03-11-2008, 05:06 PM
#226
Quote: Originally Posted by BREWDOG52
Use the skin editor
or delete these lines from menu.skin & menu2.skin
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP2","left"
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial", "=Computer:","right"
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," =Interior:","right"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP1","left"
You rock - thanks!
03-11-2008, 05:12 PM
#227
Quote: Originally Posted by jjnit
You rock - thanks!
yeah I do  no problem
03-11-2008, 05:38 PM
#228
Raw Wave
Quote: Originally Posted by nigwhyrito
hmmn that white area i am thinking you dont have the background location right in the .ini or no flash or shockwave installed. Is that the animated nissan logo.
That background preview is a flash file so he/she may indeed need to install or update flash player..
03-11-2008, 05:53 PM
#229
Quote: Originally Posted by barnyard
Ok, I think I've got the signal meters sorted out, but I can't verify because I'm at work. Anyone want to try it out and let me know?
XM signals work fine for me. Thanks.
03-11-2008, 06:01 PM
#230
Dang it, I forgot you have to install flash via IE and not firefox to do it correctly. Thanks for the reminder - I've been out of the loop for a while.
03-11-2008, 06:04 PM
#231
And the request - is there any way to lose the temperature sensor headings on the main screen
Make sure and also delete the lines from all the menu.skin and menu2.skin files in the menu folder or you may find them reappearing if you change configurations. Also, you may want to comment them out rather than deleting them to avoid taking a chance of deleting something by accident and so you can easily revive them later if you want.
03-11-2008, 06:10 PM
#232
Quote: Originally Posted by dmistry
Thanks John, if anyone takes me up on my offer I will make the icon package available to you so you can add it to your downloads.
Come on all you photoshop experts start creating some cool new icons..
waiting for you to send me a pm, I got the day off, so I can work on it today if you get back to me
actually never mind, I think I'm gonna use buuf icons or Icandy if I do anything, or does anyone have any other suggestions, or is everyone happy with the icons allready. I think their fine as-is, so if enough people don't speak up, I probably won't do it.
thanks for adding that, I didn't realize there were different menu/menu2.skin in the menu folder.
#233
just dloaded and installed dfx 3.0....this thing rocks!!!!! love it! thanks a million john! so far everything runs smoothly
03-11-2008, 06:15 PM
#234
Ding0,
Don't forget that the GPS comport in RR.ini is the port that RR, not iGuidance, will use. Since you have set GPS to 9 in RR.ini, based on your setup you will need to set the Comport to 8 in iGuidance (Tools/GPS Options/Comport).
03-11-2008, 06:22 PM
#235
Ding0,
I think DingO's problem was with sendkeys not working correctly , probably has cftmon.exe running.
03-11-2008, 06:32 PM
#236
Sirius Indicators work
OK I verified the Sirius Skin and the indicators work!!!! maybe John can add these to his next release thanks so much Barnyard!
03-11-2008, 07:08 PM
#237
DFX3 Menu Icons
Images / Icons uploaded to http://www.yourhostdirect.com/DFXMenuICONS.zip
EDIT: I must say thank you to CarPuter who has helped convert some previous images but I think these ones are better quality I hope ppl will add to this ICON package
03-11-2008, 07:17 PM
#238
Bad archive. Wont unzip
03-11-2008, 07:22 PM
#239
It works, re-download
03-11-2008, 07:30 PM
#240
GPS not loading properly?
Anyone encounter this problem with 3.0? When I click on iGuidance, the screen switches, the gps loads but music stutters and pauses for about 60-90 seconds while there's no signal. Then it locks on and I'm back to normal.
I don't think I remember having this problem with 2.5. It's everytime it loads, even in the audio player screen. I don't have this problem with LSX Void and I'm using comp ports lower than 10 with xport (8 and 9).
| Thread Tools |
| Display Modes |
Linear Mode
