08-22-2008, 02:59 AM
#2236
Quote: Originally Posted by jnot2
I have searched this thread and site but could not find what I was looking for.. Anyway I cannot get the WIFI skin to show anything. I have a wirelss card in my laptop. It is just using the vista drivers. It connects fine with my home wireless networkbut like I said I cant get anything to show up in the WIFI skin... Once agin thanks for all the help.. Donations will be comming once I get everythng working and installed....
Vista = awful, especially for Front Ends.
08-22-2008, 03:12 AM
#2237
I am still having an issue with sirius. I shut my carpc down with hibernation in the skin digitalfx. When I start it up there is no sound with sirius. I have to exit out of roadrunner and open it again to get sound. I tried it in other skins and the same issue. Is there something I am doing wrong?
I had it working great before I did a full format...not sure what is going on here.
I am using a laptop.
I contacted mitch and still am having issues...anybody help!
08-22-2008, 03:52 AM
#2238
John-
I am having one issue with DigitalFX4. In DigitalFX3 when you went to search for music and selected the album you could just double click the song and it would play. In digitalFX4 you have to hit play selected in order for the song to play.
Also when the song is done playing it doesn't continue to the next track...it just stops. Is there away to get it to be more like DigitalFX3 where it will continue to the next track like a cd?
08-22-2008, 04:01 AM
#2239
Quote: Originally Posted by boriman
DFX 4 does not display Russian characters in the music player screen correctly. It is garbled. When I go back to DFX 3 - it works OK. Any one else noticed problems with int characters/able to fix it ?
I have the same problem  90% of my music is in Russian and all i see is ???????
PLEASE anyone, a solution to the problem?
08-22-2008, 04:02 AM
#2240
The Curator
Quote: Originally Posted by CARLOS_CET
Blue...Not sure if this is a bug or a problem or just normal. Today I added about 190 songs to my music directory. After that I re-built my database and at the end of the re-build it said that it deleted/removed 179 songs. Now, during my music playback, I've pressed the "remove song" button, but there is no way that I removed that many songs. Unfortunately, I don't have a copy of my music library so I can't tell you if it really deleted songs. Can you tell me why updating the database would do something like that?
RRMedia does not, or will not delete any actuall music files. If it said that it removed/deleted x songs, its telling you how many DB records that were deleted as they point to files that no longer exsit, files you either renamed or just deleted from your music collection.
Tis thinks it goes more like this... Vista = awful anywhere!
08-22-2008, 04:34 AM
#2241
The Curator
This probably would be due to the fact that DFX 4 is using my RRMedia plugin for all of the audio media handling. And sounds like a small issue in the plugin...
Quote: Originally Posted by cameronlazzari
John-
This is the way my plugin plays the songs, dbl clk'n adds it to the PL, this is one of those things that everyone will have their own preference to what action single or dbl clk'n on a song will do.
In order to play all songs on an album, you need to go back one step and play selected album. The thinking behind this is, if you go into an album then your most likely only looking to play a few songs otherwise you would have seen the album name and thought "i want to play the whole album" and selecting it to play not browsed.
Thanks for the quick response.. One more question before I quit for the night. How do you add a new menu page.
Two menu pages not enough? Hitting the menu button on the menu scn toggles between two different main menu's, giving you a total of 16 cust btns to set to your liking.
08-22-2008, 08:11 AM
#2242
have you tried Mitch's new code?
08-22-2008, 09:31 AM
#2243
no problems here, Road Runner on vista works fine for me.
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Vista with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:Garmin
Screen:Xenarc 700TSV
The Florida Meets Thread
08-22-2008, 09:37 AM
#2244
You're the only one that I know of that has it working correctly.
08-22-2008, 10:02 AM
#2245
Quote: Originally Posted by marteline
I didn´t find anyone question about the color menu... when I use this menu, I must change the background color first, otherwise, the other colors buttons don´t work... are you guys facing the same problem?
At least a "shut up and keep trying" was spectated from someone.... hehehe...
Engineering: Where the rubber meets the road!
08-22-2008, 12:52 PM
#2246
do you use anything like sirius? HD radio?
i had mine working... but not with sirius and hd radio because i couldnt select the line in...
08-22-2008, 02:11 PM
#2247
If you didn't have this problem in DFX 3 and see it now, go to DFX settings and try changing the font. It worked for me.
08-22-2008, 07:18 PM
#2248
The Curator
Good catch... I would/did completely forget about checking if the currently used font supports Unicode...
08-22-2008, 08:11 PM
#2249
CannonBaller
What Main screen layout are you using? Try using the Logo with compass. Once you have that setup, click on the time and that should bring up the vis.
Yes that worked!!!
So the compass Logo is the only one then?
08-22-2008, 09:47 PM
#2250
quick question, my youtube button doesnt bring anything up when pressed. Theres a youtube.skin in the dfx4 folder but it wont open when pressing the button. Someone was having this same issue and John said there was a line at exectbl that executes the skin. My rr.ini doesnt have any reference to youtube.skin . I've been draging the same rr.ini since version 2.0. Will renaming rr.ini to something else and letting the rrconfig app rebuild a new one fix this issue?
| Thread Tools |
| Display Modes |
Linear Mode
