Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-03-2008, 05:15 PM   #2926
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Quote: Originally Posted by dfalk View Post
Can anyone tell me what the proper RR comand I need to use in the DFX button editor to embed iguidance into this skin?
The button is already setup in dfx, from the buttons you choose from, it don't say "iguidance", instead look for "GPS" or "navigation" and choose that one. When it goes back to the main menu it will say "iguidance"
treetop777 is offline   Reply With Quote
Old 12-03-2008, 05:18 PM   #2927
bay350z is on a distinguished road
That is what I did and on the main menu it just says GPS not iguidance. Is that right or am I missing something. The auto switch to GPS doesn't seem to work right, it switches when it shouldn't.
FKA psptibby
bay350z is offline   Reply With Quote
Old 12-03-2008, 05:20 PM   #2928
Dougw133 is an unknown quantity at this point
I didn't feel like dealing with RR.gas yet. But I "believe" it will be in next release anyways if you can wait.
Dougw133 is offline   Reply With Quote
Old 12-03-2008, 05:31 PM   #2929
That might work, think it will be by xmas?
I tired to get it to launch but nothing. I don't know enough about skinning. I change the button command and some screen command at the top of the skin file. Also rename the skin file to gas. I think the skin file needs a lot more updating with the rrgas command.
FKA psptibby
Old 12-03-2008, 05:34 PM   #2930
JCGBIKE is an unknown quantity at this point
HI,
How can i do for run EXTERNAL APPS.
Because mine does not run, when i select a command " NOTHINK"!!!!
JCGBIKE is offline   Reply With Quote
Old 12-03-2008, 05:48 PM   #2931
Cdeldridge is an unknown quantity at this point
Quote: Originally Posted by jbradshw View Post
so today i was using my carpc, using rr and dfx 4.0, and i must have hit something funky on the screen as it locked it and showed the keypad to unlock.
I've never used this feature, nor set it up. What's the default code to unlock it?
1234
Cdeldridge is offline   Reply With Quote
Old 12-03-2008, 06:00 PM   #2932
Raw Wave
treetop777's Avatar
Quote: Originally Posted by JCGBIKE View Post
HI,
Look in the FAQ, you have to set it up.
Old 12-03-2008, 07:52 PM   #2933
dfalk is an unknown quantity at this point
Maybe im not makin this clear enough. Ive tried every single GPS button and none of them are for iGuidance. I dunno if I accidentally deleted it in the button editor or what, but its not there. Using the button editor Ive selected one of the "unused" buttons to make my one. All I need to know is the proper path to put in the box circled in red, to make iguidance load and embed into RR with the proper skin. Can someone just copy and past what it says in your box? Thank you
dfalk is offline   Reply With Quote
Old 12-03-2008, 08:12 PM   #2934
I didn't have to do that. I just setup igudiance in RRConfig and use the GPS button that was already there.
If I get a chance I will check, but I am not sure which GPS button is the default on after install.
FKA psptibby
Old 12-03-2008, 08:30 PM   #2935
Raw Wave
treetop777's Avatar
Code:
Load;$GpsScreen$;$GPSNAME$;$GPSPATH$;$GPSNAME$||ACTIVATE;iGuidance||SENDKEY;"{p}{p}
Old 12-03-2008, 08:38 PM   #2936
Code:
That sorta works, It loads iGuidance into RR full screen but theres no icon to return to road runner. The only way to exit iGuidance is click the menu button and select exit. Then everything goes black and RR needs to be restarted. Any ideas?
Old 12-03-2008, 09:06 PM   #2937
Raw Wave
treetop777's Avatar
If you just installed DFX, Delete it and re-install. IG works perfectly out-the- box, it shouldn't be giving you any problems..START OVER!
If you are testing on a laptop or desktop with resolution other than 800X600, the button to exit full screen (IG) will apear off towards the top right of the monitor, not within the skin. And that's assuming the script to make it work isn't missing.
So you have a decision to make. Keep troubleshooting a crippled skin or start over fresh.
Ah, and make sure the path to IG (in RRconfig) is correct and the window name reads "iGuidance" (lil eye, big gee).
Old 12-03-2008, 10:44 PM   #2938
IonDokk's Avatar
IonDokk is on a distinguished road
Quote: Originally Posted by Machinehead View Post
Update your RRmedia database from Blue's thread in the plugin subforum.
Link: http://www.mp3car.com/vbulletin/rr-p...-released.html
So I tryed that.... and it Froze again on the way home. Very frustrating
Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
IonDokk is offline   Reply With Quote
Old 12-04-2008, 08:03 AM   #2939
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Next step, delete the data base file from your music directory and rebuild the library from scratch.
Machinehead is offline   Reply With Quote
Old 12-04-2008, 09:58 AM   #2940
Toxic0n is an unknown quantity at this point
Ok, so the logo in the center was not showing and no matter what I did, I could not get it to show. So I uninstalled RR and re-installed it in the default folder (c:\program files\Road Runner insead of c:\rr). I installed DFX 4.0 on top of that, ran fixflash.exe and now I'm can see the clock/logo, HOWEVER, I am having a different problem:
The screen appears white and the buttons only come up once I click on them. I searched on here and found some replies saying my BACKGROUNDS path is invalid. I tried using RRconfig to set the background image path under the Skins tab to C:\program Files\Road Runner\BACKGROUNDS. That didn't work. There is not a BACKGROUNDs folder in the DFX4.0 skin folder . What can I do?
Toxic0n is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
