07-27-2008, 01:58 PM
#1771
The Curator
Users that are having issues with the new media, please be patient as I'm dealing with one users issues at a time, so that I can check and make the appropriate changes to prevent further errors in the future.
Right now I'm dealing with the error that both Ramanator and swj123 are getting.
07-27-2008, 01:59 PM
#1772
High Voltage
Ok I figured out the path issue, DFX4 needs the "skins" folder to be inside the RR folder. The way my system is setup is c:/devel/rr and c:/devel/skins If I move the skins directory to c:/devel/rr/skins then it works. Just a heads up for people that don't use the standard paths.
I have tested the skin on the newest build of RR and everything works good except for the weather and the gps gas skin, it may be a configuration error on my part but these two menus appear to be the only one's that didn't work "out of the box"
I tested on mitchjs's RR build and when running on that code the main screen logo is broken. No matter what you choose it doesn't display anything.
HDradio is working good for me on either RR ver.
Overall a very stable and solid build, My favorite feature is being able to reorder the menus seamlessly. Great work!
07-27-2008, 02:12 PM
#1773
The Curator
Quote: Originally Posted by utd09bry
i used to like to add my entire music collection to a single playlist and shuffle it. is there a way to add all the songs to a single disk? previously, when i would pull up the music browser one of the line options was like the root option... something like "......" at the top of all my artist folders. if i selected that and then chose to play album it would add the entire directory. i hope that made sense...
i can't seem to do this with the new disk system. any ideas?
thanks again for all you (both of you) have done!!!!
First off, putting everything in one list to me makes absolutely NO sense, but that's just me...
Here is one work around, go to browser>search>all then just enter a space, when that gets done, click the manage playlist btn and add the [searchresults] to a disk..
07-27-2008, 02:17 PM
#1774
looks like that will work.
it makes sense to me because i like listening to my entire collection on SHUFFLE.
thanks for the help Blue!
07-27-2008, 02:32 PM
#1775
Confusion Master
07-27-2008, 02:34 PM
#1776
Me too. My usual setup is my entire library playing on shuffle. Or better yet, I can randomize the list and turn off shuffle so I can always see what's coming up next.
07-27-2008, 03:09 PM
#1777
Quote: Originally Posted by kbreeden
Okay, you need to create a folder called playlists somewhere. Then in the music settings portion of RRconfig in Playlist Path point to the playlist folder you have just created. Then in the music settings portion of RRConfig make sure .m3u is included as an audio file type. And just for good measure you might want to go ahead and create a playlist to make sure things are working.
Still does the same exact thing. Like I said, I dont want to use the playlist option or whatever. I just want to select the album from the list and play it ALL, or be able to skip songs. No playlist! What is different with 4.0 and all the previous versions? I think I'll trash 4.0 and just keep using 3.0. That version works.
EDIT: Got it working. Just went in and changed where the 'browser' button sent me. Instead of sending me to audio_browser_settings.skin, I made it where it sent me to audio browser.skin.
07-27-2008, 03:15 PM
#1778
Quote:
Mitch did a great job of fixing audio switching for what was being used (radio, MP3, Satellite ect). The problem is that it is build off of the 11/02/07 souce code, and this is before the dynamic sliders and a lot of other new RR features were added.
As far as getting HD radio to work, this is not a skin relates issue. I use the HD radio skin here, and it does work well with Mitch's cable, and the HD hardware. If it is not working, it is not because of a skin, but is because of incorrect ini settings, non-registered Dll's or something else.
It's kind of like blaming Microsoft because you open a Word document, and the fonts are the wrong size or are alligned incorrectly.
I understand completely, and I am not blaming the skin at all. I just get more help in here than any where else on these forums. Seeing the HD radio discussed on here mnay times befroe I thought maybe I could get a quick tip to help me out. I'll keep it out of the thread now, my apology.
Everything is still running great. Can't thank you and Blue enough.
07-27-2008, 05:58 PM
#1779
The Curator
The reason that you are having problems lies in the fact the 4.0 now fully uses my RRMedia plugin to manage the audio media. And yes it is a bit different than the old way of how the old browser worked. And going by what you posted to me, sounds like you do not like change of any sort, good or bad. This is also v1.0 of my plugin and many things to be added and tweaked to make it as user friendly as possible, its just not quite where you want it to be like at current release.
The simple solution to your problem would have been to p&h the browser button and then selected to use the old (now outdated) audio_browser method of playing your tunes. Once selected it saves you choice and always uses that for the browser button cmd
07-27-2008, 06:27 PM
#1780
Hope this doesn't ruffle any feathers, but as with any new software, or anything else new for that matter, there's always going to be a learning curve. I believe that the implementation of a db in DFX4 was a greatly needed improvement. Not saying that DFX3 had anything wrong with it, but I am seeing greatly improved seek times, the ability to set up a virtual 60 disk changer (using the switch user function of course), setup my music by mood, etc.
07-27-2008, 06:37 PM
#1781
The Curator
Good to hear that you are using everything together to get the most out of all the work that has been but in and its working well.
07-27-2008, 06:58 PM
#1782
Super Moderator
Quote: Originally Posted by Dougw133
I noticed one other thing. It seems iGuidance loads smoother, kind of a fade in. When you toggle the layout to something other than default, and then hit menu to return to main skin menu it de-toggles it first. So you have to hit menu twice..
This is fixed for the next release, was a button code problem....
Hmm, I see a clock in post 1752, so apparently not everybody is having the no logo problem a couple of us have mentioned. Any thoughts?
It has been mentioned a couple of times, that the flash logo's, clocks and such do not work with Mitch's RR version. Try the last beta released on 05/27/08 and they should work for you.
07-27-2008, 07:07 PM
#1783
Yes, definitely a little bit of a learning curve, which is a good thing IMHO. I didn't even know about the option to use the old method (not that I'd want to) until I started pressing buttons and stumbled upon it. You thought of everything didn't you, Blue? The database is amazing.
One thing I've noticed is that I'm always at 100% CPU load when on XM. All the other times I'm at less than 50%. Anyone know what might be going on with that?
07-27-2008, 07:12 PM
#1784
Can anyone give me a hand when I try to use the audio browser roadrunner completely freezes up my system.
07-27-2008, 07:14 PM
#1785
The Curator
Again, thanks for those kind words, and yes I did try to think of just about everything that i could while I'm coding away... I'm not done with it yet either!
| Thread Tools |
| Display Modes |
Linear Mode
