Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 03-11-2008, 10:10 PM   #256
PacketSniffer is an unknown quantity at this point
Quote: Originally Posted by tigergibb View Post
brewdog,
apparantly some people are missing certain skin files not included in digitalfx or enforcers traffic files... maybe we got them in a previous release somehow
My TrafficCams 1.2.7 worked out of the box.
PacketSniffer is offline   Reply With Quote
Old 03-11-2008, 10:14 PM   #257
ding0 is an unknown quantity at this point
Quote: Originally Posted by BREWDOG52 View Post
see if you have the process cftmon.exe running in taskmanager, if you do kill it.
EDIT*all of your sendkeys behave this way right? not just n, +, and - , does the keyboard work?
Well that was it! Now how was I supposed to know/find that?
What other gotchas are there lurking out there?
This sure is like trying to find your gum after you dropped it in the chicken coop!!
THANKS!
d
ding0 is offline   Reply With Quote
Old 03-11-2008, 10:15 PM   #258
mnickolson is an unknown quantity at this point
If anyone is missing any skin files for the traffic, pm me which files you're missing and I'll send them to you.
Thanks a lot tigergibb. Works great now.
2004 Sport Trac PC Project.
mnickolson is offline   Reply With Quote
Old 03-11-2008, 10:18 PM   #259
Quote: Originally Posted by kbreeden View Post
Ding0,
Don't forget that the GPS comport in RR.ini is the port that RR, not iGuidance, will use. Since you have set GPS to 9 in RR.ini, based on your setup you will need to set the Comport to 8 in iGuidance (Tools/GPS Options/Comport).
Will do - thanks!
Old 03-11-2008, 10:22 PM   #260
japeeler's Avatar
japeeler is an unknown quantity at this point
JOHN........ I do not know what to say! I am Speechless on the new version! AMAZING Werk, dude! I now have it all running and changed the Main Menu to the buttons I wanted and KIXA**!!!!! Just an amazing skin! I will be taking it on a Long RT this next week and will probably get another "GEEK" on the bandwagon of CarPC's! My Bro-In-Law has a 30th Anni Trans Am and I know he will want to install one in his!! Again, Dude, WELL WORTH THE DONARIOS and Effort! Simply Great Job!
-=- TruckPC Progress -=- 98% Complete -=-
-=- 2006 Ford F-150 Screw 4x4 -=-
@@@@@@@@@@ <-- Planning Phase
@@@@@@@@@@ <-- Purchasing (Never End)
@@@@@@@@@@ <-- Construction Phase
@@@@@@@@@@ <-- Installation Phase
My TruckPC WorkLog @ MP3Car.com
japeeler is offline   Reply With Quote
Old 03-11-2008, 10:26 PM   #261
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by dmistry View Post
Images / Icons uploaded to http://www.yourhostdirect.com/DFXMenuICONS.zip
EDIT: I must say thank you to CarPuter who has helped convert some previous images but I think these ones are better quality I hope ppl will add to this ICON package
The icons do look really nice! But only about half of the icons are in the package. Also, if they could be renamed to match whats in the MenuIcons folder, that would be great. When the package is complete, I will gladly make them avail as an alternate set of icons. I may even make a new settings screen in the skin, to choose from different sets of icons. To to this though, the icons sets need to be complete, and named correctly to work.
Thanks for you work on these!
Ok this is my last post, getting ready to go to bed as I have to be up at 4am to go to the airport. I will be back in one week.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 03-11-2008, 10:36 PM   #262
BREWDOG52's Avatar
BREWDOG52 is an unknown quantity at this point
Have a safe trip John.
BREWDOG52 is offline   Reply With Quote
Old 03-11-2008, 10:37 PM   #263
shot598 is an unknown quantity at this point
is any1 having problem with the volume going up and down in dfx30
shot598 is offline   Reply With Quote
Old 03-11-2008, 10:39 PM   #264
Quote: Originally Posted by esko View Post
I had this same issue with IG3.x and the DFX2.5 skin.
DFX3.0 & IG4 work great.
Try some of these:
1. Window name in RR.config = iGuidance
2. Check "embed apps" in RR.Config
3. Check "close embeded" apps on rr exit
4. Are you using the IG*4.exe from Johns site?
5. re-install both RR & DFX3.0
1. check
2. ?? I don't see a setting by this name
3. ?? I don't see a setting by this name
4. No - from the install disk provided by iGuidance - am I supposed to use the one on John's site?
5. I've done that at least 3 times.
Old 03-11-2008, 10:41 PM   #265
BREWDOG52's Avatar
Quote: Originally Posted by ding0 View Post
1. check
I must of missed your other problem with Iguidance, besides your sendkeys. what again are you having problems with. I thought you said it was running fine except for the button.
It seems to run ok but the buttons: Toggle North - doesn't work at all; Zoom + & Zoom - work but only on about 1 click in 5.
Old 03-11-2008, 10:51 PM   #266
I the questions I was addressing were things to try by another poster (post #244) trying to solve my button problems. I didn't find some of the settings he mentioned. Where can I find them?
I think its running ok now except I'm still a little muddled about the port numbers. I'm usinmg 8 and 9. If I set the one in RR Config to 8 do I set the one in iGuidance to 9?
Thank you VERY MUCH for you help.
d
Old 03-11-2008, 10:56 PM   #267
BREWDOG52's Avatar
cftmon.exe was the only problem with the buttons, nothing else you need to do there.
yes if RR is set to 8 IG will be something else, 9 is good. Your using xport right. if it's not broke don't fix it (you get a gps signal in IG right). I prefer using Johns .exe rather than what comes on the install disc.
#3 is on page 2 of general.
Old 03-11-2008, 11:06 PM   #268
Yes, I'm using xport. I "seem" to be getting some signal although when I try to follow a route it seems to hang on "waiting for gps signal...". BUT I'm doing this on my desktop in my house which has a metal roof.
Whats different about "Johns exe"?
d
Old 03-11-2008, 11:27 PM   #269
Geezus, this is sick. lol. You guys have got me editing the skins with notepad now. Just relocated my volume%. Doing this in the Skin Editor can be a little challenging (at least for me...a noob).
Can anyone help teach me a little more to fish? I'm looking to change the "GASFILEDATE" in the Gas Prices skin because the date is formatted for Europe. I'm not directly European and prefer the archaic U.S. method of date formatting (MM/DD/YY). Where is that variable getting its info?
Both buttons are working fine for me.
Old 03-11-2008, 11:39 PM   #270
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Don't let BlueZX3 hear that
Another convert to Notepad
MUHAHAHAHAHAHAHAHA!!!
Enforcer is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
