Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-11-2008, 11:44 PM   #3046
Cdeldridge is an unknown quantity at this point
Quote: Originally Posted by Minoritydan View Post
Dumb Question.
Where do I paste the files in the Playlist folder - highlighted above?
sorry I meant to say copy and paste the files in the "playlist" folder to the DigitalFX 4.0 folder.
Cdeldridge is offline   Reply With Quote
Old 12-12-2008, 12:42 AM   #3047
Minoritydan is an unknown quantity at this point
Hahah,
I just realized that I don't actually have playlists (mainly because I have no idea how to make one - or access it in DFX, I've tried and never figured it out - so I just copy the folder structure over of what I download)
Like you, I mainly have Anjuabeats, Above and Beyond (TATW), Armin (ASOT) - but these are all 2 hr radio shows, so I just have the folder directories with, say 10 - 12 of these files downloaded. Since Each one of these files is about 2 hrs long.
This is what I've got, if you can help me make a playlist then great!
But - I am missing some color/text. See below.
Can I edit this to do full screen file listings?
Here is my directory structure, for what I downloaded in Nov - so I have a folder called Nov 08 that I navigate to...
Minoritydan is offline   Reply With Quote
Old 12-12-2008, 08:30 AM   #3048
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Ok, I get the hint Already!!!!!
I will add a full screen playlist to the next release. It will be accessed by pressing and holding the playlist button. Tapping it will work as it does not, and bring up the normal playlist screen.
As for pressing and holding, it is a matter of the driver settings for your touchscreen. I had this once, and don't remember what I did to fix it, other than going into all the TS settings and playing around. In the mean time, when you press and hold, if you slightly move your finger while holding, it should work.
Lastly, for the font colors, copy the include lines (DFX FOnt COlor.txt, bottom buttons.txt) to your new skin. That is where it gets the colors to display the fonts correclty.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 12-12-2008, 08:46 AM   #3049
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
He probably needs to uninstall and reinstall the drivers to get all the settings back to default. Then turn off the right-click on hold deal.
Machinehead is offline   Reply With Quote
Old 12-12-2008, 08:52 AM   #3050
kbreeden
Thanks, cdeldridge, that is really nice! I have a couple of issues, though, maybe you can help with.
1. When I bring up the playlist some of the letters are "ghosted" and the icons for the controls at the bottom don't show up, though the controls do work (same as minoritydan). See image 1.
2. When I hit the find button I get the ratings screen. See image 2.
kbreeden is offline   Reply With Quote
Old 12-12-2008, 09:00 AM   #3051
kbreeden
Play Album
I thought I had read some time ago that while listening to a song in the playlist there is a way to tell DFX to play the album on which that song appears. Though I would love to be able to do that, I haven't really explored it. I have never really messed with the ratings screen, but I now see that the ratings screen contains a "Play This Album" button. When I hit that button, though, I get the error message shown below. My two questions are (1) Am I correct that this button is supposed to play the album on which the currently playing song appears, and (2) How do I fix the error I'm getting.
Thanks.
Old 12-12-2008, 09:07 AM   #3052
kbreeden
Great, John. Hopefully, you have taken a look at Cdeldrige's full playlist above, which includes the JTF plugin. This is really nice, so hopefully you will see fit to include that as well.
Old 12-12-2008, 09:30 AM   #3053
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Kbreeden, with the current ver, you have to have the active winamp plugin installed (see the dfx helper files folder) and have wa scan your lib. The next vev that btn gets changed to use the RRMedia cmd instead.. you can change that btn to "RM_PlayAlbum" in the mean time..
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 12-12-2008, 10:34 AM   #3054
Thanks John -- I will try these out later.
Do you know why I can't add favorites to XM anymore?
I updated to the newest version of RR using the installer and seem to have lost the functionality to add/change my favorites in XM.
Old 12-12-2008, 11:23 AM   #3055
kbreeden
Thanks, Blue.
Old 12-12-2008, 11:30 AM   #3056
Try a different skin first, if it doesn't work there, report it in the latest installer thread.
Old 12-12-2008, 12:56 PM   #3057
I tried Carwings Dynamic - it did not work there, but then again that is a dynamic skin and I have issues with touch and hold.
I'll try it in the default skin that comes with the install and report back.
Old 12-12-2008, 01:06 PM   #3058
I am going to repost the fullscrenn playlist. I noticed that the bottom buttons are missing and also since most people will likely not be using red text I will be replacing the find and search buttons with the dfx custom font so they change colors as needed.
Old 12-12-2008, 01:07 PM   #3059
kbreeden
I'm not able to add XM favorites on either of my machines and I'm using the 11/2/07 version of RR. If I hit the Add Fav button nothing happens. At one time I was able to add favorites, but that was quite a while ago and I don't know what version of RR I was using at the time.
Old 12-12-2008, 01:09 PM   #3060
kbreeden
Great. Any ideas on the other issues Minoritydan and I posted?
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
