Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 08-19-2008, 03:19 AM   #2206
lewcamino is on a distinguished road
Quote: Originally Posted by lewcamino View Post
Stay out of the way of that storm man. Thanks for the info. I suppose the auto switch is compiled in something?
I checked into the transition issue and found this:
In this file "EXTERNAL_Music_GPS.skin" I found
Code:
RoadRunner Skin RRScreen IGUIDANCE. iGuidance_Music_OFF.png,iGuidance_Music_OFF.png,iGuidance_Music_On.png,iGuidance_Music_OFF.png NG,80,70,639,523 INC,DFX_Font_Color.txt /FORCEEFFECT=TRUE /EFFECTIN=0
I found the same thing in this file "EXTERNAL_GPS.skin"
Forceefect looks to be commented out already. I removed it just to be sure but I was still getting the fade.
I don't mean to correct you but I had to remove the "/EFFECTIN=0" line to disable the fade.
I have a more general question related to this though. I thought that a "/" (forward slash) comments the line out (ignored)?
I am the stig's cousin.
lewcamino is offline   Reply With Quote
Old 08-19-2008, 03:45 AM   #2207
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
For about 99% of the time yes /=line commented out, there are a few skin cmds that have that as part of the cmd.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 08-19-2008, 10:40 AM   #2208
marteline's Avatar
marteline is an unknown quantity at this point
I didn´t find anyone question about the color menu... when I use this menu, I must change the background color first, otherwise, the other colors buttons don´t work... are you guys facing the same problem?
Engineering: Where the rubber meets the road!
marteline is offline   Reply With Quote
Old 08-19-2008, 03:39 PM   #2209
cameronlazzari is an unknown quantity at this point
I am having an issue with sirius. I shut my carpc down with hibernation in the skin digitalfx. When I start it up there is no sound with sirius. I have to exit out of roadrunner and open it again to get sound. I tried it in other skins and the same issue. Is there something I am doing wrong?
I had it working great before I did a full format...not sure what is going on here.
I am using a laptop.
cameronlazzari is offline   Reply With Quote
Old 08-19-2008, 03:53 PM   #2210
dmistry is an unknown quantity at this point
Cam,
Hit up Mitch he is looking for beta testers for his new sirius code and i had the same problem until i started testing his beta code and everything starting working great for me..
dmistry is offline   Reply With Quote
Old 08-19-2008, 08:42 PM   #2211
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
John, I guess this should be a bug report, but I only have a few minutes. The FM radio doesn't have a radio_menu_function.skin. Without this skin, you cannot do a local station scan on Radiator-based, ADS, or Silabs FM radios. As a work-around, I just changed the "LOCAL SCAN" button to "FUNCTION||SCAN" and copied the radio_player.skin to radio_menu_function.skin. The screen flashes as it loads the three screens and then proceeds with the scan, but its almost unnoticeable.
The "LOCAL" button could have been used, but then I wouldn't have a way to switch between the two. I guess it may may be better to use a byindicator command on the existing "scan" button: "BYIND;LOCAL;SCAN<<FUNCTION||SCAN". This would completely eliminate the need for the second button.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 08-19-2008, 09:32 PM   #2212
Quote: Originally Posted by dmistry View Post
Cam,
Sounds I will get in contact with him
Old 08-19-2008, 10:34 PM   #2213
quantum's Avatar
quantum is on a distinguished road
I read about this free program that works with Windows Mobile phones in this post http://www.mp3car.com/vbulletin/soft...e-control.html The download link for the software (myMobiler) is there too.
Since I have a Motorola Q (and none of the RR phone programs seem to work with it), I decided to give this a shot.
One of the members built a skin for "Simplisitique", so I decided I needed a lesson in skinning to make it work with my favorite skin, DFX4.0. Not bad for a first time me thinks.
Basically, I used the DFX 4.0 Phoco skin and remapped all the buttons and labels from one to the other, and guess what, it worked, even the OSK!
Now, I would LOVE to have someone check it, add stuff to it, clean it up if need be, etc. One problem I can't seem to get around is the size of the Motorola phone screen that shows up. You can see in the pics below that the right 1/3rd of it is cut off.
The coolest thing about this setup is I can use the TS to dial a number, and when the call kicks in, it fires up my Onstar / BT conversion kit mentioned here. So, I can see what is displayed on the screen, make contact list calls, and use all the functions of my phone on screen, and talk over the factory mic and speakers! The GMOS-06 kit also mutes the sound going through the amp (fades) while a call is in progress, and then fades back on when the call is over.
Here is the code for the skin. I also needed to add the path to the ExecTbl.ini file manually, it woudn't "stick" when I used the button editor for some reason.
