Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 07-29-2008, 09:07 PM   #1861
Dougw133 is an unknown quantity at this point
As for FLAC files, blue, it still won't work. If I play a FLAC in winamp stand alone and, then open RR it will show the info. But if I seek it out within the skin/rr, the folder is there but the files do not list.
Dougw133 is offline   Reply With Quote
Old 07-29-2008, 09:10 PM   #1862
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
If using the folder browsing mode, do you have .flac in your audio type settings in the config?
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 07-29-2008, 09:21 PM   #1863
hmm....Good call. Let me check, girl has the car. Willing to bet that would be the case..
Old 07-29-2008, 10:33 PM   #1864
kbreeden
Wow, when did full screen viz start working? I just tried it and it worked great, other than the fact that it was a little off center which can probably be adjusted in Winamp. It's probably something that has been working for a year now and I just missed it.
Also, I really like being able to include the current playlist on the menu screens. Good thinking, John.
kbreeden is offline   Reply With Quote
Old 07-29-2008, 10:39 PM   #1865
overlander's Avatar
overlander is an unknown quantity at this point
should the button editor be working in 4.0? Won't run for me. errors out.
Also, I can't get cdrip to work, despite following all help files. the new exectbl.ini file is very different now. anybody know how to modify it to get cdrip to work?
overlander is offline   Reply With Quote
Old 07-29-2008, 10:58 PM   #1866
The Curator
Blue ZX3's Avatar
FYI. The old DFX Button Editor that I created WILL NOT work with 4.0!
Did you use the new one? The installer puts a link to it in your start menu, or you can find it in the helper files folder.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 07-29-2008, 11:09 PM   #1867
overlander's Avatar
That worked like a charm! Any thoughts on cdrip? I've read through everything, and this is what I get with running it. I've installed aspi (to incude the nero version), and made the mods (to include the install.bat misspelling correction). still won't run.
Old 07-29-2008, 11:33 PM   #1868
RanDJ8487 is an unknown quantity at this point
Please see my work-a-round a few posts up that tells what you have to untill I get out another update to hopefully fix that...
Okay tried everything. I've even uninstalled all DFX installs, uninstalled RR. Deleted the RR folder with the exception of rr.ini. A lot of problems have fixed bc I only installed 2.5 and 3.0 but theres some sort of auto run feature still causing problems. Any ideas? I have not yet set the one file to recognize which was my CD drive. Thanks
RanDJ8487 is offline   Reply With Quote
Old 07-29-2008, 11:33 PM   #1869
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by Dougw133 View Post
As I stated earlier the entry pad for movie times, the number 0 is off. It is off center in the Vehicle Maintenance skin as well. I assume it's global. Just lettin ya know, not complaining.
The Google traffic is an awesome addition. How do make it default to my location, as well as the live weather?
Thanks..
Yes I got the NumOsk problem, it an all other bugs mentioned up to this post have been fixed, or are in the process of being fixed.
As for Google Traffic, The GPS location was not completed when I release it. It will be for the next version.
Noticed that when in CD changes skin, when you hit menu it goes to iGuidance and not main menu.
I do not see how this is possible. It will go back to whatever screen you were on before. The command on the Menu button on that skin, just sends you back to the skin you came from.
If the Visu is a little off center, this is usually indication that Winamp 5.13 is not being used, but another version. Strange as it may be, the only recent version of Winamp, that the visu shows up to where it is supposed to, is 5.13. Any other version, and the visu will appear over and down about 100 pixels each. Though all features with other versions work ok, and the visu works with other versions, it just will not show up where it is defined.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 07-29-2008, 11:52 PM   #1870
spamminator is an unknown quantity at this point
(Asked further up, but I think it got lost as part of another post)
John, how hard do you think it would be to create another Menu layout option, where the center graphic gets replaced by the currently playing album art? Something you've considered? Working on...?
spamminator is offline   Reply With Quote
Old 07-30-2008, 01:08 AM   #1871
TimmyM's Avatar
TimmyM is on a distinguished road
On the Rescan Database menu it shows "Ratings Playlist" twice.
Also shows "Database Complete" and "Database Ready", out of curiosity, whats the difference?
TimmyM is offline   Reply With Quote
Old 07-30-2008, 01:37 AM   #1872
That's great, I love the feature. Any way I can temporarily edit the script or something to default to my location?
As for the Disk menu going to iguidance.. Well I am sorry to say that is what is happening, only when I go to it from a menu button.
Any how.. Everything else is running great. You did a hell of a job. My girlfriend wants you to stop making skins so I will come inside and out of the car.
Old 07-30-2008, 02:18 AM   #1873
Well I don't see FLAC as an option in the config.exe however adding it manually in the ini file worked great. Thanks
Old 07-30-2008, 02:23 AM   #1874
TimmyM's Avatar
I believe in the config it's under music, page 1, Audio File Types. You would add it there.
Old 07-30-2008, 03:19 AM   #1875
Yes I understand this, thanks.. I was stating that it wasn't. I know where to select WMA, MP3, WAV etc.. However FLAC is not in that list. Adding it manually to RR.ini works
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
