Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 09-25-2008, 06:56 AM   #2446
iNcArCeRaTiOn is an unknown quantity at this point
Quote: Originally Posted by JohnWPB View Post
Yea, I removed the option from the skin, intending to move the button to somewhere else.... and I forgot It is now in the skin settings / change colors / screen for the next release.
If it's not working, make sure you have the latest build of Road Runner, as that rr.ini option will not work on older RR. versions
i'm pretty sure i've got the most up-to-date RR as when ever i update DFX i update RR by completely uninstalling -> reinstalling RR -> then installing DFX and reconfiguring everything in RR and DFX.
but i'll reinstall them both again and see if it works...
EDIT\UPDATE: nope, it doesn't work. i tried adding it manually into rr.ini as well as adding it in RRConfig in the "INI Extras"...neither worked (and it put it in the same place basically, at the bottom of the ini file under "[Extras]".
should i just wait for a new release and use 3.0? lol
2006 Mazda 3 S Series
2.3L 4cyl Engine
Current Build
- Commell LV-677 Motherboard
- Intel Core 2 Duo T5500 CPU
- Dual 512MB PC5300\667MHz RAM
- Seagate 80GB SATA HDD
- M2-ATX 160W PSU
- Dynamix 8" LCD Touchscreen
- VoomPC I Mini-ITX Case (Black)
iNcArCeRaTiOn is offline   Reply With Quote
Old 09-25-2008, 07:53 AM   #2447
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Quote: Originally Posted by bongta029 View Post
I'm new to RR. I installed the program and this skin, but
how do i change colors and clock? and the buttons on the bottom are not previous,play,next buttons, but it's diplayed with numbers, 0,1,2,3,4,4,5 like this.
how can i fix that?
It's a font issue, search the thread for solutions.
Machinehead is offline   Reply With Quote
Old 09-25-2008, 07:55 AM   #2448
What version of RR are you using? The latest is 9-10-08 and it's not part of the installer.
Old 09-25-2008, 08:46 AM   #2449
Impartialise is an unknown quantity at this point
Bongta,
The Colours you can change in the DFX settings menu, in settings option.
Re. The clock - You can change the theme in DFX settings also, and change to a flash spinning logo/compass etc.
The numbers you get at the bottom of the screen is due to not having the correct font installed for DFX 4.0. Check a few pages back, several other users have had this problem also.
Alix,
Beautiful thing of roadrunner is you can do anything, just need a little know-how.
Check out the FAQ section in forums on how to embed any application into RR, this will eb a good starting point.
JohnWPB,
a couple of things;-
1. WEBURL cmd in browser when using firefox crashes, haven't tried with IE yet. I know I'm not the only one having this problem.
2. European_weather.ini, this isn't in the latest install, is there a patch available, or do I need to wait til next release ??
Thanks,
Phil
EDIT: I should refresh my browser a bit quicker than every few hours before posting! lol!
Impartialise is offline   Reply With Quote
Old 09-25-2008, 08:56 AM   #2450
dmistry is an unknown quantity at this point
Quote:
JohnWPB,
Mine crashes too, I am using firefox 3.0.1 not sure what version you are running, I just keep forgetting to file a bug on John's Bug Tracker page..
dmistry is offline   Reply With Quote
Old 09-25-2008, 09:08 AM   #2451
I ran into the bug yesterday as well.
Old 09-25-2008, 09:15 AM   #2452
I too am using 3.0.1, but just checked Mozilla website, and 3.0.2 is now available, I will try that when I get home and report my findings.
Old 09-25-2008, 10:49 AM   #2453
Dirtyrhino is an unknown quantity at this point
how can i fix that?
In RRConfig, go to PAGE 1 and click the option in the bottom left corner called "No internationalization"
If that doesn't work, try this:
go into C:\road runner\skins\digital fx4.0\helper files\
look for a font called DFXfont1.ttf
copy this to your c:\windows\fonts folder. If windows tells you to remove the old font first, do this and then paste the one you copied back in there.
Dirtyrhino is offline   Reply With Quote
Old 09-25-2008, 11:01 AM   #2454
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
Well I have to say I love the skin, still getting used to the music browsing, but overall great job!
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 09-25-2008, 11:06 AM   #2455
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
wow, that's a name i haven't seen in a while...
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 09-25-2008, 12:42 PM   #2456
i downloaded the most up-to-date installer and used it (got it from the mirror page) then i used the updater and it said everything was up-to-date
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
Old 09-25-2008, 01:04 PM   #2457
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
The latest will need to be downloaded seperately, the updater is out of date
Enforcer is offline   Reply With Quote
Old 09-25-2008, 01:10 PM   #2458
Download it here: http://www.mp3car.com/vbulletin/road...r-release.html
Old 09-25-2008, 04:11 PM   #2459
MySQL Error
jcdillin's Avatar
Who me? Yeah haven't had much time to be around lately.
肚子笑痛了
S60 Install
Old 09-25-2008, 04:48 PM   #2460
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Me and mah boy mitch will hopefully be releasing a new installer/updater tomorrow. Now
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
