07-26-2008, 11:55 AM
#1696
Just an FYI:
To restore the font issue I had to copy windows\fonts from another computer over to mine. Otherwise Paint.NET wouldn't work. Didn't notice if anything else was effected or not.
07-26-2008, 12:42 PM
#1697
Confusion Master
Quote: Originally Posted by nst6563
is there a mirror to download from? maybe torrent? no matter what machine I've tried to download from, it only gets to 18.7MB and stops - trying to run results in an error stating it's corrupt. Tried from my desktop at home, my laptop at work, and my car.
Disable your AV
07-26-2008, 01:01 PM
#1698
Quote: Originally Posted by Enforcer
Disable your AV
omg that did it. I don't run AV on my desktop, but I run an Endian Firewall box and the scan size was set to 20mb. Changed it to 0 so it scans everthing no matter what size and it went right though.
thanks!
07-26-2008, 01:20 PM
#1699
Ok john have a few issues that I found if you could help with your new skin for the Garmin gps software wont load the app if I change the gps skin back to iguidance the Garmin software loads up but it wont load in the Garmin skin, also when I click the music button and click the browser button I dont get any of my music files and it frezes instantly. I was using your 3.0 skin and everything worked fine I had to modify the skinto use my Garmin software but everything worked fine until 4.0 install oh almost forgot when you go in and try to shage the buttons I tried to get the rrmedia button but it keeps installing the rescan button instead, But despite all the problems i'm having the skin is just hot. thanx for the work also i'm cliking away on those sponsor links on your site.
07-26-2008, 02:52 PM
#1700
Nice job John!
This isnt so much a problem with DFX4 as it is RRMedia...
My problem is that when I hit 8726 songs RRMedia crashes...
Am I hitting a limit within RRMedia or what?
Anyone else add more than 8726 songs???
07-26-2008, 02:58 PM
#1701
I'm over 10,500 and it works fine.
07-26-2008, 03:02 PM
#1702
Hmm...its weird that it keeps crapping out at 8726....The total amount that RRMedia is trying to scan is over 13,000...any ideas on what to do?
07-26-2008, 03:13 PM
#1703
Confusion Master
Check the 8726th or 8727th song, could be an issue with the filename or the ID3 tag.
07-26-2008, 04:34 PM
#1704
First off, great skin! Thanks for all the hard work you all put into this!
Now, a problem.  Why in the music browser, when I click on a song, it wont play. I have to press the 'Play Select' for it to work. Also, the next and prev tracks dont work. It plays one song and then stops.
07-26-2008, 04:42 PM
#1705
John you've out done yourself yet again. Great Job. And the Database is sweet (props to you Blue). However my Db scan doesnt finish and i keep getting this Autoit error. Been at this all day and cant seem to squash this bug. Any suggestions?
If you cant DODGE em, RAM em.
07-26-2008, 04:52 PM
#1706
I'm at 28,000 and the database completed in about 5 minutes.
07-26-2008, 05:08 PM
#1707
Quote:
GPS has been working since version 2.0. You need to have a zips.dat file in your Road Runner root directory. (The skin installer installs it if it does not exist already) if that is in place, and you have a GPS signal, as well as RR configured for a GPS port (If you show satellites connected in the gauges screen), then tap the top display area on the gauges screen. The entire area is a hot spot to test the zips.dat LOCATE feature. If the cities and such fill with information, then it is working. You just need to add:
localdatacaptureinterval=1
To the RR.ini to update the information automatically. The "1" above means it will update the city labels every 1 minute.
Thanks, I got confused remembering the age old issue with Ziplocater.dll. I will be sure to check/correct those suggestions.. The skin kicks a%#. I might be getting a new mobo and processor to handle it though
07-26-2008, 05:15 PM
#1708
damn.....well actually that makes me feel better...now I just have to figure out which file 8726 is....anyone know of a way to view some sort of log of the music -> SQL DB process?
07-26-2008, 05:26 PM
#1709
Show off
07-26-2008, 05:27 PM
#1710
Sounds like you only have 1 song in your play list.
| Thread Tools |
| Display Modes |
Linear Mode
