09-18-2008, 11:16 PM
#2386
For some reason nothing seems to work for me other then the Music button. cant even open the setting screen. Any idea?
Got everything installed via installer and using the RR from the Helper file link...
09-18-2008, 11:28 PM
#2387
after looking into the settings, it seems that anything with a LOAD command does not work. is there some sort of plug in that i left out? sorry for being a n00b
09-19-2008, 12:22 AM
#2388
International (Russian) tags problem...
Hello,
Just started playing with RR and DigitalFX 4 skin... (best skin!).
Ran into a problem with unicode (?).
When in media browser (inside DFX4) all works correctly in the page which uses Audio_Browser.skin. However, when I click on BROWSER button (switches to RM_Media.skin) the Russian characters are all wrong. I suspect it's RMDb plugin problem? Or something else? Is there a workaround?
Please help...
(see attached pics)
The bad (RM_Media.skin)
The good (
Thanks!
--max
09-19-2008, 02:25 AM
#2389
Finally got my weather to work on the car pc.
Tried loads of settings and nothing worked. When you go into weather it was connecting and getting updates, just seemed not to be displaying the data and pictures.
In the end I just copied my DT RR folder to the car and it works a peach.
09-19-2008, 05:33 AM
#2390
BlueZX3 and John WPB, can you give me your details for paypal donations please, I can't see them anywhere obviously, and although I can't make a huge donation, I still want to give a little something for all your hard work.
Thanks,
Phil
09-19-2008, 06:28 AM
#2391
Confusion Master
Thanks,
Phil
Tried looking at the first post of this thread (for John) and first post of the RRMedia thread for Blue?
09-19-2008, 08:15 AM
#2392
Quote: Originally Posted by K4BlOs
How can I integrate maintenance to Simplistique II skin ?
You can start by posting in the right Thread...
Engineering: Where the rubber meets the road!
09-19-2008, 10:20 AM
#2393
Quote: Originally Posted by Dirtyrhino
Hmmmmm.. i'm running this on a Virtual PC ATM on a test rig, and the old problem of the Flash items not working has reared it's head. I've not got any AV or Firewall SW installed on the VP, but have the latest Flash plugins on there.
I'm gonna have a cloeser look at the VPC build I've created... gotta be something there.....
/\ Nope... all looks OK.. any ideas guys ? /\
I found the error. The auto installer puts the RR path as c:\program files\RoadRunner (no space)
Whereas i think some of the scritping looks for c:\program files\Road Runner - Proved it to myself by uninstalling RR, and reinstalling properly. Works fine now.
Just gotta try and get my Garmin to skin properly now....Help or a small nudge inthe right direction may help.
Also - the button editor is giving me this:
09-19-2008, 11:07 AM
#2394
The Curator
There should never be a problem with where you have either RR installed or the skin, just as long as the skin is in RR skin's folder in the rr directory.
I rr installed on a port HD that i take between work & home and my RR folder is called "RR Testing" and its two folders deep from the PHD's Root and I have never had any path problems with any of the DFX scripts. John has made sure not to assume where any is and always uses relative paths for his scripts.
09-19-2008, 11:10 AM
#2395
i'm not criticising, just sharing my experience. If COULD be the VMpc that i'm using, or simply a hiccup on my part.... but it works now so i'm happy.
After farting around clicking buttons I found the Garmin option in the settings for DFX4. It loads and skins pretty well now.
Any idea on the error message i'm getting ?
I've trawled the threads for an answer, but still no fix ?
09-19-2008, 11:55 AM
#2396
I just reinstalled RR and the skin but still clicking on icons that will excute a LOAD; command does not work
Am i blind that i missed something? Please help
and does having a non-english windows make a difference?
09-19-2008, 01:10 PM
#2397
The Curator
One thing that might help is to turn on debug in the rrconfig then start rr up and press a few buttons then attach the debug.txt in your rr folder here.
09-19-2008, 01:22 PM
#2398
Whoops sorry about that reposting
09-19-2008, 01:35 PM
#2399
you might wanna just attach that as a text file next time... =)
09-19-2008, 01:56 PM
#2400
The Curator
Ok, I know what your problem is...
Your DFX skin's Exectbl.ini file is corrupt!
Towards the bottom of your debug list where you see
"2008/09/20 2:20:46: Executing: SkinButton#"
You should instead be seeing this instead
"2008/09/20 2:20:46: Executing: BYVAR;MAINBUTTON#;MyApp01<<MyApp02<<MyApp03<<MyApp 04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<M yApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp1 5<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<My App21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26 <<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyA pp32<<MyApp33<<MyApp34<<MyApp35<<MyApp36<<MyApp37< <MyApp38<<MyApp39<<MyApp40<<MyApp41<<MyApp42<<MyAp p43<<MyApp44<<MyApp45<<MyApp46<<MyApp47<<MyApp48<< MyApp49<<MyApp50<<MyApp51<<MyApp52<<MyApp53<<MyApp 54<<MyApp55<<MyApp56<<MyApp57<<MyApp58<<MyApp59<<M yApp60<<MyApp61<<MyApp62<<MyApp63<<MyApp64<<MyApp6 5<<MyApp66<<MyApp67<<MyApp68<<MyApp69<<MyApp70<<My App71<<MyApp72<<MyApp73<<MyApp74<<MyApp75<<MyApp76 <<MyApp77<<MyApp78<<MyApp79<<MyApp80<<MyApp81"
| Thread Tools |
| Display Modes |
Linear Mode
