Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-13-2008, 01:44 AM   #3076
Minoritydan is an unknown quantity at this point
John -
Are there assumptions for this?
Like, are you assuming that our Music Path and Playlist path are different? Should they be different?
Minoritydan is offline   Reply With Quote
Old 12-13-2008, 02:30 AM   #3077
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Most peoples playlistpath resides inside their music path somewhere
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 12-13-2008, 02:30 AM   #3078
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by Minoritydan View Post
John -
You can store playlists in each of your album folders, and use it to play that album, but that is built into RRMedia, as well as the skin.
RR uses a separate path to store playlists, the Playlistpath= in the rr.ini.
This is the spot where RR saves all playlists you create from inside RR. This way they are all in one place, and you can browse them and pick what you want. If you have playlists in each album folder, you have to do all the browsing to get to them, and may as well just play the music without the playlist if you have to browse all the way there anyways.
Personally my playlists are stored in Road Runner\Playlists\
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 12-13-2008, 02:31 AM   #3079
The Curator
Blue ZX3's Avatar
Quote: Originally Posted by GizmoQ View Post
Hey John,
I just learned something new and wanted to share it with you. Remember when I was searching for a solution to the issue with DFX4 still showing the Artist and Album from the Audio Player when you switch to FM or XM and I wrote an elaborate RRCode section into my Exectbl.ini to change it. Well now that we have "ACTIVESOURCEID", I tried a simple label BYVAR and it works.
Example label:
L,169,93,390,30,0,00,16,xirod,"BYVAR;ACTIVESOURCEI D;rdsname<<rdsname<<TRACKNUMBER||= - ||xmstation<<TRACKNUMBER||= - ||srstation<<Tagalbum<<= <<= <<= ","SCROLL-CENTER"
The above is from one of my skins and as soon as I update all of the referenced labels in them, I'll give DFx4 a go and report back. This will definitely eliminate the last nasty bug in your menu.skins.
Hey Giz... I have already found some issues with the way mitch had added that and helped to get it working more correctly for the next release
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 12-13-2008, 02:54 AM   #3080
Cdeldridge is an unknown quantity at this point
John, thanks for the info about playlists with RR. I'm still a newbie so this is all pretty new to me. Minoritydan, did the last playlist I uploaded correct your problems? Is it working properly for you now? Just wanna make sure as this is my first contribution.
Cdeldridge is offline   Reply With Quote
Old 12-13-2008, 08:14 AM   #3081
Yes Its working for me now, the screen displays properly.
Old 12-13-2008, 10:39 AM   #3082
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Actually, I did not see anything about setting up the External Apps in the FAQ.
I have Calc and Notepad, but nothing else.
I'd like to add some others, but I can just minimize RR for now (using the hidden feature - to launch my app).
That would be a workaround i guess.
From the FAQ:
"To set it up an Application on the Launch Folder:
-You must have a "base" launch folder (i.e. C:\LAUNCH\)
-You must create a sub-folder with your App's name (i.e. C:\LAUNCH\Calc)
-You must create a INI with the same name of your sub-folder (i.e. calc.ini)
-You must enter AT LEAST those two lines in the INI file:
PATH=C:\WINDOWS\system32\calc.exe
WindowSearchString=calc
-You must have the correct path and windowsearch (found with winspector) setup right for it to work correctly
-You can OPTIONALLY save a image with your sub-folder name for displaying in the launch screen (i.e. calc.jpg)
Note: The latest RR binary packages and install have examples of Launch folder and ini files you can use as base for adding other applications."
treetop777 is offline   Reply With Quote
Old 12-13-2008, 03:59 PM   #3083
Dougw133 is an unknown quantity at this point
Wow, really? Not one person on this thread uses HD radio? Not one can tell me if their "Band" changing button functions correctly? It would be most appreciated.
Dougw133 is offline   Reply With Quote
Old 12-13-2008, 06:13 PM   #3084
Urhg...Remember back when this was released and a few of us had our Windows Fonts changed some how to the default DFX Font? That happened today upon a resume. I did not reinstall anything, change anything, or DO anything...Computer started up and boom, DFX fonts haunting my windows...Any ideas ?
Old 12-14-2008, 04:58 PM   #3085
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Quote: Originally Posted by tbird2340 View Post
John, when I choose the layout to have a photo displayed, how do I change it from the Red car that is the default?
Thanks!
Anyone know the answer to this? Thanks
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 12-14-2008, 05:12 PM   #3086
drewbp is an unknown quantity at this point
Change the Photo.jpg in the dfx skin folder to what you would like it to be.
drewbp is offline   Reply With Quote
Old 12-14-2008, 05:23 PM   #3087
Raw Wave
tbird2340's Avatar
Thanks.. I thought John told me before that he was going to make it so when you selected that it brought up your pictures path to be able to select it from there.. Guess not.
Thanks again..
Old 12-15-2008, 04:18 PM   #3088
From the FAQ:
I think I was looking in the Helper files - sorry!
where is this FAQ?
Old 12-15-2008, 05:12 PM   #3089
2 quick questions.
Does this have the Mileage plugin incorporated? I thought it was in previous versions, but I don't think I saw it at anytime when I was setting up my PC.
Background: http://www.mp3car.com/vbulletin/rr-p...mption-14.html
I could not find Vehicle Maintenance - is this in here or was it removed? Its in the fist post of this thread, but I don't see it anywhere.
Old 12-16-2008, 11:07 AM   #3090
jpbody is an unknown quantity at this point
visualizaition problem
Ok I have done some searches and can not seem to find a fix to this problem whenever I click the visu button under the music player a winamp visualization window pops up showing the visualization instead of it being in rr skin I am using the latest rr and dfx 4.0 so what do I need to do to have it show embeded instead of a seperate window
thank you
ps if there is a thread already telling how to fix this if you can just point me to it because i have looked and can not find a fix
jpbody is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