MEDIACAR Skin
MEDIACAR Phone Skin
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B24,442,338,98,83,"ACTIVATE;!My Mobiler||SENDKEY;{DOWN}",
B23,445,149,94,80,"ACTIVATE;!My Mobiler||SENDKEY;{UP}",
B21,675,10,58,40,"PREV",""
B02,2,93,98,084,"ACTIVATE;!My Mobiler||SENDKEY;{F7}","Volume-"
B01,4,5,98,084,"ACTIVATE;!My Mobiler||SENDKEY;{F6}","Volume+"
B22,600,10,58,40,"NEXT",""
B26,2,518,103,78,"CLOSE","Exit"
B10,548,397,248,69,"ACTIVATE;!My Mobiler||SENDKEY;{ENTER}",
B08,337,529,218,67,"ACTIVATE;!My Mobiler||SENDKEY;{F4}",
B07,106,530,206,65,"ACTIVATE;!My Mobiler||SENDKEY;{F3}",
B59,443,250,91,81,"APPOSK",""
B,435,433,106,90,"ACTIVATE;!My Mobiler||SENDKEY;{PGDN}",""
B,443,56,91,81,"ACTIVATE;!My Mobiler||SENDKEY;{PGUP}",""
B03,2,178,98,082,"ACTIVATE;!My Mobiler||SENDKEY;{RIGHT}",""
B04,2,265,97,083,"ACTIVATE;!My Mobiler||SENDKEY;{LEFT}",""
B11,550,109,079,060,“ACTIVATE;!My Mobiler||SENDKEY;{1}",""
B12,632,112,080,060,“ACTIVATE;!My Mobiler||SENDKEY;2",""
B13,712,113,077,060,“ACTIVATE;!My Mobiler||SENDKEY;{3}",""
B06,2,438,98,083,"ACTIVATE;!My Mobiler||SENDKEY;{F2}",
B05,1,353,98,083,"ACTIVATE;!My Mobiler||SENDKEY;{F1}",
B20,552,321,079,70,"ACTIVATE;!My Mobiler||SENDKEY;{F8}",
B25,557,533,238,61,"ACTIVATE;!My Mobiler||SENDKEY;{F11}",""
B14,552,181,079,65,"ACTIVATE;!My Mobiler||SENDKEY;4",""
B15,634,181,079,65,"ACTIVATE;!My Mobiler||SENDKEY;{5}",""
B16,713,183,077,64,"ACTIVATE;!My Mobiler||SENDKEY;{6}",""
B17,551,254,079,63,"ACTIVATE;!My Mobiler||SENDKEY;{7}",""
B18,632,251,079,66,"ACTIVATE;!My Mobiler||SENDKEY;{8}",""
B19,712,250,077,68,"ACTIVATE;!My Mobiler||SENDKEY;{9}",""
B09,551,468,247,58,"ACTIVATE;!My Mobiler||SENDKEY;{F12}",""
B21,631,322,079,67,"ACTIVATE;!My Mobiler||SENDKEY;(0)",""
B22,713,320,077,69,"ACTIVATE;!My Mobiler||SENDKEY;{F9}",""
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L55,500,10,100,35,#DFX1R#,#DFX1G#,#DFX1B#,18,#DFXF ONT#,"REMAININGTRACKTIME",""
L03,150,10,268,35,#DFX1R#,#DFX1G#,#DFX1B#,18,#DFXF ONT#,"/ ||TAGARTIST||= - ||TAGTITLE||=","SCROLL-LEFT"
L,8,544,83,36,#DFX1R#,#DFX1G#,#DFX1B#,19,#DFXFont# ,"=MENU","CENTER"
L,570,482,197,34,#DFX1R#,#DFX1G#,#DFX1B#,26,#DFXFo nt#,"=Home","Center"
L,569,548,197,33,#DFX1R#,#DFX1G#,#DFX1B#,26,#DFXFo nt#,"=Screen Off","Center"
L,716,335,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=#","Center"
L,636,336,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=0","Center"
L,557,342,71,44,#DFX1R#,#DFX1G#,#DFX1B#,40,#DFXFon t#,"=*","Center"
L,716,261,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=9","Center"
L,636,262,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=8","Center"
L,555,263,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=7","Center"
L,716,193,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=6","Center"
L,636,194,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=5","Center"
L,556,193,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=4","Center"
L,716,123,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=3","Center"
L,636,123,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=2","Center"
L,555,123,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=1","Center"
L,570,413,197,40,#DFX1R#,#DFX1G#,#DFX1B#,26,#DFXFo nt#,"=Enter","Center"
L,445,270,88,32,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFon t#,"=OSK","Center"
L,10,39,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont# ,"=Vol UP","Center"
L,10,110,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Vol DN","Center"
L,10,195,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Right >","Center"
L,10,282,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Left <","Center"
L,10,368,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Soft","Center"
L,10,392,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=1","Center"
L,10,451,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Soft","Center"
L,10,477,88,20,#DFX1R#,#DFX1G#,#DFX1B#,13,#DFXFont #,"=2","Center"
L,467,63,45,31,#DFX1R#,#DFX1G#,#DFX1B#,35,#DFXFont #,"=^","CENTER"
L,464,179,48,31,#DFX1R#,#DFX1G#,#DFX1B#,35,#DFXFon t#,"=^","CENTER"
L,467,87,46,31,#DFX1R#,#DFX1G#,#DFX1B#,35,#DFXFont #,"=^","CENTER"
L,462,366,50,36,#DFX1R#,#DFX1G#,#DFX1B#,21,#DFXFon t#,"=V","CENTER"
