09-19-2008, 01:57 PM
#2401
The Curator
Have you by chance gone in a manually changed something in it????
09-19-2008, 02:08 PM
#2402
No i jsut downloaded it installed and did nothing...
where can i find the un-corrupted version?
THANKS SO MUCH for your help! At least i know whats wrong now
09-19-2008, 02:21 PM
#2403
Here is my exectbl.ini by the way
09-19-2008, 02:30 PM
#2404
OK i think i understand what happened.
its a problem with Japanese Windows.
See when US PC uses the \ for directory, japanese PC uses a different symbol, thus everythign stops working.
Thanks for the help BlueZX3!
09-20-2008, 04:03 AM
#2405
.......... my problem with the button editor.... anyone ????
09-20-2008, 05:06 AM
#2406
The Curator
Have you (manually) changed anything in the skins exectbl.ini file? Next, are you using the supplied newer button editor as opposed to the one from dfx 3.0? you should have swap and delete buttons in the top right corner area if its the correct one to be using for 4.0.
09-20-2008, 02:08 PM
#2407
i've not changed anything in the ini file, And i'm using the button mod supplied with the 4.0 installer......
09-20-2008, 05:05 PM
#2408
Hello,
I am given the same error message when I try to run DFX Menu Button Editor.exe
Any idea why?
My RR is installed in c:\program files\RoadRunner
Thanks!
--max
Quote: Originally Posted by Dirtyrhino
The auto installer puts the RR path as c:\program files\RoadRunner (no space)
Also - the button editor is giving me this:
09-20-2008, 05:52 PM
#2409
I get the same error and mine is installed to default location.
09-20-2008, 09:08 PM
#2410
The Curator
Should I assume that error message appears when trying open the editor?
09-21-2008, 07:37 AM
#2411
Hya - sorry for the delay in my reply - i've been busy playing with scripting.
I had alook through my system, and decided to do a fresh installation on my new ITX unit ( i've been playing with VB6 the past few weeks on the test rig) All is now fine. I have no idea why it wasn't working, but I don't care - it works now.
One thing I have realised, though, is that the DVD and Video apps lock up RR.... is this just a path problem, or have I missed something in the apps ?
I've Got Garmin Mobile PC to work now, and Destinator 7 - which I'm quite happy about. Altough GMPC does open up too high on the screen, blocking out the x and - buttons, but I can live with this for the time being.....
[B]
09-21-2008, 08:05 AM
#2412
Yes it does. I am sorry for not being clearer.
09-21-2008, 03:21 PM
#2413
John and Blue, just made a small donation to you both to say thanks.
I live in UK, and I'm trying to get the weather sorted, but there seems to be no weather_europe.ini file in my \DFX4.0\weather\ folder, My DFX 4.o installer was downloaded on 9th August, which should be the most recent version according to the JohnWPB site. I know there were mentions of a patch, to replace/update modified files but can't find it, or it maybe that nothing has been released yet, if so I'll be patient
Can anyone advise ?
Thanks, Phil.
09-21-2008, 07:18 PM
#2414
Quote: Originally Posted by maxthebuilder
Hello,
Any idea why?
Thanks!
--max
Try a couple of things:
1. Change the folder name to Road Runner (with a space);
2. Make sure the button editor is in the DigitalFX 4.0 folder;
3. I believe I may have had the same issue a few months ago and eventually figured out that I was using an older version of the button editor. I seem to remember that there were two versions and the older one gave me trouble. The newer one is included with the DFX download, but for some reason I was using the older one. Try using the [ ADDED BY JohnWPB Latest one from 09/23/08 in the FAQ (post #3 in this thread) ].
Reason: Changed the link to point to the latest version of the button editor
09-21-2008, 08:08 PM
#2415
3. I believe I may have had the same issue a few months ago and eventually figured out that I was using an older version of the button editor. I seem to remember that there were two versions and the older one gave me trouble. The newer one is included with the DFX download, but for some reason I was using the older one. Try using the attached.
This fixed it for me. Thank you.
| Thread Tools |
| Display Modes |
Linear Mode
