07-29-2008, 01:47 AM
#1831
I've got the same screen as this guy with all the numbers showing on the bottom instead of icons
Also, the biggest problem is only the music button works and all the other buttons on the main menu are dead(no response)
I'm using the latest RR with digitalfx 4.0. I also installed the latest flash. What could be the problem?
07-29-2008, 02:13 AM
#1832
Fonts
07-29-2008, 02:19 AM
#1833
The Curator
Quote: Originally Posted by Ramanator
Blue, Do you know if the guys with this error, error out at the same spot?
Would you check your playlistpath in your rr.ini and post weather it has a trailing backslash? Willing to bet that it doesn't have one...
07-29-2008, 02:22 AM
#1834
Here's mine:
playlistpath=C:\Documents and Settings\My Documents\My Music\
If you cant DODGE em, RAM em.
07-29-2008, 02:27 AM
#1835
The Curator
well that deserves a ....
07-29-2008, 02:35 AM
#1836
How much did u say the bet was
07-29-2008, 02:46 AM
#1837
One more: Movie times is finiky and managed to crash RR twice. Also the pad to enter zip code, the zero is in the middle.
07-29-2008, 02:57 AM
#1838
I cannot get the interactive weather to zone over my location. I changed the Lat and Long in my skin file and It is still hover over Kansas? Also can the traffic map be changed too? Thanks.
07-29-2008, 07:59 AM
#1839
Quote: Originally Posted by JohnWPB
I am working on the color chooser now, and will have it all fixed up. Can you tell me exactly what menu's are not lining up? RR is supposed to scale and locate the pop-up menu's depending on the current resolution.
The overlay image (see screenshot) is shifted to the right and about 25% too big. If I try to choose a color in about the top ¼” of colors, then choose to set one of the attributes to the color, it changes to the color of the button that you click on.
RM_Browse_Mode.skin was also offset, but I fixed this by changing the POSX to 120.
I haven’t come across anything else yet, but I’ll let you know if I do.
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
07-29-2008, 09:06 AM
#1840
Quote: Originally Posted by qha_vn
do you have minimum system requirements to use your great DigitalFX? my pc seems not strong enough to host this skin. on my pc, it can not load the skin fully, buttons just appear when i hoover the mouse pointer over them
by the way, i use single pc board with 512MB RAM, 1GHz VIA Eden processor
I had a similar issue yesterday when I tried to load the FX 3.0 skin. Everything was grayed out until I ran the cursor over it. I don't know what the cause was, but I don't think it was lack of computer power. Have you tried reinstalling the skin and maybe even Road Runner?
07-29-2008, 10:25 AM
#1841
I loaded FX4.0 yesterday and the buttons would not appear until I ran the cursor over it. I was running FX3.0 fine. I was about to reinstall Flash but turns out after I changed the colors for the buttons everything was ok.
07-29-2008, 10:43 AM
#1842
^^Same issue
07-29-2008, 11:06 AM
#1843
I honestly don't know what the issue is here.... You want to play a whole album? Its actually quite simple really.... Select an album, and click the "Play Select" button. That's ALL there is to it, it could not be easier.
On top of that you have a LOT more power now! You browse by artist for instance. Select say, "John Cougar", and then hit play select. It will play every single song that you have in your collection for all of his albums, as well as songs that are on any compilation album.
You can then browse by genre, select Rock, and hit play select. It will play every song in your collection in the genre "rock"
NONE of these require you to make any playlists in any way.
What you probably did not know, with the "old" browser, when you played an album, it did indeed create a playlist in the background, whats called an "On the fly playlist". This is how RR keeps track of the songs on that album. Try adding a album with the old browser, and you will see the playlist contains: xx songs above the album art
My system does not work this way. Is there some setting that needs to be activated for this to work? When I hit play select after doing a searck for say 'pink floyd', only the highlighted song will play. Same as with the whole list. If the whole music library is displayed and i hit play select, only the highlited selection will play. I cannot select all and play select.
07-29-2008, 11:26 AM
#1844
You're not talking about the same thing. In John's case he's listing his music by artist and then hitting 'play selected' which will load all the music sorted under that artist. In your case you're picking a specific song within a search result, and that will only load that song.
07-29-2008, 12:10 PM
#1845
Machinehead is correct. The search results screen and the browser screen are two different things and work differently. In the browser screen you can browse through genres, artists, folders, etc. and when you find one you want to play you hit play select and the artist, album, folder, etc will be loaded into a new playlist.
If instead of browsing you want to search for an artist, album, etc. you hit search and that will display your search results. Your search results are not a playlist and can only be played one at a time. In order to play your search results you need to hit manage playlist and then load the playlist that says [searchresults]. Now your search results are in a playlist that you can use like any other playlist.
| Thread Tools |
| Display Modes |
Linear Mode
