Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 08-17-2008, 02:28 AM   #2191
lewcamino is on a distinguished road
Quote: Originally Posted by treetop777 View Post
Yep, notepad.
Record the coordinates of where you are, then open zips.dat in notepad then either find the city name you want to show when you are at those coordinates and edit it's coordinates OR find the coordinates and edit the city name (i don't remember exactly).
Don't do that...
Here is the thread that addressed this issue. There is a newer, shinnyer zips.dat posted in that thread.
http://www.mp3car.com/vbulletin/1123845-post18.html
Replace the small zips.dat with this one.
I am the stig's cousin.
lewcamino is offline   Reply With Quote
Old 08-17-2008, 04:14 AM   #2192
vicky_obee's Avatar
vicky_obee is on a distinguished road
Hi Guys,
Well I am trying hard to get the BUTTON and ICON change...
The Button ( text ) display changes BUT I AM NOT GETTING ANY ICONS ( its blank )
Can some 1 pls help me as how do i go about it...
I tried to create my own icons ( PNG format ) and also tried to replay from existing ones but still they dont sow up.....
PLS guys help me out
thanks
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
vicky_obee is offline   Reply With Quote
Old 08-17-2008, 11:37 AM   #2193
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Quote: Originally Posted by vicky_obee View Post
Hi Guys,
thanks
See if you can do it manually. The last section in this post talk about how to display the icon.
http://www.mp3car.com/vbulletin/1224017-post1359.html
treetop777 is offline   Reply With Quote
Old 08-17-2008, 02:42 PM   #2194
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Hi Guys,
thanks
I have check the btn edtr and see absolutly no probs with it... with RR open and changing one of the displayed main menu screen icons, as soon is i select any pic from any location and click open the icon changes to what i selected...
maybe a screen cap of one of the btn's your trying to change showing the button properties window from the BE.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 08-17-2008, 03:27 PM   #2195
I have a couple questions that I could not solve on my own.
1. GPS Auto switch (iGuidance): I use the GPS skin with the music info across the top. When it auto switches for navigation it goes to the full GPS screen (no music across the top) and it takes a few seconds to load up this skin. Plus I would like to keep it with the music info across the top.
2. I would like to disable the fade in when switching to GPS. It takes too long on my system (transitions is already -1)
I would also like to contribute to any who is using the web browser this tip.
I missed the OSK from 3.0. Now we only have the URL button.
Change this line in wbrowser.skin
Code:
B04,101,526,98,67,"WEBURL"
To
Code:
B04,101,526,98,67,"APPOSK",@WEBURL@
This will give you the OSK on press and URL on press&hold
You can also change the label to match
Change this:
Code:
L,107,543,85,33,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFont#,"=URL","CENTER"
to
Code:
L,107,543,85,33,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFont#,"=OSK","CENTER"
or whatever u want
Old 08-18-2008, 01:50 PM   #2196
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
1) I have fixed this for the next release, so it remembers what view you have it set to.
2) I did this as personally I HATED the whole white flash and iguidance appearing, then embedding. THis makes it smoother, but yes, is slower on a lot of systems. Open the iGuidance_Music.skin, and remove the forceeffects line. That will remove the fade.
I am not sure how much I will be on the forums for the next couple days with Fay headed out way. As far as the forecast goes, it is not going to hit here directly... BUT we are still going to get 50 MPH + winds from it. That , more than likely, means the power will be going out intermittently.
Here is the latest radar, and yes, it is really, really nasty outside right now! (That little star is where I am located)
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 08-18-2008, 03:26 PM   #2197
dhantiflag's Avatar
dhantiflag is an unknown quantity at this point
good luck with the storm!!
if you get a moment can you look at my posts (few back)
here i copy it:
Quote: Originally Posted by dhantiflag View Post
so maybe this has been answered, but i couldnt find it...
im currently using mitchjs build of the 11/7 rr
using DFX4
whenever i select a folder to play, then append another folder to the current playlist, then go to sirius, hd, hibernate or anything like that and then go back to audio, i lose the playlist... just the orignal folder is there nothing else.
also how is it possible to use the unused buttons simular to LSX void does? to embed programs in?
and some reason it wont open garmin GPS, but if i have garmin already open dsx reconizes it and moves it and resizes it propperly
dhantiflag is offline   Reply With Quote
Old 08-18-2008, 03:36 PM   #2198
Super Moderator
JohnWPB's Avatar
With the DFX Button editor, in the helper files folder, you can put anything you want on the empty buttons.
Open the exectbl.ini in the skin folder, search for "Garmin" and change to the correct path on your system.
Old 08-18-2008, 03:48 PM   #2199
hpric is on a distinguished road
Having an issue with the browser keyboard
For some strange reason when I type a URL and click the enter key nothing happens. The keyboard is responding (shows URL I'm typing) but it appears the enter key is not doing anything. To make matters worse there is no way for me to back out of this screen. Am I the only one having this issue?
This doesn't happen if I use an external keyboard
hpric is offline   Reply With Quote
Old 08-18-2008, 06:24 PM   #2200
Super Moderator
JohnWPB's Avatar
@hpric: Hmmm This is the first time this has been reported... The Enter key has the standard Key13 (Carriage return character). If you get stuck in the screen, try pressing the cancel key on the top left of the OSK.
If you can't figure it out, I can have a look at it Sunday after next if you are going to be at the meet.
Old 08-18-2008, 07:02 PM   #2201
Dougw133 is an unknown quantity at this point
I just went out to the car and was able to duplicate this problem... Same as described the enter does not seem to activate the URL entry. From regular keyboard it works fine.
: Also, the new weather looks great, what's + on the radar button now? Different function?
Dougw133 is offline   Reply With Quote
Old 08-18-2008, 08:17 PM   #2202
By the way, have fun with FAY
Old 08-18-2008, 11:44 PM   #2203
Super Moderator
JohnWPB's Avatar
Hmm I will have to look into it a bit further then....
A plus sign (+) on any button on the skin means it has a second function if pressed and held. In the case of the radar button on the weather screens, it will bring up the European weather mentioned a page or so back.
Old 08-19-2008, 12:19 AM   #2204
Ok cool, yeah i understood the +, I guess I was just asking what the extra function was..Thanks
Old 08-19-2008, 02:03 AM   #2205
Stay out of the way of that storm man. Thanks for the info. I suppose the auto switch is compiled in something?
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
