Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-04-2008, 10:06 AM   #2941
MGD
MGD's Avatar
MGD is on a distinguished road
See if you have this line in RR.ini
backgroundpath=C:\Program Files\Road Runner\Backgrounds\
if not add it.
MGD is offline   Reply With Quote
Old 12-04-2008, 10:23 AM   #2942
Toxic0n is an unknown quantity at this point
if not add it.
I will check, but isn't what doing it through the roadrunnerconfig.exe does?
Toxic0n is offline   Reply With Quote
Old 12-04-2008, 10:29 AM   #2943
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Add some wallpaper pictures to the backgrounds folder
Enforcer is offline   Reply With Quote
Old 12-04-2008, 11:14 AM   #2944
I will do that. But shouldn't the skin work by default? The last installation worked fine except the logo not showing up. Of course, that was installed over DFX 2.0 so maybe that added some backgrounds? Not sure
Old 12-04-2008, 11:18 AM   #2945
MGD
MGD's Avatar
DFX 2.0 I think had it's own background folder in the skin folder.
Old 12-04-2008, 12:14 PM   #2946
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Yes, it did, but in the last release the Baclgrounds folder is now in the Road Runner directory, as it is a new standard that was created so all skins can share the same backgrounds, instead of having multiple backgrounds folders taking up space.
As far as iGuidance, I agree, remove the skin and re-install. I use iGuidance myself, and the GPS button when the skin installer is done is defaulted to iGuidance. Looking at the capture of the button editor, you have somehow deleted the information in the exectbl.ini.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 12-04-2008, 12:49 PM   #2947
MGD
MGD's Avatar
Hey John, just tryed your DIMMER Control. Isn't it going backwards? I mean if you want to DIMM more (as in darker), should'nt be the plus sign dimm more and the minus sign dimm less. I think the way it is now it is a brightness control, + brighter, - darker.
Old 12-04-2008, 04:55 PM   #2948
I checked and the rr.ini file points to the C:\Program Files\Road Runner\BACKGROUNDS folder. There are also pictures in there. The issue still remains unresolved.
One thing to point out, I copied the execbtl.ini for the DFX 4.0 from my last install as I made some custom changes there. Is there anything in that file that could still be pointing to the old folder? I took a quick look and didn't see anything...
Old 12-04-2008, 05:13 PM   #2949
Cdeldridge is an unknown quantity at this point
John, I am editing the audio playlist skin by making the playlist screen bigger and getting rid of the nine buttons on the side of it. I also got rid of the volume +, volume -, and the mute button and moved the songs in, artist, album, song, genre, year label in their place, but the icons for the volume and mute are still there. How do I get rid of them in the playlist screen, but not in the other audio screens? Thanks....
Cdeldridge is offline   Reply With Quote
Old 12-04-2008, 05:23 PM   #2950
MGD
MGD's Avatar
Look in the skin folder, open SKIN.ini and check for any backgroundpath settings.
Old 12-04-2008, 09:02 PM   #2951
John here is a picture of the new playlist screen. How can I get rid of the volume -, volume +, and mastermute images? Thanks...
Old 12-04-2008, 09:07 PM   #2952
barnyard is an unknown quantity at this point
If I remember correctly, those are in "botombuttons.txt". You'll probably end up adding the other buttons to your new playlist screen, and deleting the reference to "bottombuttons.txt" in your skin file.
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is offline   Reply With Quote
Old 12-04-2008, 09:27 PM   #2953
This is what happens if i delete the "bottombuttons.txt" in the skin file. Any other ideas?
Old 12-04-2008, 10:46 PM   #2954
Hey I figured it out. I deleted the following lines from "bottombuttons.txt", L,628,531,71,67,#DFX1R#,#DFX1G#,#DFX1B#,29,"Arial Black","=+","CENTER"
L,526,516,71,67,#DFX1R#,#DFX1G#,#DFX1B#,40,"Arial Black","=-","CENTER"
L,712,502,71,67,#DFX1R#,#DFX1G#,#DFX1B#,65,"DFXFon t1","=4","CENTER"
L,599,504,71,67,#DFX1R#,#DFX1G#,#DFX1B#,65,"DFXFon t1","=4","CENTER" then renamed the file to "bottombuttons2.txt" then changed the menu.skin to load "bottombuttons2.txt" and wallah. Thanks for the help...
Old 12-04-2008, 11:41 PM   #2955
Dougw133 is an unknown quantity at this point
Looks good!
Dougw133 is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
