Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 07-24-2008, 03:55 PM   #1621
MGD
MGD's Avatar
MGD is on a distinguished road
Quote: Originally Posted by swj123 View Post
It's strange that no one has XM muting on IG4 speaking. Like I said mp3's mute fine with Navicon 2. I have searched everywhere for the answer. Thanks, Mike
Look at the navmon2. you can select any other audio line to mute or lower the volume.
Here,I lower my cd Line where the HD Radio is playing through. Now, when iG speaks it lowers my HD Radio.
MGD is offline   Reply With Quote
Old 07-24-2008, 04:00 PM   #1622
swj123 is an unknown quantity at this point
Thanks MGD, I see the cmd area in Navimon2 but not sure what command would mute and unmute xm audio. Do you have any idea? Thanks
swj123 is offline   Reply With Quote
Old 07-24-2008, 04:02 PM   #1623
MGD
MGD's Avatar
That would depend on the line you're using for the XM box.
Where is it hooked up? Line In, CDPlayer, Mic?
Old 07-24-2008, 04:23 PM   #1624
My Xm is hooked up to Line in.
Old 07-24-2008, 04:26 PM   #1625
dmistry is an unknown quantity at this point
Is navimon2.exe included in RR or is it seperate I have the similar problem that Sirirus does not mute when GPS talks.
Also I am not sure if anyone has figurred out this other problem I am having when I resume from hibernation my Sirius does not start playing I have to navigate to the sirius screen then it starts playing. I have the resumemusic=1 in the rr.ini
dmistry is offline   Reply With Quote
Old 07-24-2008, 04:28 PM   #1626
MGD
MGD's Avatar
Then you would use..
SETVOL;Line In;40
SETVOL;Line In;255
Volume is from 0 to 255. 0 means 0% Vol and 255 is 100% Vol.
Play with the settings to find your volume level.
Old 07-24-2008, 04:31 PM   #1627
dmisrty, Navimon2 is a seperate program from RR. You can find it in this thread.
http://www.mp3car.com/vbulletin/road...nuation-2.html
Old 07-24-2008, 04:34 PM   #1628
Dougw133 is an unknown quantity at this point
Here's the writeup on the DUN button.
Dougw133 is offline   Reply With Quote
Old 07-24-2008, 04:35 PM   #1629
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by Ramanator View Post
go to skin folder, then plugins.txt, then change X,Motion to /X,Motions
save, close and enjoy.
Why add the 's'?
Enforcer is offline   Reply With Quote
Old 07-24-2008, 04:59 PM   #1630
Quote: Originally Posted by Dougw133 View Post
Excellent thanks
Old 07-24-2008, 05:30 PM   #1631
MGD. I tried
SETVOL;Line In;40
SETVOL;Line In;255
in Navicon2 and no reduction in xm audio when IG4 speaks.
Anything else that you can think of? Thanks
Old 07-24-2008, 05:47 PM   #1632
MGD
MGD's Avatar
Did you checked the Box in visual?
Show Guidance Screen during instructions. It has to be checked.
Old 07-24-2008, 06:08 PM   #1633
I checked the box. I didn't get SetVol;Line In;0 to work but I did get Pause/Resume and XmMute to work but there was a several second delay before the sound muted. I wish I could get the Line In command to work. About ready to give up for today.
Old 07-24-2008, 09:09 PM   #1634
DeadlyAP1's Avatar
DeadlyAP1 is on a distinguished road
I am a little bit stuck with setting up speedfan. I ran showspeedfan program supplied with the skin, but all I got was the following values:
SFT0
SFT2
SFT4
SFT6
Each of those values have a temp reading after it. I cannot figure out where to put these SFT# values in the skin so that it represnts the proper value. I see where there are other SFT# values in the code, but I don't know which is which. Can someone give me a hint on where to put them? thanks!
DeadlyAP1 is offline   Reply With Quote
Old 07-24-2008, 09:27 PM   #1635
Ramanator's Avatar
Ramanator will become famous soon enoughRamanator will become famous soon enough
Quote: Originally Posted by Enforcer View Post
Why add the 's'?
Typo, Thank you. Editing Now.
If you cant DODGE em, RAM em.
Ramanator is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