L,466,451,48,36,#DFX1R#,#DFX1G#,#DFX1B#,21,#DFXFon t#,"=V","CENTER"
L,466,471,47,36,#DFX1R#,#DFX1G#,#DFX1B#,21,#DFXFon t#,"=V","CENTER"
/, A, x, y, w, h, color;RGB
A01,100,81,251,395,000
L,575,65,200,40,225,51,0,22,#DFXFONT#,"=Mute","CEN TER"
/, I, x, y, w, h, Code;INDICATORCODES
I06,600,70,200,40,"MASTERMUTE"
/, Y, Back Slider file path
Y01,"\volume_slider\volume_*.jpg"
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
S01,600,6,215,45,303,530,215,45,H,01,"",013,"MASTE R","Master"
END
COMPLETE! - 2002 Cadillac DTS - Summer 2008
http://www.mp3car.com/vbulletin/show...-complete.html
quantum is offline   Reply With Quote
Old 08-19-2008, 10:52 PM   #2214
Dougw133 is an unknown quantity at this point
Nice... It's too bad the Phone integrations have seemed to fall off. None of these programs out there work with my voyager and I am not willing to give up my 3G. I hope someone comes out with something for CDMA.
Dougw133 is offline   Reply With Quote
Old 08-19-2008, 11:36 PM   #2215
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quantum: Find this line in your skin:
And replace with this one:
A01,112,64,317,446,000
That should fix the area the app appears in and let you see the whole display.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 08-19-2008, 11:45 PM   #2216
quantum's Avatar
Hey John,
Glad to see you weathered the storm OK!
That did the trick! TY
Old 08-20-2008, 12:33 AM   #2217
CannonBaller is an unknown quantity at this point
I'v been looking all over. And i still can't get the Spectrum Analyzer to show up at the top part of the screen?
how can i get this to work?
CannonBaller is offline   Reply With Quote
Old 08-20-2008, 02:15 AM   #2218
Super Moderator
JohnWPB's Avatar
Ummmm Check the help file under "How do I get the spectrum analyzer to work" maybe
Old 08-20-2008, 10:17 AM   #2219
CARLOS_CET's Avatar
CARLOS_CET is on a distinguished road
First I have to say that this skin is awesome! I've been a LSX skin user and just switched over to this one. Both skins are great but it feels like this one has a lot more features and more flexible.
I just got through reading all of the DFX 4.0 posts. Took a couple of days.
docbreezy requested this option below and I wanted to know if there was some way to get it working. I just setup the 5.1 surround sound on my M10K (after 3 years) and sometimes I have to minimize RR to be able to adjust my sound settings to the rear speakers and sub. I was hoping there was some way to get this integrated into the, line in, mic and aux setting in the mixer screen??
Quote: Originally Posted by docbreezy View Post
First off since this is my first post on this, i must say this is a sublime skin, i mean everything you could ask for and more.
I do have one small question though though regarding Fading the volume, not increasing or decreasing, but rather from front to rear. I realize that that is not an option in the skin but i am adding this X-Fi Surround 5.1 from creative specificaly to have control over the channels and my subwoofer ""digitally"". I realize this can be achieved through the software that is provided but Digital FX is so pleasing on the eye that i would hate to go out of it and go to xp just to make those changes. Any help or suggestions is appreciated.
Oh and by the way my programming skills is non existant, i took like half a C++ class over a decade ago.
Car PC Progress
(>>>>>>>>>>>>---) 90%
"Don't speak about it, be about it"
CARLOS_CET is offline   Reply With Quote
Old 08-20-2008, 10:34 AM   #2220
I did check hte Help file. And i followed the instructions. and I got the Spectrum Analyzer to work via AVS. But only on the Album cover.
I would also like to get it working on on the TOP part of the screen. So it works on the MAIN page as well.
And btw (DFX Team)...just to report to whomever is in charge of keeping the "HELP"file up to date.
The section that says "click HERE" to the the analyzer working on the first page, doest work. Infact the Hyperlink is completely gone. And there isn't a section referring to this setup in the DFX4.0 help file.
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
