Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 09-17-2008, 10:34 AM   #2371
MGD
MGD's Avatar
MGD is on a distinguished road
The talking is from the RRMedia plugin. Don't know if Blue can take care of this. It is very annoying. Maybe a bug in RR ?
MGD is offline   Reply With Quote
Old 09-17-2008, 10:45 AM   #2372
rsrblade is an unknown quantity at this point
Quote: Originally Posted by jurg View Post
I have some problem.
I wonder if some can explain how his "dfx menu button editor" works so i can change some of the buttons in the menu of his skin.
And my computer voice is going crasy each time i start the musicplayer it starts to talk about some stars and _. So if some have any solution to this problem would be nice.
The talking can be disabled by opening the rrconfig.exe;General;Page 1 and uncheck "Voice Enabled"
rsrblade is offline   Reply With Quote
Old 09-17-2008, 11:11 AM   #2373
jurg is an unknown quantity at this point
Okey thx. I tried another skin but with out the rrmedia plugin then the voice said the songs namn and artist that was not as annoying.
But if some can explain how his "dfx menu button editor" works so i can change some of the buttons in the menu of his skin.
I would be really
jurg is offline   Reply With Quote
Old 09-17-2008, 11:55 AM   #2374
MGD
MGD's Avatar
Read the help file in the DFX folder. Everything is in there.
Old 09-17-2008, 01:30 PM   #2375
Nygie is on a distinguished road
Me Too LOL
Nygie is offline   Reply With Quote
Old 09-17-2008, 02:41 PM   #2376
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
The button editor/creator is really very easy to use if you have some knowledge of RR cmds. The three main buttons have a description next what each one does, and then you can change/add a coresponding picture that will be shown when that button is placed on one of the two main menu screens.
Yes, I beleive that it is a bug within RR as I have many internal cmds that have many params and RR probably thinks that one of these parms are to be spoken as noted in the skin command.txt. I have a new extention plugin to incorporate all my other smaller plugins into one, plus two extra features. a seperate speaking cmds to help fix this problem till it hopefully gets fixed in RR's main code.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 09-17-2008, 05:11 PM   #2377
Chuck's Avatar
Chuck is on a distinguished road
2 years ago I had a heck of a time getting rid of all those strange speaking things and I finely did.
If there is a command that is not defined make one up in the ExecTBL.ini file
One trick I did was by adding a blank command that got rid of a lot of them on exit of stuff. – 4 spaces
"EXIT","TEMPEXIT|| "
"TEMPEXIT","EXIT"
Another thing you can do is use voice=false in the rr.ini and use the command “TALK;Say this” when you want rr to say something.
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 09-17-2008, 07:06 PM   #2378
nitefallz is an unknown quantity at this point
The help file doesn't talk about using the MP3Art plugin. It recommends to use Toaster for Winamp, but I can't find any config steps on how to integrate this either.
It seems MP3Art doesn't work with the latest RR. Can anyone confirm? All my album art is embedded in the mp3s.
nitefallz is offline   Reply With Quote
Old 09-17-2008, 08:06 PM   #2379
The Curator
Blue ZX3's Avatar
You need to update your Mp3Art.dll file that I posted HERE
Tags:
Mp3Art Plugin Mp3Art.zip
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 09-17-2008, 08:28 PM   #2380
Now I feel dumb. I didn't even see that in the searches.
Works now, thanks!
Old 09-17-2008, 08:31 PM   #2381
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Works now, thanks!
Don't feel bad, i knew it existed but couldn't find it with a search either. Just a matter of using the right search words.
treetop777 is offline   Reply With Quote
Old 09-18-2008, 05:53 AM   #2382
HuseyinOzsut is an unknown quantity at this point
The skin is perfect!! I'll make a donation for sure if I can be sure that this skin will work for me...
I have a strange problem, I searched it here but I couldn't find a solution... I use Sb audigy 2 and in RR with digital fx 4.0 skin, when I push the "volume up" all the things in the sb mixer go up, including Microphone, line-in, cd, and also bass and treble... I only want it to increase the volume... But I can not make it work like that. Anyone who knows the solution?
Ok I'm closer to the solution right now. I found that in the line mixer of digital fx skin, when I increase/Decrease the Wav also volume increases and decreases; but when I increase and decrease volume, everything increases and decreases. So I only need to find a way to control the VAW with volume increase and decrease buttons. How can I do that?
HuseyinOzsut is offline   Reply With Quote
Old 09-18-2008, 06:18 AM   #2383
The Curator
Blue ZX3's Avatar
you neen to open up RRConfig and go to General > Pg 2 > bottom right "Map Master Volume..." and check to make sure that its set to "Master Volume" and not "All Lines"
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 09-18-2008, 12:00 PM   #2384
Thank you very much!!
And again, thanks for the nice skin, there will be one more donation coming for this skin!
Old 09-18-2008, 03:20 PM   #2385
Dirtyrhino is an unknown quantity at this point
Hmmmmm.. i'm running this on a Virtual PC ATM on a test rig, and the old problem of the Flash items not working has reared it's head. I've not got any AV or Firewall SW installed on the VP, but have the latest Flash plugins on there.
I'm gonna have a cloeser look at the VPC build I've created... gotta be something there.....
/\ Nope... all looks OK.. any ideas guys ? /\
Dirtyrhino is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
