Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-06-2008, 05:10 AM   #2971
lewcamino is on a distinguished road
I thought this was kinda weird.
Code:
"MyApp20","Load;$GpsScreen$;$GPSNAME$;$GPSPATH$;$GPSNAME$||ACTIVATE;iGuidance||SENDKEY;"{p}{p}"
What is the SENDKEY;"{p}{p}" for exactly?
I removed it with seemingly no ill effects. I also tried to simply press p+p while in iGuidance but no effect. Is this for another external GPS app?
I am the stig's cousin.
lewcamino is offline   Reply With Quote
Old 12-06-2008, 08:21 AM   #2972
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Quote: Originally Posted by utd09bry View Post
are you sure you aren't running gammacontrol or any other gamma related program in RR?
im just curious because i figured the digitalfx dimmer was just an on-the-spot change and that it had no time setting.
If that's wrong... I'll be a happy man!
It only flickers on iLists, which leads me to believe that it's hardware, drivers or directx.
Machinehead is offline   Reply With Quote
Old 12-06-2008, 08:51 AM   #2973
silvi4000 is an unknown quantity at this point
Ot
I love Johns new avatar.
Hope you are feeling better and that your next avatar is a Red Ferrari
silvi4000 is offline   Reply With Quote
Old 12-06-2008, 10:49 AM   #2974
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
it is mentioned in the docmentation for dimmer ,that it may flicker in some cases over ilists and app's , and it maybe down to a low powered or quality machine.
carputer1 is offline   Reply With Quote
Old 12-06-2008, 12:56 PM   #2975
That's a cop out answer if I've ever heard one.
Old 12-06-2008, 01:04 PM   #2976
THE EXPERIMENTER
carputer1's Avatar
well mitch would'nt of put in there if it was'nt a problem would he, he could of said it all works hunky dory , and sod the lot of ya
i'm only pointing out what was in black and white, to which most don't even read the documentation weather it comes with skins or rr.
Old 12-06-2008, 01:09 PM   #2977
Dougw133 is an unknown quantity at this point
If you are using dimmer feature in XP with RR the inlaye or default video is all black and does not display either. Mitch is aware.
Dougw133 is offline   Reply With Quote
Old 12-06-2008, 01:11 PM   #2978
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
That is actually the correct answer. I worked with Mitch when he was implementing this. On a machine with a "lesser" graphics card, you will see a flicker. (It does this on my laptop, but not on my Desktop system with the same EXACT install mirrored) It is not a problem with Road Runner, but in fact a problem with GDI and the way windows handles it. iLists and the dimmer overlay are both GDI, and they are fighting each other. Think of playing video on your system, and sometimes it bleeds through other windows, or you get a ghosting effect. Same thing if you try to screen capture a video, you cant with any standard screen capture program, as it is a "layer" of sorts. Bottom line is it is the way windows itself draws the video, as well as the GDI overlays that is the problem.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 12-06-2008, 01:17 PM   #2979
Super Moderator
JohnWPB's Avatar
ODB II Coming in the next release finally!!!!!
It has been a long time coming, and many MANY thanks go out to Mezz64 for creating the RR plugin.
I purchased a ELM 327 on ebay for around $25 shipped, so the hardware is certainly inexpensive! No car to test it on as of yet
Here are a couple screen shots, and the plugin is functioning, as if it were not, all the fields would be empty, instead of containing 0's ect.
I am working on flash gauges that will show Speed, RPM and Coolant temperature, that will match the gauges on the "Gauges" skin that uses GPS to display information.
Old 12-06-2008, 01:24 PM   #2980
Ramanator's Avatar
Ramanator will become famous soon enoughRamanator will become famous soon enough
While trying to use latest RR, It changes from 32bit(color quality) to 8bit, when I exit out out of RR it switches back to 32bit. Did I forget to do something?
EDIT: Never mind I found it.
If you cant DODGE em, RAM em.
Ramanator is offline   Reply With Quote
Old 12-06-2008, 01:39 PM   #2981
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Post the problem/solution just in case somebody else run into the same issue.
treetop777 is offline   Reply With Quote
Old 12-06-2008, 02:07 PM   #2982
Ramanator's Avatar
You're right treetop, My monitor is set for 800*600*32*60, and under the "Run Road Runner at this Resolution" drop down window I was selecting 800*600*8*60, thus causing my screen to carp out.
NOTE: FVI their is a lot to choose from, so be careful in your selection
Old 12-06-2008, 02:29 PM   #2983
bay350z is on a distinguished road
Thats, great to see the ODBII plug in. I have had the hardware for awhile, but never used it since I had to switch to another app.
FKA psptibby
bay350z is offline   Reply With Quote
Old 12-06-2008, 02:30 PM   #2984
I am pretty sure, since I don't get flickering with gamma, only dimmer. I don't get the flicker problem during the day. I can check again. I might go back to gamma for now anyway.
FKA psptibby
Old 12-06-2008, 04:15 PM   #2985
utd09bry's Avatar
utd09bry is an unknown quantity at this point
i went with gamma settings because it seemed the easiest and only solution that was aware of time.
my only problem is that while gamma works great, it really takes a lot of quality out of the picture. Sure, it's darker but it makes viewing angles and colors messed up in different ways. The dimmer overlay is great because it dims the screen equally and doesn't distort the colors in any way.
Does anyone know how to make the dimmer time-sensitive? (if it isn't already...). If not, then I guess it is just a suggestion to add. I would love that feature
utd09bry is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
