Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 03-10-2008, 09:12 AM   #151
the_crooked_toe's Avatar
the_crooked_toe is an unknown quantity at this point
Quote: Originally Posted by mnickolson View Post
First thanks and a Great skin. I have every thing working but Traffic Cams 1.2.7 and just seem to be missing something. Trafficams installed in RR dir and DLL's reg.
INI file
[General]
Width=800
Height=586
Delay=60
Country=US
Skin=DigitalFX 3.0
Update=4
Xpos=50
Ypos=150
Keep getting error:
Run-time '76';
Path not found
If I change the skin to default or idrive which are in a sking dir in the Traffic Cam dir it work and used thos skins. Any ideas what I'm doing wrong. I looked at the help file in DigitalFX 3.0 but nothing in there. Any help would be great.
have you installed Traffic Cams yet??
http://www.mp3car.com/vbulletin/rr-p...-v1-2-1-a.html
can you open it in BMV2?
the_crooked_toe is offline   Reply With Quote
Old 03-10-2008, 09:34 AM   #152
mnickolson is an unknown quantity at this point
Yes its is installed in the rr dir under Traffic cam. It will start and work but just will not use the DigitalFX 3.0 skin files. It for some reason will only use the Default or IDrive skin file that cam in traffic cam. I know I must be doing something wrong but for the life of me just can not figure it out. I read through the tc thread but did not see anything that helped me. I was hopping someone here had it working and might know the fix.
2004 Sport Trac PC Project.
mnickolson is offline   Reply With Quote
Old 03-10-2008, 10:52 AM   #153
tigergibb's Avatar
tigergibb is an unknown quantity at this point
Do you have the skin files in the correct folders?
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 03-10-2008, 11:07 AM   #154
DigitalFX 3.0 is c:\Program Files\Road Runner\skins\Digital 3.0. The skin files to traffic Cam are in that dir as I have found nothing to say move them. Now one thing in reading the info on Traffic Cam it says the skin files should be *.eskin and I see the ones in DF are just .skin but I tried renaming them. but that was a bust. Just would like it working with the DF skin files but I may just live with it. I had seen outer post here were others were having problem and just hoping I not the only one.
Old 03-10-2008, 11:17 AM   #155
tigergibb's Avatar
C:\Program Files\Road Runner\skins\DigitalFX 3.0
-Traffic.skin
-trafficcam.skin
-trafficcamViewer.skin
-TrafficTest.skin
-traffic_cam.eskin
-traffic_search.eskin
C:\Program Files\Road Runner\Traffic Cams\skins\DigitalFX
-skin.ini
-traffic_cam.eskin
C:\Program Files\Road Runner\Traffic Cams\Trafficcams.ini
[General]
Width=800
Height=600
Delay=60
Country=US
Skin=DigitalFX
Update=2
[Cams]
Old 03-10-2008, 11:29 AM   #156
Hmm no traffic_cam.eskin or traffic_search.eskin. Strange. I will rerun the installer. Woulder why it did not install them.
Here is what I get
Old 03-10-2008, 11:36 AM   #157
Thanks for all your help tigergibb.
Old 03-10-2008, 11:47 AM   #158
tigergibb's Avatar
So I assume you got it working?
Old 03-10-2008, 11:49 AM   #159
Nope, even went and download a new copy and a some of the files you have listed are missing. Do you have a pre release or something?
Old 03-10-2008, 11:56 AM   #160
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
I have just installed on a PC, and yes it looks like the trafficam eskin files and graphic files that go into the plugin skin folder are not there.
Enforcer is offline   Reply With Quote
Old 03-10-2008, 11:57 AM   #161
Ah cool so I not lossing my mind or what little is left.
Old 03-10-2008, 12:17 PM   #162
Confusion Master
Enforcer's Avatar
BTW John, what is "Internal Traffic Cams" ?
Old 03-10-2008, 12:28 PM   #163
jbradshw is an unknown quantity at this point
Quote: Originally Posted by jbradshw View Post
OK I found out where this setting is at - it's in the Weather_Interactive.skin file. You'll see the latitude/longitude coords in there as well as the zoom level.
I have another issue - I changed the general.ini file so the skin will show for 800x480 which works fine from what i can tell, except for one thing: The main menu buttons at the bottom, the print is too large (except for the MENU button on the far left) and part of it is displayed off of the buttons themselves. Not sure if this was supposed to get scaled down or what not. I didn't know if the font size was a RR setting or a skin setting but I looked all over the place to try and find where to change it. It seems the rest of the text in the skin at that altered resolution looks ok, though overall I'd like to lower the font size a notch or two.
Ha nevermind I found a thread talking about this as well..
jbradshw is offline   Reply With Quote
Old 03-10-2008, 01:14 PM   #164
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
That was a typo on my part, it has been fixed. Also, not being able to include the whole International Traffic Cams package with the skin, instead of just not including the plugin, I forgot to include the skin! Sorry, It has been fixed and will be out with the new installer here soon,
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 03-10-2008, 01:16 PM   #165
dmistry is an unknown quantity at this point
Ok as everyone has stated a thousand times we all LOVE DFX3.0 one thing that could be slightly more appealing is the ICON's. The way John has his skin coded allows us to swap out these icons very easily.
Now my question I have been able to download a bunch of icons (free) from the net, is anyone interested in taken them and shrinking them down to 52x50 pixels and making them transparent. My photoshop skills are non-existant so I am not up for the challenge. Of course all images/icons will be shared by all should someone decide to take on this task.
dmistry is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
