PM   #712
darag2358 is an unknown quantity at this point
Thanks again
You mean when you start RR? I get whatever was playing last, or the HD Radio station I was listening to.
Dan from Minneapolis
darag2358 is offline   Reply With Quote
Old 11-03-2009, 01:17 AM   #713
Davefocus's Avatar
Yep, I get nothing until I go into 'Music' with version 1.6.6.
With version 1 I got whatever was playing last, although when I changed album I never got anything for the first track but once that had played or next/prev was used it was ok, but with version 1.6.6 I get nothing useless I go to the 'Music' Menu.
Old 11-03-2009, 08:27 PM   #714
suavecito's Avatar
suavecito is an unknown quantity at this point
Quote: Originally Posted by davefocus View Post
yep, i get nothing until i go into 'music' with version 1.6.6.
With version 1 i got whatever was playing last, although when i changed album i never got anything for the first track but once that had played or next/prev was used it was ok, but with version 1.6.6 i get nothing useless i go to the 'music' menu.
have you tried the patch 2 file ?
eLite Lite has been released
suavecito is online now   Reply With Quote
Old 11-04-2009, 06:19 AM   #715
Davefocus's Avatar
I thought that was purely an album art issue. I've tried it and still no info when opening RideRunner until I go to music but just realised that happens with all skins. It must be a general RR/WinAmp setting that I've missed. Hmmm......
Old 11-04-2009, 08:58 PM   #716
suavecito's Avatar
Did you select the proper Use ID3 Tag in the Music settings? (Music > Page 1 > ID3 Tags Section)
Make sure it is not set to Don't Use ID3 Tags.
Old 11-05-2009, 01:15 AM   #717
Davefocus's Avatar
Set to use Mix V2 with V1............
Old 11-11-2009, 04:01 PM   #718
l1nk's Avatar
l1nk is an unknown quantity at this point
A general question on the skin structure.
I'd like to have some info always shown on every screen of the skin, like the number of visible satellites or the bluetooth link with the phone. There' some way to add these info in a single file of the skin and have them always available in every screen?
l1nk is offline   Reply With Quote
Old 11-11-2009, 04:47 PM   #719
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Yep, use an "include file"
Carwings is a good example (among many others) this is a portion of it's menu.skin:
Code:
RoadRunner Skin RRScreen menu menu_1_OFF.png,menu_1_OFF.png,menu_1_ON.png,menu_1_DOWN.png [ Dummy Label for the skin editor ] L3,1025,0,5,5,255,255,255,12,#DFXFont#,"=.", [ Include File ] INC,Bottomtext.txt
Buttomtext.txt contain the commands (and is in the skin folder); the labels/commands will show in the same exact place in every .skin you put the "inc,bottomtest.txt (for example)
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 11-12-2009, 10:06 AM   #720
tommy_xx84 is an unknown quantity at this point
yes, you could create 1 files (named how you want) and write in all what you want will be visibile in all your screen....
then include this file in all the skin file
example of elite:
in RideRunner\Skins\eLite Lite\elite\active-source you will found a file named
audio.elite
and it contains:
L04,254,29,299,26,181,183,184,16,"HandelGotDLig"," TAGARTIST","scroll-center"
L04,177,2,443,26,255,255,255,18,"HandelGotDLig","T AGTITLE","scroll-center"
if you include this file in all your skin files, you have this 2 label in all the screen...
INC,elite\active-source\audio.elite
tommy_xx84 is offline   Reply With Quote
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Dual video in 1.6 yunusyu Centrafuse 14 05-10-2006 04:17 PM
