09-13-2008, 02:25 PM
#2356
Confusion Master
The codes are in the skincommands.txt supplied with RRGas. They are also in the first post of the RRGas thread.
09-13-2008, 08:13 PM
#2357
Did a preliminary test on iGuidance 2009 integration. Appears it is functioning as iGuidance 4 does within DigitalFX 4.0
Here is a link for a screencapture I took.. Note - I didn't setup x-port yet - thats why there arent any co-ords on top.
http://s114.photobucket.com/albums/n...idance%202009/
09-14-2008, 03:25 AM
#2358
The Curator
Quote: Originally Posted by Enforcer
Sounds like you are still using the native gas codes in the skin.
I'm not sure if John has released an update with the new RRGas codes or functions yet.
No, soon after he returns from vac.
09-14-2008, 04:38 PM
#2359
Wondering about skype
Ok, now i have skype and it seems to work really well. Any chance I can get skype to work in my car embedded with rr? Has this been done? or am I just going to have to use it in my car outside of RR?
Thanks Phil
09-14-2008, 05:11 PM
#2360
This post is long i really didn't want to read it all. Anyways im hoping someone can help me out with a quick solution. I'm trying to use this skin, but when i try to change the color/layout. The program makes the skin all skinny and you can't see the whole user interface. Im sure its just a quick setting change.
09-16-2008, 02:40 AM
#2361
Does DFX4 skin have the TMR,1 command in the code for sending commands to the Spacenavigator driver?
I looked at the skin in skin editor and it looked a llittle odd.
Cheers
09-16-2008, 06:28 AM
#2362
Nygie,
No -- I have been adding the TMR,1 commands to each skin file that I will be having my SN do something with (damn, reminds me of some files I need to edit....)
09-16-2008, 04:56 PM
#2363
OK. I know how to do that, it's just that when I open DFX4 in the skin editor (rrskineditor) none of the skins look like what I expect. I have attached a screen print of what it shows me for menu.skin. Am I using the wrong skin editor?
I still cannot get the weather working in the car, works fine on the desktop.
I even transfered an weather named files from the desktop to the car in case it was a settings issue. The temp, sat and radar pics are ok, albeit a different country LOL
09-16-2008, 05:13 PM
#2364
Skin editor is fine. Just drop a background image of your liking into the skin editor folder.
09-16-2008, 05:27 PM
#2365
Done that, even called it background.jpg and it's the same??
09-16-2008, 06:49 PM
#2366
The Curator
I don't know what else it would be besides maybe the registering the gdipluswrapper.dll file?
09-16-2008, 11:20 PM
#2367
Quote: Originally Posted by Nygie
To help save me searching through 155 pages, I tried the search function but it just brought this thread up.
I had DFX4 working desktop but when i transfered to the car it mostly seems OK apart from the media buttons at the bottom of the main menu and in the GPS screen and maybe other but haven't checked them.
Instead of having the symbol for previous, play, next, vol-, vol+ & mute it has numbers 1,2,3,4- 4+ 5.
Is there maybe something that has not been updated on the car side?
I am having the excate same problem
reinstalling, copying fonts, nothing works...
anyone can give me a hand?
09-17-2008, 02:48 AM
#2368
mp5a4. I reinstalled the DFX4 skin as per instructions and the buttons are now fine.
I just cannot get weather to work!
Check .net framework, should be OK if your running SP2 or above. (i think)
09-17-2008, 04:40 AM
#2369
My problem is solved by clicking the no internatsomethign in RRConfig.
problem is now my MP3 Title display is displaying gibberish instead of Chinese fonts... haha i guess i will continue trying out different settings
09-17-2008, 09:19 AM
#2370
I have some problem.
I wonder if some can explain how his "dfx menu button editor" works so i can change some of the buttons in the menu of his skin.
And my computer voice is going crasy each time i start the musicplayer it starts to talk about some stars and _. So if some have any solution to this problem would be nice.
| Thread Tools |
| Display Modes |
Linear Mode
