Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 08-13-2008, 08:34 AM   #2161
ajamils is an unknown quantity at this point
Quote: Originally Posted by navputer View Post
I had these same issues - See post 2111 (page 141).
Thanks for the help. I downloaded the latest version of RR and will try it out later today. As for calender, I have not been able to find the latest version. If you don't mind, can you please post the direct link to the thread or Rainlendar itself ?
04 Accord Coupe Carputer
ajamils is offline   Reply With Quote
Old 08-13-2008, 10:04 AM   #2162
k1hog's Avatar
k1hog is an unknown quantity at this point
I know is is some where, but can't fine where? When I go to gas prices, RR hangs, is there a fix?
Johnnie
k1hog is offline   Reply With Quote
Old 08-13-2008, 11:13 AM   #2163
aerotight31 is an unknown quantity at this point
CD Changer Problem
First, great skin, John! I created a disk in the disk changer. I used 5 cd's from one artist to make up the disk. When I start playing it, I go into playlist, sort playlist, and choose randomize. It works great, until I turn the truck off and then back on. The playlist still looks randomized, but it is playing the songs in the order they were put into the list. The song highlighted isn't what is playing. Any ideas of what's going on?
aerotight31 is offline   Reply With Quote
Old 08-13-2008, 03:55 PM   #2164
notion's Avatar
notion
Zips.dat
Is the zips.dat file a limited list? Can it be added to or updated from a 3rd party source?
The reason I ask is that the guages and gas prices page keep reporting me as being in the next city over from where I live (bit of a problem when navigating to nearest gas stations). I was assuming that this is happening because that's the nearest zip code in the database to my GPS coords. I added the 1 minute update command to rr.ini but the Zip code doesn't seem to want to change even though GPS is working fine in iG4 and with the skin's GPS Speedometer, long, lat, height and satellites locked (all set up with XPort)
I'm using a SirfStar 3 USB GPS unit
Also, different tangent...
Quote:
Question: Why does album art flash at start of song then disappear?.
Solution: You do not have Embedded album art in your MP3's. Go into the plugin manager in the skin settings, and turn off MP3Art.
Does this mean that RR+DFX 4.0 displays embedded album art now? I guess it does, if so do I have to choose any IDTag specific settings to ensure they all show up?
DFX 4 once again moves the bar up for Roadrunner, this skin looks fantastic and the embedded music DB is FRIGGIN' SWEET!!!!
Thanks guys
350z Roadster,
Lilliput 7" touch, Opus 250w, 160gb, AMD3500+, 1gb ddr400, geforce 6500 pcie, SiRF Star 3, Wireless G, Sprint CDMA, Bluetooth, Creative iCam Pro, RR, iG 4, Digital FX 4.0
notion is offline   Reply With Quote
Old 08-13-2008, 05:37 PM   #2165
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Yep, notepad.
Record the coordinates of where you are, then open zips.dat in notepad then either find the city name you want to show when you are at those coordinates and edit it's coordinates OR find the coordinates and edit the city name (i don't remember exactly).
treetop777 is offline   Reply With Quote
Old 08-13-2008, 06:02 PM   #2166
E92er is an unknown quantity at this point
Looks Great!!!
E92er is offline   Reply With Quote
Old 08-13-2008, 06:15 PM   #2167
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by treetop777 View Post
Yep, notepad..
shhhhh! blue will hear you.
Enforcer is offline   Reply With Quote
Old 08-13-2008, 06:54 PM   #2168
Maddominican's Avatar
Maddominican is an unknown quantity at this point
I am getting an Autoit Error 'Script could not be found' or something. I'm @ work and can not remember the exact error. What is that error about? It happens when I switch back from Gauges, and sometimes when I switch to the main screen from any screen.
Maddominican is offline   Reply With Quote
Old 08-13-2008, 07:02 PM   #2169
notion's Avatar
notion
I had the same problem, turned out my RR install was in a folder called 'Roadrunner' rather than 'Road Runner' so the pathing on the DFX4.0 installer had some problems installing everything in the right place, even if you change the install path in the DFX4.0 installer.
I fixed mine by reinstalling RR to the correctly named 'Road Runner' folder and then reinstalling DFX4.0, this helped clear up some other little issues I had with Gas prices routing to IG4 also.
350z Roadster,
Old 08-15-2008, 07:25 AM   #2170
Does the new rrgas version work now for this theme? What about weather?
O yea, and the skin won't let me turn on music videos to my rear screens while driving, how can i disable that?
EDIT: Knew I was forgetting something......in the Gauges portion, I got it running, but it's showing my speed to be ~20mph over what I'm driving at.....
Old 08-15-2008, 08:53 AM   #2171
marteline's Avatar
marteline is an unknown quantity at this point
Blue ZX3 talked that he will not use notepad anymore, from now on, he only will use Wordstar, because of the "new functions"... hehehehe
Engineering: Where the rubber meets the road!
marteline is offline   Reply With Quote
Old 08-15-2008, 10:35 AM   #2172
Dougw133 is an unknown quantity at this point
It's now a plugin "Motion Lock", go to the settings and then to plugins...Read the help file.
Dougw133 is offline   Reply With Quote
Old 08-15-2008, 11:52 AM   #2173
wsudu is on a distinguished road
iGuidance Embedding??
I am still having a hard time getting iGuidance to embed into the into DFX4. When I click on the button it just opens ig4 in a full sized window on top. I went to the RR settings and named the window iGuidance but it still won't. I also told it the right path. Anyone else know?
wsudu is offline   Reply With Quote
Old 08-15-2008, 11:59 AM   #2174
Mibix is an unknown quantity at this point
Hmm, did you use the updated exe on the DFX website? Did you check to make sure your window is named iGuidance?
Mibix is offline   Reply With Quote
Old 08-15-2008, 11:59 AM   #2175
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Look in the help file, it details, with screen captures, how to set it up. If you are still having problems, Check THIS FAQ at the top of the forums.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
