Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 07-26-2008, 09:24 PM   #1726
Dougw133 is an unknown quantity at this point
Oh also, my album art now flashes at start of song then disappears. I have tried everything and never had this issue before... I'll keep hacking away I'm sure it's on my end.
Dougw133 is offline   Reply With Quote
Old 07-26-2008, 09:38 PM   #1727
barnyard is an unknown quantity at this point
Quote: Originally Posted by Machinehead View Post
I took the work of the person that fixed the sat skins for DFX 3 and tweaked the DFX 4 files. Sat and Ter bars work like a charm now.
My tiny contribution to an outstanding skin.... now I just have to find time to get my setup updated!
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is offline   Reply With Quote
Old 07-26-2008, 10:12 PM   #1728
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Sorry for not specifically giving credit where credit is due.
Machinehead is offline   Reply With Quote
Old 07-26-2008, 10:40 PM   #1729
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Just for the record, everything, (and I mean EVERYTHING) was broken when I installed DFX4 to a non standard path. After I installed it to the default (c:/program files/Road Runner) everything worked great. It sucks that its hard coded to only run from the default directory, but when its there it runs good. I had many of the similar problems mentioned when I was trying to run it from C:/Devel/RR which is where I like to have my RR install.
blk02si is offline   Reply With Quote
Old 07-26-2008, 10:42 PM   #1730
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Any body know where the "shuffle/repeat" button is?
treetop777 is offline   Reply With Quote
Old 07-26-2008, 10:46 PM   #1731
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
@treetop
Jjust click the indicators
@blk02si
There is no prob with a using a diff path, I run RR out of a "RR Testing" folder both at home and at work.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 07-26-2008, 10:47 PM   #1732
Well, I had a lot of problems after trying to fiddle with "MJS's" RR and HD radio updates. I uninstalled RR and all my DFX skins 2,3 and 4. Reinstalled RR, applied bete EXE (weather fix) and DFX 4 again.. I came up with those com errors with the data base you guys were talking about. My HD radio works with that "PCR" program but not in the skin. So, I am at witts end for today. I'll try tomorrow.
Old 07-26-2008, 10:59 PM   #1733
The Curator
Blue ZX3's Avatar
For anyone with a that get a COM error message, please please give some details, what the box says, what you were doing at the time the issue occured ect..ect
I can only look to see where there might be a bug if i know more info, thanks!
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 07-26-2008, 11:18 PM   #1734
Ramanator's Avatar
Ramanator will become famous soon enoughRamanator will become famous soon enough
Blue, Is Autoit error considered an Com error?
If you cant DODGE em, RAM em.
Ramanator is offline   Reply With Quote
Old 07-26-2008, 11:18 PM   #1735
RR.GML.
So doing a fresh install of the latest RR fomr the "New RR installer and Updater" sticky I noticed there was no longer an RR.GML file for girder in it...I cannot find it anywhere.. Doe's anyone have one?
I put down the sword for tonight. My hair has been pulled out. I will try to make it happen again tomorrow and let you know. If I recall there was a lot of unknown text and some if it looked asian.
Old 07-26-2008, 11:21 PM   #1736
The Curator
Blue ZX3's Avatar
RR.Gml
See here!
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 07-26-2008, 11:23 PM   #1737
Oh...THANK YOU BLUE!
John, as I stated I uninstalled my old FX's... Should I reinstall DFX3 for any files 4 might need? Or is ok to run without it's little brothers help?
Old 07-26-2008, 11:26 PM   #1738
The Curator
Blue ZX3's Avatar
All DFX x.0 skins do not depend on each other as far as i know.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 07-26-2008, 11:30 PM   #1739
The Curator
Blue ZX3's Avatar
Uh..yes and no. Yes as they are both autoit errors. A COM error means that there was a problem with the communication between the two apps. The autoit error is more of a standard type error, with some reasoning at the bottom of the msgbox to why the error occured.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 07-26-2008, 11:41 PM   #1740
Ramanator's Avatar
Not trying to push ('cause i posted this earlier) But this came up on me while tring to run your app: "Line-1 Error: Subscript used with non-array variable". Out side of that what did work is amazing.
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
